Old 17th October 2014, 12:37   #526
blackasta's Avatar
Thanked: 1,225 Times
185/60 14 tires on i10 leaves a hairline gap between mudflaps and tire on full lock in my car. I had no oem front mudflaps from 2009 to 2014 for this very reason. Finally could not take the wide spray no more, and fell for fitting thin faux sparco mudflaps.
blackasta is online now   (2) Thanks Reply With Quote
Old 17th October 2014, 12:53   #527
RSR
RSR's Avatar
Thanked: 4,549 Times
Default re: Hyundai i10 : Tyre & wheel upgrade Thread
Originally Posted by eyesice View Post
It's been one month since I have upgraded to 185/60 R14. Since yesterday, I hear a creaking sound ( something like an old rusty door getting opened ) from the front-left portion of my car when I take turns. If I turn the steering wheel when the car is in stand still, there is no sound.
On a flat road, even at high speeds, the sound is not audible.
I think it occurs when the weight shifts between the left and right sides when taking turns.
Your thoughts on this issue guys?
There are two possibilities here. One - it could be the mud flaps as mentioned by blackasta.
Two - if that's not the case with your car, then it's probably got to do more with the wheel's offset or ET, than with the 185/60R14 tyres themselves.
Your 14" wheels may have a slightly more positive offset than is ideal for the i10, which results in the tyre scraping against the inner wheel well during a turn. This would be felt only when the car is moving because of the weight shift, just as you mentioned.
On the other hand, blackasta's 14" wheels seem to have a slightly more negative offset which causes no problems on turns, but which makes the tyres protrude out slightly causing mud to splatter on the car's front fenders. He has controlled this by fixing after market mud flaps.
This page offers a simple explanation on wheel offset:
http://www.raceandroad.com/technical...el-offset.html
RSR is offline   (1) Thanks Reply With Quote
Old 17th October 2014, 13:29   #528
eyesice's Avatar
Thanked: 62 Times
Thank you very much for the explanation. If my wheels may have a positive offset, will this affect any of the wheel or other components in the long run? Is there anyway to fix them?
eyesice is offline   Reply With Quote
Old 17th October 2014, 13:53   #529
RSR
RSR's Avatar
You're welcome.
Unless your wheels have a H-U-G-E offset difference, there should be no problems with the wheels or any suspension component in the long run.
If it's the alloy wheel offset that is indeed causing the tyre scraping issue, then it only seems to be a minor offset difference on your car. This should not lead to any other problems.
Are you sure it's not the mud flaps that are getting scraped on turns? You can remove the front ones temporarily and drive the car on turns to check if if they are the ones fouling with the tyres.
Only once this has been ruled out, you can be sure of the offset issue causing the problem. There are three solutions in that case -
1) use different wheels of suitable offset with the same 185/60R14 tyres, or
2) use different sized tyres with the same wheels, or
3) use wheel spacers to negate the offset.
Wheel spacers are most commonly used to ensure that a particular set of wheels will fit properly on a vehicle if the wheels have the incorrect offset. If wheels interfere with suspension components or body work in the inner wheel arches, then installing a set of wheel spacers may solve this problem by locating the wheels further away from the body work. On the other hand, wheel spacers can potentially cause interference issues since they may locate the wheels closer to the fender lips and body work around the fender openings.
RSR is offline   (2) Thanks Reply With Quote
Old 19th October 2014, 08:49   #530
eyesice's Avatar
Thanked: 62 Times
You're welcome.
Thank you sir. Will definitely check this and post the observations.
eyesice is offline   (1) Thanks Reply With Quote
Old 19th October 2014, 21:24   #531
Stanher's Avatar
Thanked: 1,694 Times
Would like to know what make these alloys are and how much a set would cost. Sorry but couldn't take any better pics. Car had moved away by then!
Hyundai i10 : Tyre & wheel upgrade thread-10661769_10152591578982670_9041684605355788528_o.jpg
Stanher is offline   Reply With Quote
Old 23rd October 2014, 19:44   #532
eyesice's Avatar
Thanked: 62 Times
You're welcome.
Turns out the mud flaps were indeed the culprits. I took them to tyre store and slightly adjusted the tyres and now the sound is gone. Thanks again for all your inputs
Old 24th October 2014, 10:47   #533
Thanked: 641 Times
Friends, need a suggestion. One of my friend looking for replacing his Hyundai i10's tires. He has some neck pain related issues. Which would be the best product available considering his health condition.
