Old 1st December 2011, 17:11   #16
Default re: Skoda Rapid : Tyre & wheel upgrade Thread
Originally Posted by Nikhilb2008 View Post
The CPC2s are worse. Which is why given the current choices, I think the S drives would be better. Every tyre has it's limitations. You need to know the limitations and drive within the limits.
I agree with you. Unfortunately S-Drives reach their limits very easily especially when braking. As said by someone in someother thread, they don't quite like cars with strong brakes.
Originally Posted by oxyzen View Post
Check out if PP2 is available with the desired size. What I hear is that it is in a different league altogether.
Second that. I would anyday choose PP2s over crappy S-Drives. Have driven 75K kms with both PP1/PP2, they are probably the best among budget performace tyres.
novice is offline   Reply With Quote
Old 1st December 2011, 23:52   #17
Nikhilb2008's Avatar
Thanked: 5,067 Times
PP2s are not available. They have been phased out more than a year back. The idea was to replace PP2s with PS3s but due to the ISI rule, that hasnt panned out the way Michelin planned.
And I dont think the PP/PP2s were budget tyres. They were always way more expensive than the other tyres. The only tyre which was more expensive was the Advan Neova.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
Old 4th December 2011, 10:43   #18
Thanked: 1,224 Times
Yes, PP2's aren't available.
Got the S.Drives fitted yesterday evening! Thanks to everyone for their inputs.
The steering weighs up a little more now, the ride is a little stiffer than before, but not uncomfortable. The road noise isn't too loud to bother me (yet) either. So far so good!
The recommended stock tyre pressure for 185/60 R15 was 36psi.
For the 205/55 R15, i've set 33psi. Is this correct? What would you recommend?
kryptonite is offline   Reply With Quote
Old 6th December 2011, 17:14   #19
Default Re: Tyre upsize for Skoda Rapid (CPC2 or S.Drive). Need Help for selecting Alloys too
Originally Posted by nitrous View Post
195/60/15 if you want ride and handling.
205/55/15 would make the car handle, but you'll lose a lot of the ride quality.
how about 205/50/R16 ?
ajitmoses is offline   (1) Thanks Reply With Quote
Old 11th December 2011, 17:26   #20
Default Tyre pressure for the 205/55 R15 Yokos
The recommended stock tyre pressure for Rapid's stock 185/60 R15 was 36psi.
For the Yoko S.Drives 205/55 R15, i've set 33psi.
Old 15th December 2011, 10:17   #21
nishanth.shegde's Avatar
Default Re: Tyre pressure for the 205/55 R15 Yokos
Originally Posted by kryptonite View Post
Congrats for getting the car and tyres ...
Even I am looking for upsizing my stock tyres. I have booked TDI Ambition and would be getting it in January.
I would suggest you to keep the stock alloys and just upgrade the tyres (if you have not done it already)
Would like to talk to you on that. Not sure, whether we can share phone numbers or email Ids directly on TeamBHP. I tried for the option to message you directly through Team BHP. Couldn't find it anywhere. Is there any way we can get in touch with each other on this ?
nishanth.shegde is offline   Reply With Quote
Old 17th December 2011, 19:27   #22
Hi Nishanth,
Responded to your queries over email. Hope that helps.
kryptonite is offline   (1) Thanks Reply With Quote
Old 20th December 2011, 08:48   #23
With upto 2 or 3 people in the car with light luggage, the factory recommendation of 32psi (or 33psi) in front, and 29psi (or 30psi) at the rear tyres works best even for the 205/55/R15 upsize - in both city and highway driving conditions.
Still yet to try a full load of 5 people + luggage, but in any case I doubt i"ll be setting the recommended max load pressures of 36psi front, and 39psi rear, seems overkill.
Thanks for your inputs everyone!
Old 24th December 2011, 15:34   #24
Thanked: 46 Times
Does anybody have an opinion on 205/50/16 ? Will the ride get bumpier ? I just found the deviation from 185/60/15 to be around 1.4%. I heard we get Pirelli P6, Yoko A Drives and Hankook in this spec. Any recommendations ?
krish.sathish is offline   Reply With Quote
Old 24th December 2011, 18:52   #25
The ride quality will be terrible with the 205/50-16. I suggest you stick to 15". Think of 16" only if the roads you drive on are as smooth as a baby's buttock!
Nikhilb2008 is offline   (2) Thanks Reply With Quote
Old 11th January 2012, 21:45   #26
I have 195/60 R15 Pirelli P6 on my Skoda Rapid and I can tell you that this imho is the best size. You get great handling without losing ride comfort. This is a practical choice if youd ask me for our roads.
ajitmoses is offline   Reply With Quote
Old 11th January 2012, 22:02   #27
Please do post a detailed review of the tyres. There is a lack of good reviews on the forum regarding these tyres.
Old 11th January 2012, 22:12   #28
Nikhil: I am sorry it is not P6. It is P7.
Old 12th January 2012, 10:56   #29
It costs 5k in Chennai. I was looking at Yoko S Drives but P7 caught my attention.
2010 European Summer Tyre Test | the online tyre guide
I have not driven a lot yet to post a detailed review but my initial impression is satisfactory. The tyre is certainly a lot quieter than the stock. It looks very well constructed. Tested it quite a bit in some really tight corners and I was very impressed with the way it stuck to the roads. It also performed well under braking. The person who recommended this tyre has been in the tyre business for a while so I took his word for it.
ajitmoses is offline   (2) Thanks Reply With Quote
Old 13th January 2012, 01:03   #30
Thanked: 364 Times
Which shop in chennai? Does he also stock 205/55/15 pirelli's?
bala80 is offline   Reply With Quote
Skoda Laura : Tyre & wheel upgrade thread deepakvrao Tyre & Alloy wheel Section 317 24th December 2017 18:31
Skoda Yeti : Tyre & wheel upgrade thread Invinsible Tyre & Alloy wheel Section 474 2nd August 2017 17:22
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
