Old 21st April 2009, 06:05   #91
jango's Avatar
Thanked: 19 Times
There are quiet a few threads running on the same. Pls refer to the below links for more suggestions.
http://www.team-bhp.com/forum/tyre-a...ze-alloys.html
http://www.team-bhp.com/forum/tyre-a...es-alloys.html (i10 took delivery and upgraded with new tyres and alloys)
jango is offline   Reply With Quote
Old 21st April 2009, 09:30   #92
Thanked: 564 Times
@ kpzen:
As far as I know, i10 rim specs are 13x4B.
Has hyundai changed it recently or for i10 Kappa?
@ nareshtrao:
It's better to avoid 15" wheels on i10.
sukiwa is offline   Reply With Quote
Old 21st April 2009, 10:00   #93
nareshtrao's Avatar
Thanked: 337 Times
Default Wheel upsize calculator
Folks,
Thanks indeed for all your reponses.
185/60 R14 is the best match. The difference is only -0.1%.
Current Circumfrence - 1816.47
New Circumfrence - 1814.58
i10 original wheels are 4.5J and 100 PCD. With 185/60 R14, the wheels required are either 5.5JJ or 6J.
both i10 1.1 and 1.2 have same wheels.
Here is a link to the calculator for those who do not already have it.
Car Bibles : The Wheel and Tire Bible Page 2 of 2
nareshtrao is offline   Reply With Quote
Old 21st April 2009, 18:18   #94
185/60r14 does seem to be the right upsize on paper but how applicable is it actually on the car?
Realistically speaking its more on a car to car basis. I have had couple of complaints in the past about 185's on 6 j rims scraping on the sides of the body but we have also fit 195/50r15 on 6.5 j rims without any problems of any sort.
I would say you opt for a 5.5j wheel with a 185 to be really safe but the problem is you will have very limited option of wheels, all the imported ones are mostly default 6 j
Aura should be available in 5.5 j.
nithin.g.balaji is offline   Reply With Quote
Old 21st April 2009, 22:44   #95
Tejas@perioimpl's Avatar
Thanked: 5,064 Times
Nithin, i have also upsized to 185/60/14 without issues. See pics and detailed review here:
http://www.team-bhp.com/forum/test-d...of-review.html (Got a black eye! i10 AT Asta (Kappa engine) With Sunroof Review)
Tejas@perioimpl is offline   Reply With Quote
Old 21st April 2009, 22:48   #96
nitrous's Avatar
Thanked: 283 Times
IMO, 175/65/R14 is the best size for the i10.
Optimum bling. Optimum Ride quality. Optimum FE.
Old 30th April 2009, 22:59   #97
nareshtrao's Avatar
Thanked: 337 Times
Default Offset of i10 Wheels
Folks,
I have a query. I am unable to find the offset of i10 wheels anywhere in print. What is the offset that we get on 155/80 4J wheels and what should be the offset for 14" upgrade?
The sample I tried was sticking out over "1 and half inches" out of the car body with Yoko A drives. It looked so bad that I asked the guy to remove and fit original wheels back.
Which are best 14" wheels for i10 that can take 185/60 R 14? What should be the offset?
Any advise would be appreciated. Thanks.
Old 3rd May 2009, 17:06   #98
godog's Avatar
Thanked: 12 Times
Originally Posted by nareshtrao View Post
Folks,
I second this query. I don't want 195s that stick out like it is 1999.
godog is offline   Reply With Quote
Old 16th May 2009, 00:07   #99
Infractions: 0/1 (10)
hey team,
I'm absolutely disatisfied with the stock rubber on my i10 and even though I've run 9K, still want to just get rid of it. I've around 17K budget(CANNOT GO ABOVE THAT, I"M MERELY A STUDENT). Please suggest me the
Tyre + Alloy combo I can get in this budget. (READ: TOTAL BUDGET= 17K)
Will I be able to get 175/65 R14's in this budget? Won't go for cheap alloys just because they are cheap. I'm a sucker for warranty and quality.
cheers
bharti22shresth
bharti22shresth is offline   Reply With Quote
Old 16th May 2009, 00:34   #100
godog's Avatar
Thanked: 12 Times
Originally Posted by bharti22shresth View Post
hey team,
Sailing the same conundrum boat, aren't we? 17k may afford you either a good set of shoes or decent alloys.
eg HR's 14" Hyper Silver stands at around 14.5k for a set of four. Shoes will be around 3k a piece.
My bet is placed around a stock getz rim+ decent tires mix, which should come around the desired price point. The other option is to wait and wear the current set out, and go all-out on 15" 195s.
Old 16th May 2009, 01:02   #101
Oh darn! I did 9K in a YEAR! Even if I wait for another 2 years,the rubber would still have something! I hate this wait game. C'mon HR, don't you need to clear some of last year's stock. Some team-bhp discount, something!!
Old 16th May 2009, 07:52   #102
Thanked: 101 Times
Hello everyone. It will be a few weeks until I get an i10 AT. Have read probably every forum and page that is on Team BHP regarding the same and have learnt a lot.
The wheel specs I have gathered are: 4D X 13” ET 34
To start with, are the above wheel specs correct?
Can I use 14” Steel Rims of other cars with width greater than 5.5”?
Is the PCD and offset of the Getz steel rim the same as the i10?
Bigger steel rims will be heavier. Will this effect car performance; pickup, fuel efficiency?
I spoke to Saifee tyres. They say best upgrade on stock rims is 175/70/R13. While I am ok with that as circumference difference is -0.52%, my main concern is that all tyre manufacturers recommend rim width grater than 5.5 for this size as well. Saifee says this will not foul tyres but I am sceptical.
Request your inputs & experiences
I asked the Hyundai dealer on the cost of the i20 alloys. He told me 12,000 per piece! I found that difficult to digest. I will be unable to afford alloys at this time.
I have my first post very long I know, but it’s all due to the education I received from you posts. Would appreciate any help.
NevGin is offline   Reply With Quote
Old 20th May 2009, 18:00   #103
Thanked: 101 Times
Dear all. Had a concern: Should I ever face a problem, would any of my warranties (mostly on the suspension) be void because of my change to alloys and upgraded tires? Need your advice please as after I have read the problems on the Skoda forums, I am rethinking my decision to change the footwear.
Post EDITED since it contained various [FONT], [COLOR] and [SIZE] tags.
Posting with such text formatting should be avoided on Team-BHP as it is inconvenient for members to read post.
Kindly go through Announcements section before proceeding.
Thanking You for your anticipated co-operation
The Team-BHP Support
Last edited by Jaggu : 20th May 2009 at 18:56. Reason: Please use preview before posting, also use note pad instead of word for offline typing to avoid this issue. Thanks
Old 21st May 2009, 10:26   #104
nareshtrao's Avatar
Thanked: 337 Times
Yes. Your warranty on suspension would be void "technically'. However, if you develop a decent relationship with the the Service Center personnel, they may not raise an issue. But it again depends on what kind of damage you have (if any) due to modifications.
Old 24th May 2009, 08:28   #105
Thanked: 101 Times
Default Alloys offered by Hyundai
Went to Motor Plaza, Parel. They have 3 types of 13" alloys. Wanted to share details about them:
All alloys sourced from Aura.
Available in 13" X 5J
PCD: 100
ET: 2 of them were 40, the third was 46
Cost: Rs 14,200 for a set of 4
On the Aura catalouge numbers are: D6350, A8350 & C9350
Apparently there is a worker strike at the factory and hence limited stocks.
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 10 4th June 2017 10:16
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
