Old 15th February 2009, 09:43   #511
goldsun's Avatar
Default Getting close to replacing tyres for my SWIFT VXi
I have 185/70/14 on 14 inch alloys on my SWIFT VXi and it has run about 48k KMs. The tyres now look worn out and deserves replacement. I need the following advise from the experts here.
1. Is 50k KMs the expected life of tyres for SWIFT VXi? or should it last longer than 50k KMs?
2. What are the upgrade options that I can opt for, if I were to retain my 14 inch rims?
Thanks in advance.
Last edited by goldsun : 15th February 2009 at 09:44. Reason: Corrected grammatical errors
goldsun is offline   Reply With Quote
Old 15th February 2009, 12:17   #512
DieselFan's Avatar
Thanked: 233 Times
1. Each tyre has Tread wear indicator in its grooves that marks 1.3mm of tread left. One that gets exposed it is time for you to change the tyres irrespective of how many kms the tyres have run. you may find more details on this in -
Car Bibles : The Wheel and Tyre Bible Page 1 of 2
2. Ideal size for 14" is 185/70. You may also use 195/70 but this is a non standard tyre and may cost you much higher with minimal additional benefits. I would suggest you stick to 185/70. You may also look at better quality tyres. Let me know which brand of tyres you are using and the type of roads /speeds you typically drive and I can suggest if a change of tyre brand is recommended.
DieselFan is online now   Reply With Quote
Old 15th February 2009, 21:59   #513
Thanked: 16 Times
hey Dieselfan,
I am running a Swift VXI with 15" lensos with Goodyear's 195/60/15 GT3 tyres, but it makes a lot of " running noise " i.e, rubber beating the road sound . I travel mostly in Bangalore. Can you help me out with this reason with this peculiar noise.
mjkaushal is offline   Reply With Quote
Old 16th February 2009, 08:44   #514
DieselFan's Avatar
Thanked: 233 Times
Hi MJ,
Some tyres do have a high noise while running. Is the noise intermittent?
Can't comment until I hear the noise. Can the noise be recorded and posted.
Old 16th February 2009, 10:22   #515
Fountainheader's Avatar
Originally Posted by mjkaushal View Post
hey Dieselfan,
mjkaushal,
Most of the performance oriented tyres (Yoko ES100, BFG Sport) do make road noise. So I guess your case is also the same.
Fountainheader is offline   Reply With Quote
Old 16th February 2009, 13:13   #516
Nikhilb2008's Avatar
Thanked: 5,122 Times
Originally Posted by Fountainheader View Post
mjkaushal,
GT3 is not a performance tyre by any stretch of imagination!!
Old 16th February 2009, 21:43   #517
Hi Team,
Can you guys share your opinion on 205/60 R14 for Swift. How do you think this would perform
Appreciate your help
Alexishot is offline   Reply With Quote
Old 16th February 2009, 22:30   #518
vikram_d's Avatar
Thanked: 937 Times
Alexishot
205/60-14 will be the wrong upsize. You need to get 205/65-14. But for 205 width tyres you will need minimum 6J rims. 7J is the correct one.
Do you plan to keep stock rims or get alloys?
Old 18th February 2009, 14:40   #519
Hello there
This is my first post here in Team-BHP
I have swift VXi ABS, 165/80 R14 with Aura alloy wheel, 14 x 5.5J, offset 32 and 4 bolt. Though run for 16K, thinking of upgrading the tyres since I regularly go to Mangalore via Shiradi, Madikeri or Shimogga/Agumbe. One can find some of the worst roads out there.
Thinking of an upgrade of tyre only and not wheels. I understand that 185/70 R14 shouldn't have any problem with that. I saw in Michelin website Energy XM1+ in 195/70 R14, mentioning the min rim width 5' and recommended 6'. Checked around tyre shops here and not many are aware of this! Does anybody has any idea about this tyre? Will this be a good fit for the alloys I have?
thanks in advance,
suresh
zensure is offline   Reply With Quote
Old 18th February 2009, 15:37   #520
vikram_d's Avatar
Thanked: 937 Times
You can go in for either 185/70 or 195 70. Both of them will do. But for 5.5J rims I would recommend 185/70-14. 195 might balloon from the sides.
