Old 3rd August 2009, 11:47   #166
Thanked: 12 Times
on Saturday I talked to at least 3-4 tyre dealers. They all told me that it will fit in no issue and they have done it to a few i10s. then i called up the sales guy in trident and he also told 175/70 R13 should fit in the existing RIM. one guy even offered me to fix it in my stepne tyre but did i did not try that.
anyway i trusted tbhp folks and decided not to do anything. thanks guys.
madhukar_n is offline   Reply With Quote
Old 9th September 2009, 10:09   #167
blackasta's Avatar
Thanked: 988 Times
Put in 185/60R14 Yokohama AVS ES 100 tires on 14" Plati 10 spoke alloys.
No issue of tire touching anywhere anytime with full load (5 persons)
blackasta is online now   Reply With Quote
Old 9th September 2009, 14:56   #168
Mi10's Avatar
Thanked: 1,459 Times
Yes, No Issues for 14 inchers on 185/60/14.
http://www.team-bhp.com/forum/tyre-a...ml#post1470608
Mi10 is offline   Reply With Quote
Old 21st September 2009, 22:15   #169
vishnuvijay's Avatar
is there any size bigger than 185/60 r15 that can be fitted on the i10 without fouling with the wheel arches? say in 195 section example 195/60 r14, 195/55 r14 or 195/50 r14 (which i suppose has a very low profile 195*50/100).
vishnuvijay is offline   Reply With Quote
Old 21st September 2009, 22:49   #170
blackasta's Avatar
Thanked: 988 Times
185/55 R 15
195/60 R 14
195/55 R 14
195/50 R 15
But ideal upsize from 155/80R13 is 185/60R14, with 0.1% difference in circumference.
source: Car Bibles : The Wheel and Tire Bible Page 2 of 2
Old 21st September 2009, 23:51   #171
heloo blackasta, i can see that. but what i need to know is that whether these sizes will foul with the rear wheel arches when under full load, say 3 person at the back.
can you please upload a picture of your car shot from behind it. i wanted to see how wide the 185 section tires are on the i10. it would be of great help.
Old 22nd September 2009, 00:07   #172
blackasta's Avatar
Thanked: 988 Times
185/55 R 15 & 195/60 R 14 have bigger circumference than 155/80R13, so there is a greater chance of fouling in their case under load.
195/55 R 14 & 195/50 R 15 have a lesser chance of fouling under load as they have smaller circumference than 155/80R13.
But 195 section tires shall stick out more and may foul with the wheel well /mud flaps while turning (front tires). The 185 section ones barely scrape though.
As for the picture, I shall post it tomorrow.
Old 22nd September 2009, 00:09   #173
thank you for the quick response.
Old 22nd September 2009, 08:16   #174
blackasta's Avatar
Thanked: 988 Times
Picture of my driver's side rear tire.
Hyundai i10 : Tyre & wheel upgrade thread-dsc02382.jpg
Hyundai i10 : Tyre & wheel upgrade thread-dsc02378.jpg
Had my not-so-presentable-self-in-the-morning reflected on the back bumper, so blackened that out!
Old 22nd September 2009, 08:38   #175
knp
Thanked: 18 Times
Even, I had put 185/60R14 A drive with HR alloys for my i10. They are not touching anywhere in the body, but my fifth wheel is not fitting to the boot. there is a screw which would tighten the wheel in the boot and it's becoming shorter for this wheel. So, i just had to leave it without tightening with some padding all around.
knp is offline   Reply With Quote
Old 22nd September 2009, 09:54   #176
thank you blackasta, i find these 185/60 r14 tires wide enough. but i think these performance tires look wider because of their stiff sidewall. i find yokohama a.drive to be narrower.
Old 24th September 2009, 14:53   #177
blackasta, can you tell me the width of your alloy wheel. is it 5.5j or 6j ?
Old 24th September 2009, 15:28   #178
blackasta's Avatar
Thanked: 988 Times
The alloys are plati 14" x 6J.
Old 24th September 2009, 17:03   #179
thank you again blackasta. can you me one more favour. can you please upload a photo of your car from behind it. this time full backside view (to see both the tyres) of the car. i want to see how wide these tyres are when viewed from behind.
Old 24th September 2009, 20:47   #180
Any particular reason you choose 6j instead of the 5.5j most people have chosen for their i10(atleast as far as I've seen).
I'll be going for 185/60 R14 xm1+ in most probability.Its the width 5.5j or 6j I haven't yet decided on.
Arun1 is offline   Reply With Quote
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 10 4th June 2017 10:16
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
