Old 8th May 2017, 09:17   #61
BLACKBLADE's Avatar
Thanked: 420 Times
Default Re: Toyota Etios & Liva : Tyre & wheel upgrade thread
Originally Posted by Doc_Hudson View Post
My Etios is running with OEM set of tyres - R15 185/60 with 44K on the ODO. I wanted to know if it is advisable to upgrade to R15 185/65? I am looking for some increase in the profile so that the car doesn't scrape on big speed breakers when loaded.
Any tire up-sizing is recommended, as long as the diametrical difference is less than 2%
Considering this, 185/65/R15 tires will have a diameter variance of 3.07%. Even though your car's ground clearance will be increased by 9.25 mm, it is not recommended.
A better up-size will be 195/60/R15, which will have diameter variance of 1.99% and your car's GC will increase by 6mm. Will result in overall improved grip and comfort levels.
Toyota Etios & Liva : Tyre & wheel upgrade thread-tire_calc_2.jpg
Also while choosing the tires go for Michelin XM2 or Yokohama Earth 1. These two brands come higly recommended by Team-BHPians for their quality and reliability.
BLACKBLADE is offline   (1) Thanks Reply With Quote
Toyota Fortuner : Tyre & wheel upgrade thread Turbanator Tyre & Alloy wheel Section 67 9th June 2018 11:55
Toyota Innova : Tyre & wheel upgrade thread Akshay1234 Tyre & Alloy wheel Section 326 13th May 2018 08:34
Toyota Corolla : Tyre & wheel upgrade thread Wraith Tyre & Alloy wheel Section 113 2nd May 2017 14:01
