Old 15th April 2012, 09:19   #1471
rajeev k's Avatar
Thanked: 1,730 Times
Default re: Maruti Suzuki Swift : Tyre & wheel upgrade thread
Originally Posted by naveen.raju View Post
The only problem that I face is when I drive through potholes. It really hits my spine.
Originally Posted by Champion View Post
But naveen.raju, isn't road noise intruding into the cabin when you have used 205 50 15R? I have been using 205 55 15R Falken Tyres for the last 3 years and I find the road noise more than bearable. I have thought of downsizing my tyres to either 185 65 15R or 195 65 15R?
The lesser aspect ratio is the causative factor for the above here on the Indian Roads
rajeev k is offline   Reply With Quote
Old 15th April 2012, 09:53   #1472
vikram_d's Avatar
Thanked: 936 Times
Aspect ratio has nothing to do with tyre road noise. Road noise is dependent on tyre rubber compound and on tread pattern.
vikram_d is online now   Reply With Quote
Old 23rd April 2012, 22:39   #1473
sameerpb's Avatar
Thanked: 125 Times
Hi Gurus, I need help on Tyre upgrade, I have clocked 35K kms on Swift VDI with the stock JK tyres and planning to upsize to 15".
I am planning to go with 195-65-15 Michelin PLC, I see other spec which is 195-60-15 and would like to know how much 5mm side will impact?
Further I would like to know, some BHP mates upgraded to Honda city rims, How good is this option to save on alloy wheel cost (May be 15K)
Thanks for your kind help and support
sameerpb is offline   Reply With Quote
Old 24th April 2012, 10:12   #1474
ScorpMan's Avatar
Thanked: 121 Times
195/65 15 seems to be a wrong upsize. My Zdi is running on 195/60 15 BS turanza's since day 1, and they are an absolute delight. Though I wish the stock alloys were a bit more wider.
ScorpMan is offline   Reply With Quote
Old 25th April 2012, 00:50   #1475
deetjohn's Avatar
Thanked: 7,367 Times
The ZDi stock alloy is wide enough for a 195 cross section tyre.
I guess you are referring to offset of the rim here. Most after market alloys have a negative offset, which makes them jut out a bit. And it does add to the appeal.
The stock rims have Positive/ Zero offset. They don't extend out and are less glamorous. But they don't put undue load on the suspension components or throw up muck in the rain. Well, you win some, lose some.
deetjohn is offline   Reply With Quote
Old 26th April 2012, 01:01   #1476
ScorpMan's Avatar
Thanked: 121 Times
No, I am not talking about the offset here. The way 195 section's sidewall juts out of the stock rim, clearly gives an impression that the stock rim should have been more wider.
Old 26th April 2012, 11:56   #1477
deetjohn's Avatar
So, I guessed it wrong.
But isn't the stock alloy 5.5J? 195/60 R15 should be a good fit on 5.5J.
Old 1st May 2012, 15:49   #1478
rajshenoy's Avatar
Thanked: 623 Times
Infractions: 0/2 (10)
What are the current offers on various tire brands ?
I am aware of the Swiss knife on purchase of 4 Yokohoma tires. Are there any similar deals from other manufacturers ?
I have been pushing my tire purchase for a while now and looking for either A drive, Accelere or Michilin XM2 (whichever is cheaper)
rajshenoy is offline   Reply With Quote
Old 5th May 2012, 16:44   #1479
rajshenoy's Avatar
Thanked: 623 Times
Upgraded my 5 year old stock JK tornado(Swift VXI) to Yoko A drives today(185/70 R14). After 45K and few punctures and noisy ride, decided to switch to A drives even though the tires looked OK for say another 5K or so
I think i got a competitive price of 4.2K per piece, but the dealer scraped 3 of my old tires giving reasons such as either sidewall shoulder puncture, and un-even wear. So effectively i got 200 each for two of the old tires
Got Free alignment and balancing and nitrogen filling.
Ride looks well cushioned and noise has definitely reduced. Yet to measure if the FE has any drop.
I am told that the ideal pressure is 32 PSI for all tires. Is this OK ? what is the team-bhp recommended pressure for Swifts running 185/70 R14 ?
Old 5th May 2012, 17:07   #1480
Thanked: 18 Times
29 PSI is the manufacturer recommendation for Swift Zxi running 185/70 tyres. I have been maintaining 30 PSI for my Yokos. I feel for 32 PSI, the ride may be stiffer unless you are fully loaded.
ndinesh is offline   (1) Thanks Reply With Quote
Old 5th May 2012, 17:17   #1481
rajshenoy's Avatar
Thanked: 623 Times
Even with 32 PSI or more, Ride will always be better than the JK tornadoes
But yes, i would like to stick to a best combo that offers comfort as well as FE(i drive a petrol plzzz). Let me observe this for some more time to settle into optimum PSI
Old 8th May 2012, 22:40   #1482
beast_within's Avatar
Thanked: 32 Times
Hey folks I wish to upgrade stock tyres of my Swift ZDI to 195/60 on the stock 15" 5.5J alloys. On some googling I found that although 5.5J size is OK but 6J is the recommended size for 195 section tyres.
Can gurus here shed some light on the implications of retaining stock 15" 5.5J alloys on safety, life of the tyres, ride handling etc?
beast_within is offline   Reply With Quote
Old 8th May 2012, 23:01   #1483
Thanked: 274 Times
You can comfortably and safely mount 195 section tyres on your current 5.5j wheels. No problem whatsoever.
needforspeed88 is offline   (1) Thanks Reply With Quote
Old 8th May 2012, 23:39   #1484
funkyp's Avatar
Thanked: 92 Times
I went through the forum and sought advice on tyre upgrade for my zdi. 195/60 on stock alloys is the most commonly and best recommended upgrade for the swift.
I have been running yoko a - drives 195/60 since day 1 and have now 1400 kms down. never felt any problem. i guess you can safely go for this upsize.
funkyp is offline   Reply With Quote
Old 8th May 2012, 23:43   #1485
Safari_Beast's Avatar
Thanked: 196 Times
Hello Beast
I upgraded by swift Zdi tyres on day 1 to 195 60 R15 profile and there are no issue till now . Since OEM alloys have less J width which has made my car more comfortable to ride on uneven roads . Swift really glides on , when you will upgrade it then you will get to know the real experience what i want to tell you . I daily drive 50 kms on highway i.e faridabad to gurgaon , it has great twisties in between and i throw the swift into corners . I just love the way it holds on to roads . I have got bridgestone turanza Er 60 , till now no road noise and very smooth , comfortable ride it has been .
Safari_Beast is offline   (1) Thanks Reply With Quote
Maruti Suzuki Alto : Tyre & wheel upgrade thread abhibh Tyre & Alloy wheel Section 361 24th October 2017 10:36
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 80 19th September 2017 09:34
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 384 3rd June 2017 20:36
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 57 20th December 2016 13:19
