Old 30th April 2016, 13:19   #31
Akshay1234's Avatar
Thanked: 7,242 Times
Default Re: Differently-sized Spare Tyre and Wheel
Originally Posted by razorBlades View Post
Ah yes.. my 17 inches are 225/45 R17 and my spare is 205/55 R17.
Please confirm if they are 225/45 or 225/50. I'm pretty sure I remember the Superb coming with 225/50 R17 tyres on the V6 model. Do check the drivers door frame or fuel lid cover where tyre pressures are mentioned. They also mention different tyre sizes. See if for 17" 225/45 or whether 225/50 is mentioned?
Akshay1234 is offline   (1) Thanks Reply With Quote
Old 1st May 2016, 12:20   #32
Ricky_63's Avatar
Thanked: 394 Times
As long as the OD of the tyres is the same it's ok. Different OD tyres on the driving wheels may be problematic IMHO
Old 1st May 2016, 15:15   #33
razorBlades's Avatar
Thanked: 70 Times
It's 225/50. Have attached the pressures pic
razorBlades is offline   Reply With Quote
Old 8th May 2016, 03:32   #34
avinash_clt's Avatar
Thanked: 930 Times
The V6 models came with 225/45 R17 as OE fitment (all 5 tyres).
I hope your car is the second gen Superb. Unless it is the V6, the spare tyre would be 205/55 R16, not 205/55 R17(improper size).225/45 R17 is also a proper upgrade sizes for both second gen Superb and Laura. Stock tyres on the 16" Lauras and Superbs were 205/55 R16.
205/55 R16, 225/50 R16, 225/45 R17 are all closely matched & accepted sizes for the tyres and thus you should have no trouble in maintaining the first size as a spare tyre.
Avinash
avinash_clt is offline   (1) Thanks Reply With Quote
Old 10th May 2016, 18:14   #35
Thanked: 70 Times
Avinash
Thanks Avinash. Yes you are correct, my last two posts are wrong and I am not able to find the edit button.
my spare is 205/55 R16
Besides, I took the car to Ignite and he said, one of my alloys have a small damage, which could seep the air outside. He suggested to change all the alloys and the tyre. I am now finding for options, but I am planning to keep the alloys as the damage is not that bad afaik.
He did have a 5 set of BBS 235/40 R18, which he had removed from a Laura. He is quoting 80k for it including the tyres (which are 6 years old). Still in dilemma on this choice. Even if I get new tyres, it might cost me minimum of 45-50k and this deal sounds good with the BBS and the tyre has another 10k kms left on it. What do you recommend?
Old 11th May 2016, 01:59   #36
Thanked: 930 Times
The correct size in 18" is 225/40 R18, though 235/40 R18 is also acceptable.
Personally I don't recommend the 18" on a Superb. You have to run quite a low profile and will require extra caution always to not damage the rim or tyre. I don't see any benefit apart from cosmetic ones. BBS alloys would shed some unsprung weight, but likely that the 17" wheels of Skoda weighs the same as an 18" from BBS. Stick to 17" is my recommendation.
I am not sure which brand of tyres you have on the car currently. There are good number of top spec tyres in 225/45 R17 size (Yoko advan sport, Michelin Pilot Sport 3, Hankook S1 Evo 2 K117 etc). They can make a significant difference if current tyres are regular ones.
Having a 6 year old tyre, irrespective of tread depth left is not advisable. Natural aging would have made the rubber loose its qualities of grip, load/heat resistance etc. So buying those BBS rims will require new tyres also.
Why not replace only the single damaged alloy? Rather buying used 18" rims for 80k, you can have new 17" from other reputed brands
Avinash
Wanted: GOOD Clothes for Plus Sized Males and Females frankmehta Shifting gears 74 11th October 2014 01:34
The Spiti Loop > done differently - 7900kms jaysmokesleaves Travelogues 189 28th September 2009 08:07
Pics: Silver Cayenne V6 and White Cayenne with spare wheel behind (update 13/05) Dippy Super-Cars & Imports in India 48 26th June 2008 21:57
Swift tire pressure and fixing spare alloy wheel doubt ece2k2 Technical Stuff 24 21st March 2008 21:57
Rear View Mirror of 2.2 VTT DICOR and spare wheel cover clamp sunishsamuel Modifications & Accessories 5 20th March 2008 19:57
