Old 17th December 2007, 21:15   #16
kpzen's Avatar
Thanked: 1,613 Times
Originally Posted by carZest View Post
I paid 2700 per tyre. Since the stock was MRF, the dealer was OK to give only 1500 per tyre. He said only the esteem and the getz would take 155/80. Moreover the stock tyres were tubeless.
Hope this was an OK deal!
Looks like a fair deal..
kp, could you give all the possible upsizes for the i10?
Sure, Here u go
Stock size 155/80-13
Upsizes
13"
165/75-13
175/70-13
185/65-13
14"
175/65-14
185/60-14
195/60-14
195/55-14
15"
185/55-15
195/50-15
205/50-15
215/45-15
16"
205/40-16
215/40-16
17"
205/35-17
215/35-17
18"
205/30-18
19"
205/25-19
PS: Only upsizes till 14" are advisable...
Old 29th December 2007, 13:01   #17
iraghava's Avatar
Thanked: 154 Times
I was thinking of doing the 175/70 R13 upgrade too on the car but the problem is that the wheel is only 4"!! I don't think I would suggest anyone to fit a 175 section tyre on the standard rim.
Old 31st December 2007, 09:01   #18
Thanked: 45 Times
Default Getz rims?
I have the 175/70 tyres on the standard rim, and know that it is below the minimum 4.5" required, with the ideal width being 5.5". This has been on my mind for the last 15 days, but was waiting for the new year before I can do anything about it!
Some options:
-> I think the Getz Prime 1.3 comes with 175/70 profile tyres, so maybe I can exchange the i10 rims with the Getz rims. If this works, this should be a cheaper option.
-> The dealer has said he should have the company alloys by the 1st week of January. I think this would prove a very costly option.
-> I could also check after-market alloys
Do you think the Getz rims would fit ? Thanks!
carZest is offline   Reply With Quote
Old 31st December 2007, 13:09   #19
iraghava's Avatar
Thanked: 154 Times
Well for that the first thing to know would be the PCD.
KP any idea what PCD the i10 has??
Old 31st December 2007, 13:57   #20
rks
rks's Avatar
With your present set-up the tyre life will come down. The tyres are very wide in relation to the rim width, meaning that there will be much higher sidewall deformation. There is also a danger of the tyres coming off the rims in case you hit a pothole/kerb or in case of under-inflation. So it is advisable to get wider rims as soon as possible.
Some options:
I personally would go for company-supplied alloys. This is the safest, if expensive option. After-market is fine, but you need to find alloys that will be a good fit in terms of PCD and offset, otherwise you may end up with all kinds of problems. I am not sure if Getz rims will fit the i10. My suggestion is to check directly with Hyundai (unfortunately I found that even the authorized dealers know very little about tyres and wheels).
Old 31st December 2007, 15:07   #21
Thanked: 24 Times
Slightly off topic. DOes anyone know what is the rim size of Getz 1.3?
Also the Getz 1.1 (and older Getz 1.3 GLE) come with 155/80. So wud be right for Getz 1.1/1.3 GLE owners to upgrade to 175/70 XM1?
Elito
Elito11 is offline   Reply With Quote
Old 31st December 2007, 16:07   #22
kpzen's Avatar
Getz GLE with 155/80-13 tyres has 4.5j rims and GLS with 175/70-13 has 5j rims.
I think i10 has 13 x 4.5j 100 PCD rims. Will confirm in a day or two.
Old 31st December 2007, 19:43   #23
Thanked: 24 Times
Thanks KP
But the question is will 175/70 be suitable for Getz GLE, GVS? (with 4.5J rims)
Elito
Old 31st December 2007, 20:01   #24
Thanked: 24 Times
Thumbs up Got it!
Michelin India - XM1
Elito
Old 2nd January 2008, 01:37   #25
iraghava's Avatar
Thanked: 154 Times
No Kp, I confirmed this, it has 4B rims.
Old 2nd January 2008, 09:03   #26
Thanked: 45 Times
Default getz rims or alloys
am planning to talk to the dealer today to check if he has the alloys, and how much he is quoting for them. will try talking to the service center to see if the Getz Prime wheels would fit.
@rks: thanks for the advice! am waiting for either the company alloys to reach the showroom (these were not available in December).
@kpzen: did you get a chance to find out about the PCD of the i10? am hoping to get out of the current set ASAP.
@iraghava: what is the difference between a 4B and a 4J rim?
thanks!
Old 2nd January 2008, 15:32   #27
PatienceWins's Avatar
Thanked: 264 Times
carZest
Congrats for the car and good set of tyres.
PatienceWins is online now   Reply With Quote
Old 2nd January 2008, 15:51   #28
rks
rks's Avatar
Hope you get the company alloys soon. Just make sure that the rim width is adequate for your upsized tyres.
Old 2nd January 2008, 17:54   #29
Thanked: 45 Times
Default no luck!
an update: I called up the showroom and he says the alloys haven't come as yet. So that is ruled out.
I went to the service centre and spoke to a couple of people there. They didn't have a clue if the Getz rims would fit. After a series of phone calls, I was asked to talk to their Bridgestone contact. He said "Saab 1/2 inch width kam hain - uska koi problem nahin hoga". Hmm!
So I guess the only option is after-market alloys, unless kpzen/iraghava can find out if the Getz rims would fit perfectly. What would be a good set of alloys (not just the make, but also specific model numbers)?
Old 3rd January 2008, 10:01   #30
kpzen's Avatar
Carzest
Give me a day or two, I'll confirm if the Getz rims fit in i10.
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 10 4th June 2017 10:16
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
