Old 15th March 2010, 22:38   #211
Infractions: 0/1 (10)
Originally Posted by maverick236 View Post
Sorry for the 2nd post mods...
There is no 175/70 R13 in Bridgestone Potenza. Any alternatives??
These are tha available sizes
165/60R13 73H175/60R13 77H175/65R14 82H185/60R13 80H185/60R14 82H185/65R14 86H185/70R13 86H
Oh. I'm using apollo acceleres if that helps . Why don't you try finding in michelin xm1+? I still suggest you PM nikhilb2008 or iraghava regarding this. They're the tire gurus on the forum. . They'll be able to guide you more accurately.
bharti22shresth is offline   Reply With Quote
Old 15th March 2010, 22:39   #212
blackasta's Avatar
Thanked: 996 Times
175/70R13 is available in michelin xm1+
Personally I am using 185/60R14 with my i10 A/T
blackasta is offline   Reply With Quote
Old 15th March 2010, 22:50   #213
maverick236's Avatar
Michelin XM1+ is on my list but its not that SPORTY... If i do not have any other option i mite as well settle for xm1+.. Just checking out the other options as I prefer this set to be comparitively sporty..
Btw, any idea about the prices of XM1+ and Bridgestone POtenza???
maverick236 is offline   Reply With Quote
Old 16th March 2010, 07:02   #214
para_7k's Avatar
Thanked: 63 Times
I'm using the XM1+ 175/70 R13 and pretty satisfied with the performance.
By sporty, do you mean the looks ?
If you want Bridgestone, I guess the "Turanza ER-60" is available at this size.
You can also check out tyres from continental, Apollo Aceleres or the Yokohama A-drives.
PM "Nikhilb2008" and he'll be able to tell you the options along with the prices.
para_7k is offline   Reply With Quote
Old 16th March 2010, 07:39   #215
rk_sans's Avatar
Thanked: 602 Times
I do agree with @para_7k. I also use XM1+ 175/70 R13 and performance is very good. Road grip is fantastic.
rk_sans is offline   Reply With Quote
Old 16th March 2010, 09:21   #216
Yeah, I meant looks...
Will check Turanza too..
Thanks a lot..
Old 16th March 2010, 12:35   #217
Nikhilb2008's Avatar
Thanked: 5,294 Times
Turanza also doesnt look sporty. It will give a worse ride quality compared to the XM1+.
I think you should just go in for the XM1+ blindly.
If you want a sporty looking tyre, then go in for 185/60 r14 Yoko ES100
Old 17th March 2010, 00:01   #218
Absolutely, I dint find Turanza that sporty either..
Nikhil, will the XM1 fit in my i10 stock rims, or do i have to get alloys??
Old 17th March 2010, 00:21   #219
optimist's Avatar
Thanked: 82 Times
Hi Nikhil,
I should have thanked you much earlier for the SSW 6.5J 14" alloys that i picked up. The ES100's are nice also.
There are 2-3 instances that i have heard what seems to be a scrape sound with the wheel arch. But they are when the car goes over the wide humps which are with cobbled blocks at a more than normal speed and once when the left side of the car was passing over a mound of mud on a narrow road.
The 185/60-14" are the nearest to stock dia but are wider. That's why the sound of the (minor) scrape i guess. However there are no marks/cuts/degradations on the tyres due to this.
On the overall, it seems to be a good option.
optimist
optimist is offline   Reply With Quote
Old 17th March 2010, 12:23   #220
rk_sans's Avatar
Thanked: 602 Times
@maverick236,
XM1+ fits in i10 stock rims. You can go for it without a second thought. I am using with stock rims and have done around 10K now.
Old 17th March 2010, 12:35   #221
blackasta's Avatar
Thanked: 996 Times
Originally Posted by optimist View Post
Hi Nikhil,
optimist
My 185/60R14 ES100 used to scrape the front mudflaps (OEM) at full steering turn. I took out the two front mudflaps and now they are ok. Guess in monsoons I have to find thinner (albeit uglier) mudflaps for both front and rear.
Old 17th March 2010, 13:45   #222
para_7k's Avatar
Thanked: 63 Times
Originally Posted by rk_sans View Post
@maverick236,
175 section tyres on your stock rims . The stock rims are 4" and fitting 175s on them is totally unsafe.
175s require a minimum width of 4.5". Do take a moment to check this out.
Tire Size Calculator - tire & wheel plus sizing
@maverick236, Please do NOT fit 175s on your stock rims. If you cannot spend on alloys, do check with your tyre dealer on sourcing steel rims that are 5J. You could try to get the Hyundai Accent's or Ford ikon's rims.
Old 17th March 2010, 13:57   #223
blackasta's Avatar
Thanked: 996 Times
Yup - do not fit 175/70R13 tires on 4J rims. It is risky.
Old 24th March 2010, 22:32   #224
blackasta's Avatar
Thanked: 996 Times
I got my car's wheel alignment done today, as I noticed thin scrapes of rubber peeling from my right front tire outer edge (checked other 3, there were no issues). The alignment check revealed that there was a toe alignment issue, which was rectified.
The alignment sheet is posted, tire gurus please comment if all is ok.
Hyundai i10 : Tyre & wheel upgrade thread-dsc02411.jpg
Old 29th March 2010, 09:17   #225
keralshobhit's Avatar
Thanked: 21 Times
Hey,
I have a i10 magna 1.1 almost 1.5 yrs old.
After a lot of surfing in this thread i recently got the the footwear replaced.
With i20 alloys and XM1+ 14 inches.
According to the shop guy this combination worked fine.but when a car is going in some bumps sometimes Tyre gets touched and it even makes a bang sound.
I am not able to understand what the reason.
I got it checked and he says back spring have gone down a bit .
i never thought there is any such prob with car.
I will be giving car to Hyundai motor plaza on 1st.
Please advice me further action.
need help
SOS
keralshobhit is offline   Reply With Quote
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 11 12th February 2018 18:49
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
