Old 15th July 2010, 15:04   #286
MutantX's Avatar
Thanked: 89 Times
Guys, how much does Hyundai i20 alloy wheel nut cost? ment for set of 20 nuts?
MutantX is offline   Reply With Quote
Old 12th October 2010, 16:48   #287
Hi All,
Do you feel that the steering is tight/hard after upgrading your wheels and tyres? I'm planning to go for 175/70/R13 with some alloy wheel. My wife likes the current light steering in i10. If it is going to affect very badly after 175 tyre then I don't get approval from her. Please let me know your experience.
TIA
automaticfan is offline   Reply With Quote
Old 12th October 2010, 21:00   #288
para_7k's Avatar
Thanked: 65 Times
Originally Posted by automaticfan View Post
Hi All,
TIA
Yes, I did feel a tightness in steering after the tyre change to 175/70.
On the contrary, I liked the tightness it offered especially during lane changes in the highway.
It is not significant but defenitely noticeable.
Alternatively, you can change to 14" and get 165/65 14. But the sidewall height reduces by nearly 15mm and ride will be back bending.
para_7k is offline   Reply With Quote
Old 12th October 2010, 21:16   #289
MutantX's Avatar
Thanked: 89 Times
well, i would suggest 185/60 R14 which is a perfect upsize for the stock 155/80 R13. I have been having them on my i10 for the past 4-5 months and the handling/cornering has been much better than the stocks.
Old 13th October 2010, 19:14   #290
This is the main reason I want to upsize the stock tyres but I'm concerned about the steering. How is your experience with 185/ 60 R14. Is the steering harder by about 25% after upsize? If it is that much then it okay anything above 50% is no-no.
I know percent is not the best way to measure the steering comfort but I'm looking for the difference before and after because my wife is very particular on that.
Old 13th October 2010, 23:09   #291
kpzen's Avatar
Thanked: 1,655 Times
I feel 185/60-14 is an overkill for i10.
A friend of mine, got the same wheels and now he's struggling to get anything more than 10kmpl..
Anyone else having the same issue ?
Shobit or MutantX - pls share your experience.
Old 14th October 2010, 10:01   #292
Thanked: 712 Times
check with 'Tejas@perioimpl'. His i10 has been sporting this tyre upgrade for more than a year. Tejas was very vocal during initial months of purchase due to low mileage, though his i10 (used mainly by his father) has/had low daily usage.
sukiwa is offline   Reply With Quote
Old 14th October 2010, 10:16   #293
MutantX's Avatar
Thanked: 89 Times
Well, to be frank with you i10's 1.2 kappa's mileage hasnt been great before & after the upgrade. My car has run just 1300 kms hence cant comment on the mileage. I am getting 10kmpl as of now in city B2B traffic conditions. The driveability has improved a lot and so is the road grip. Get either michelin or yoko a-drive as there is surely a reduction in road noise when compared to the stocks.
@automaticfan: 185 60 R14 profile tyres are a good upgrade. I have been many i10s upgraded to these profile tyres. The steering isnt tight *atleast for me*.
I guess tbhp tyre gurus would be able to answer your question much better.
Old 14th October 2010, 14:16   #294
Thank you all for your inputs. Yes, I'm planning on Micelin XM1+ for the tyres. Will there be significant drop in the milegae if I go with 175/ 70 R13.
Curently, my i10 Auto is giving about 8-9 kmpl depending the AC usage. The shop owners claim that there won't be any drop in the FE if I go with R13 alloys.
Old 14th October 2010, 20:01   #295
blackasta's Avatar
Thanked: 1,226 Times
i10 kappa asta AT - running on 185/60R14 (yoko ES 100) from day 1 (since september 2009)
Clocked around 13K - no issues with steering/handling, or tires touching wheel well whatsoever (light/tight)
mileage - around 12-13 kmpl
Hope the above stat clarifies some issues/queries!
blackasta is online now   Reply With Quote
Old 17th October 2010, 10:29   #296
camon's Avatar
BlackAsta,
Can you please let me know the braking experience in your car. I heard from some of the articles in this forum that up-sizing will impact the braking efficiency especially in rainy season.
Since you have changed your footwear from the day1. Might be you have not experienced the difference b/w stock shoes handling and braking part. Isn't it correct me if I am wrong.
Camon
camon is offline   Reply With Quote
Old 18th October 2010, 07:00   #297
blackasta's Avatar
Originally Posted by camon View Post
BlackAsta,
Camon
I never faced any problem with braking - be it rainy, dry or winter.
Don't think there would be any braking problems involved if the upsized tires are of good quality.
Old 18th October 2010, 08:05   #298
Mi10's Avatar
Thanked: 1,459 Times
I had 185/60/14 for about an year and i was getting consistently around 11.5 to 12 kmpl.
Its not about the size, but the engine itself seems to be running optimum only if you shift at ~ 2.5K
I ve experimented at almost all rpm's right from 1.5K till 3.5K
THe best figures recorded were from the times when i shifted just in between 2-3K rpm
BlackAsta,
Camon
The braking will be the most improve aspect after you upsize your rubber to better quality ones.
Get the ones that Black Asta or Mutant X is having.
I was running ES 100, thought they were great in rains, they add more noise to an already noisy car (read as tire/road noise)
Mi10 is offline   Reply With Quote
Old 18th October 2010, 12:14   #299
camon's Avatar
Got the point Mi10.
Once I return to India, will gonna change my footwear. Will catch you for alloys suggestion.
Camon
Old 19th October 2010, 13:49   #300
Dieselite's Avatar
Thanked: 116 Times
Hey,
I've upgraded to 175/70 R13 with Continental tyres and i'm loving every bit of it !
check the pics below. I hope its okay to upload these pics here again? Mods please edit this post if its not okay.
Hyundai i10 : Tyre & wheel upgrade thread-14.jpg
Hyundai i10 : Tyre & wheel upgrade thread-15.jpg
Dieselite is offline   Reply With Quote
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 11 12th February 2018 18:49
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
