Old 14th July 2009, 11:02   #151
inferno's Avatar
After selling my Alto some days back, I've booked i10 Sportz version in white. I'm considering to go in for alloys and decent footwear. I've read all the posts in this article but still I'm a little confused.
Right now, I'm thinking to go for either of these alloys
Mag Wheels,Automotive Wheels,Aluminum Alloy Wheels,Car Chrome Wheels,Supplier
Or
and for tyres, Im thinking about apollor acelere 175/70R13.
I want to tell that my main priority is to improve looks with least decrease in fuel efficiency. Cornering and handling etc. are not of much concern as it would be mainly driven inside city by my father.
Can someone tell how much would be the decrease in fuel economy if im upgrading to 175 ?
inferno is offline   Reply With Quote
Old 14th July 2009, 13:30   #152
Tejas@perioimpl's Avatar
Thanked: 5,059 Times
Negligible. Nothing to worry about.
If you are into looks, upgrade to 14"
Tejas@perioimpl is offline   Reply With Quote
Old 14th July 2009, 13:41   #153
tsk13's Avatar
Thanked: 278 Times
Or
I'm having Santro Xing with 175 tyres upgraded from stock 155 and there has been no or negligible change in Fuel Economy.
And the four spoke design you've shortlisted is too common nowadays. Moreover, as you're in Delhi so check Sai Mag Wheels personally; you'll find ample number of designs in different finishes. Take your car along as it helps in finalising the most suitable design and finish.
For tyres, why don't you check out Yokohama/ Michelin/ Bridgestone and get tyres changed as soon as possible to get the best buyback.
tsk13 is offline   Reply With Quote
Old 14th July 2009, 13:55   #154
inferno's Avatar
My budget is around 20-22k, I think 12-15k would be used up for a set of 5 alloys. And assuming that I get 1500 per tyre, so that I can buy anything under 3k per tyre.
What are the best options in that price category ?
Old 15th July 2009, 08:21   #155
Your budget is good. I got four 14" koenig alloys and 185 Yokohama 'A' drives for around 22k after exchange of stock tyres and rims. Don't worry, you have a lot of options within your budget. I highly recommend the A drives. Super ride quality!
Old 15th July 2009, 11:03   #156
knp
Thanked: 18 Times
I have got HRS 14" (the new multispoke) and 185/60R14 Yokohoma A-drive for 24k after exchanging my stock wheels.
I got them from Sai Iyengar and they look damn cool.
knp is offline   Reply With Quote
Old 15th July 2009, 11:16   #157
sb1
Originally Posted by carZest View Post
I paid 2700 per tyre. Since the stock was MRF, the dealer was OK to give only 1500 per tyre. He said only the esteem and the getz would take 155/80. Moreover the stock tyres were tubeless.
Hope this was an OK deal!
carZest did you pay total of 2700+1500(refunded for stock tyres)=4200 per tyre ?
sb1 is offline   Reply With Quote
Old 15th July 2009, 11:33   #158
That's way too high. It should be 2700-1500 = 1200 per tyre.
Yokohama 'A' drive 185/60/14s cost 3000 approx per tyre.
Old 15th July 2009, 13:17   #159
inferno's Avatar
I must say, your alloys are killer.
Anyways, somebody told me that we lose car's warranty if we go for upsizing and after market alloys, is that true ?
My family doesn't like going in for any after market fitments as we have always had a bad experience. And that's the reason we always look out for loaded model. I earlier thought nothing can go wrong with aftermarket tyres and alloys, but now knowing that this could be used by manufacturer as an excuse to void warranty, I may not go for them.
Old 31st July 2009, 12:52   #160
Thanked: 12 Times
can someone please tell me if 175/70R13 can fit into the standard Rim. I do not want to go for alloys.
I talked to 2-3 tyre dealer and they told they have fit in a lot of cars.
Please tell me ASAP and i want to get it done today ??
For Turanza the quote is 3050
for XM1+ it is 3200
Please please tell me sooon.
madhukar_n is offline   Reply With Quote
Old 31st July 2009, 13:35   #161
Thanked: 101 Times
No it will not. Some dealers will tell you anything to make a buck. The rim width on the i10 is just too narrow for a 175. You risk the tyre coming off while driving. At high speeds, this would be a potentially very dangerous situation.
NevGin is offline   Reply With Quote
Old 31st July 2009, 15:09   #162
tsk13's Avatar
Thanked: 278 Times
If you want comfortable ride, XM1+ is the tyre but if you'll be taking the car on bad roads frequently then go for Turanzas, as they'll promise a longer life in these conditions.
Old 31st July 2009, 15:13   #163
Thanked: 12 Times
but do they fit in the Standard Rim size ????
Old 31st July 2009, 19:14   #164
Thanked: 101 Times
XM1+ start only at 14". Bottom line, they will not fit on your 13" stock rims. Even if they did in dia, the width would kill it.
Old 31st July 2009, 22:32   #165
tsk13's Avatar
Thanked: 278 Times
Thanks for the correction.
In Santro upgrade thread, a person had 175/60 R13 on stock rims running fine, ideally it's a No-No but do it at your own risk.
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 10 4th June 2017 10:16
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