MaxTorque is offline   Reply With Quote
Old 24th October 2014, 16:13   #534
RSR
RSR's Avatar
He must not compromise on the ride of the car, and choose tyres which offer the best ride quality.
I would advise him to stick either to the stock size of 155/80R13 or choose 175/70R13 tyres. 14" wheels and tyres with less sidewall would worsen the ride quality. If he is upsizing to 175/70R13 tyres, then it's recommended to change the wheels as well, for the stock 4Bx13 rims are too narrow for these.
Considering the above factors, it would be best to stick to the stock 155/80R13 size, and go for tyres which offer the best ride in this size. Softer compound tyres offer good ride comfort. Please tell him to avoid hard compound tyres.
From my experience, the Michelin Energy XM2 is an excellent tyre overall, for it is very silent and offers very good ride quality, lovely road grip and effective braking performance. Despite being made of a softer compound, it's a pretty tough tyre overall. The only downside is that it is a bit expensive comparatively.
I replaced two stock Bridgestone B250s (that had worn out/got damaged) on our i10 to Michelin Energy XM2s over a year ago, based on the recommendation of tyre guru Nikhilb2008. They have been awesome so far, and the difference is very noticeable in terms of road noise and ride quality. Two more stock B250s have almost worn out now, and I'm planning to replace them with XM2s as well.
I'd recommend the Energy XM2 despite them being costlier compared to most other tyres. Softer compound tyres like Amazer 4G from Apollo should also offer good ride quality in this size at a lower price.
I hope your friend ensures the correct air pressure is always maintained in his tyres. I've found that Hyundai's recommendation of 33 psi is on the higher side. 29 psi or 30 psi offers much better ride quality on the i10.
Old 24th October 2014, 18:11   #535
Thanked: 641 Times
Thanks for the suggestions mate. I will communicate the same to my friend.
MaxTorque is offline   (1) Thanks Reply With Quote
Old 9th December 2014, 11:34   #536
My i10 has run over 65K kms in 7 years with the original Bridgestone tyres. So finally I have decided to get them replaced.
Checked with Tyre Empire in HSR layout.
Bridgestone b250 is Rs 3500 and Falken is running an offer of Rs 2700 per tyre.
Can you please suggest if Falken would be a good choice if I can save 3K ?
avinfine is offline   Reply With Quote
Old 9th December 2014, 19:18   #537
I got Michelin Energy XM2 175/70R13 based on the inputs from the dealer. Will there be any problems? as I have 13" wheels.
Old 10th December 2014, 20:12   #538
RSR
RSR's Avatar
Bridgestone B250 is strictly an average tyre, but priced rather high. These were the factory fitted stock ones on our i10 too and they are quite average in terms of performance, but they seem to be pretty tough and long lasting. Bridgestone is in the process of phasing out the B250 and replacing it with its successor, the B290.
There aren't many reviews for the Falken Sincera on Team-BHP since Falken has entered the Indian market only recently. I think it should be a decent all-round performer and a good value-for-money product, but I have no idea about its toughness or longevity.
I guess this doesn't matter since you've already purchased Michelin Energy XM2s - these are superb tyres in my opinion.
175/70R13 is an ideal upgrade size for the i10. The only thing is that wheels of at least 4.5" width are recommended for this size (the i10's stock factory steel wheels are of 4" width). However, some members are using 175/70R13 tyres with the stock wheels.
Old 18th December 2014, 18:10   #539
I was in a hurry and took the plunge.
So, finally I drove my car all the way long till Bijapur and returned Bangalore. The drive was awesome, was regretting why I didnt change tyres early.
Totally satisfied with the tyres
avinfine is offline   (1) Thanks Reply With Quote
Old 15th May 2015, 15:58   #540
hrbheda's Avatar
Thanked: 42 Times
Hello all. Sorry for my ignorance but i haven't gone through the whole thread only parts of it.
I own a 2010 i10 Magna 1.2. It is still on the stock tyres
(B250 & 155/80 R13 & 4J steel rims)
All 5 of which are now due for a replacement.
I do want to upgrade them but do not want to change my steel rims.
Hence my query - which size should I use? Should I use the recommended size or something else which will fit the 4J rims?(please guide me as to which size other that stock will fit on the steel rims)
I'm more inclined towards Michelin but it makes only the stock size that fits my rims. Other sizes made by Michelin wont fit my steel rims. I'm want to avoid JK and MRF.
Budget- max rs 4500/tyre or ~ 23000 for the set , excluding balancing and alignment.
hrbheda is offline   Reply With Quote
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 11 12th February 2018 18:49
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