Old 23rd February 2009, 09:39   #521
goldsun's Avatar
Thanks DieselFan, the link was very informative and useful. My Swift is currently running on Good Year GT770+ 185/70/14. As I have not been consistent in tyre rotation, I have two of the tyres exposing the tyre wear indicators (Front Right and Rear Left). In both these tyres, I see the outer side is worn out more than the inner side. I am not sure if this is a serious concern for me.
Most of my driving is in City 45 kms approx in a day with a max speed of 65 kmph. Occasionally approximately twice a year, I take my Swift for a long drive ( beyond 200 kms) and when on highways, I max to 120 kmph.
Please suggest a good alternative tyre and on the inconsistent wear that I am observing in my Swift.
Last edited by goldsun : 23rd February 2009 at 09:42. Reason: added more information
Old 23rd February 2009, 11:21   #522
Guys,
Anybody having experience with 195/70 R14 on 5.5J rim for Swift VXi ABS?
Michelin XM1+ 195/70 R14 says min rim 5', recommended 6' and max 6.5'
What other best options I have on 195/xx R14 tyres on 5.5' rim?
thanks
Old 24th February 2009, 21:01   #523
DieselFan's Avatar
Thanked: 233 Times
If there is uneven tread wear on the outside or inside then it is due to improper alignment or suspension setup. get alignment checked up properly.
You can do well with 185/70/R14 JK tyres which are stock tyres for ZXI/ZDI, These you can find new at Rs. 1000 a piece from any of the tire replacement folks or folks in this forum who are planning to buy new Swift and want to upgrade their tyres.
Old 2nd March 2009, 23:07   #524
rider60's Avatar
Thanked: 47 Times
well finally i am upGrading both the tyres and rims on my swift LDi all over again previously i had put 195/60-R15 michelin MXV8 with League alloys, they were Transfered to my RED Beast Viva Crdi.
now i am in luck i found one of the last sets of Honda NHC alloys 14x5.5J from the show room being sold at a discount of 70% well they are FAT-FIVES and i intend to put on 185/70-R14.
now what i need to know is are they Enkei Make?
and i dont intend to spend more than 3200 per tyre in any case, so my choices are narrowed down to
1.continentel eco contact 3 185/70-R14
2.Bridgestone Turanza ER-60
3.Bridgestone Potenza G-III
any other tyre suggestions are also welcome in this size, i chose this profile for comfort over performance, the swift's stock suspension setup was really hard and bad with the 195/60-R15 mxv8 and dad drives this car so i better stick with 70 profile
so guys help me out, and please pardon me i dont have the time and patience to read through the thread now so please answer this query thanks in advance.
rider60 is offline   Reply With Quote
Old 2nd March 2009, 23:15   #525
mobike008's Avatar
Thanked: 8,037 Times
Yash, good that you finally decided to shod your car with better rubber.
My recommendation would be to stick to ER-60 of the lot as not sure about Continental as they are still new to India and G-3's are more for performance and less for comfort.
Ritesh told me they make some noise on high speed driving.
Btw, did you get the offer of NHC alloys from Ritesh or from the Honda showroom itself? And, i think the tyre size choice is good for comfort.
Also, why dont you look at Michelin XM1+, they are up for grabs at 3.6K/Tyre and now dont tell me you cannot afford that 400 bucks/tyre since its a 2 year investment.
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 61 1st January 2018 09:49
Maruti Suzuki Alto : Tyre & wheel upgrade thread abhibh Tyre & Alloy wheel Section 361 24th October 2017 10:36
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 80 19th September 2017 09:34
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 384 3rd June 2017 20:36
