Old 20th March 2006, 23:54   #1
kb100's Avatar
Default Upsize Advice - Accent CRDi
Fellow BHPians..
I have been going thru the various threads on this forum and have not found a specific solution to my combination of issues - hence this thread!
I have an Accent CRDi (that just got kitted out with the Petes Box by our Turbo India himself!! )
My car rides on 195/60 R14 Michelin MXF Sports on HR 8 spoke alloys 6-J rims
- These tyres have rrrreaaalllly lasted!.. but down side - Harsh ride - good only on smooth tarmac roads, very scary if one wheel needs to be dropped onto the shoulder at speed, and crazy ROAR (tyre noise! ) Wife complains she can feel every pebble/indentation on the road! The steering effort has increased for sure - but I kind of like the security of the feedack(steering) that these tyres give! Milage might have sufferd a km or two - I still get 18 on the higway (before Pete-ing).. Have a feeling initially it was more.
I am now due for a tyre change - My rims are 8 holed ones I have had the problems of a slight shudder between 100 -120 kmph etc which other threads in this forum have attributed to "PCD & Offset". I would like to know the following
1. What is the PCD and offset for this size'd rim on an Accent?
2. How to deduce these on this/any other rim.
3. Is a 6J rims better or should I go for a 6.5 J rim in 14".. less flex, better cornering stability? - what are the downsides if any? (Tolerance according to http://www.tongseng.com.hk/Page/Product/G3.html#14inch is apparently 5.5 - 7.0")
4. Are FORGED alloys available in India - I am told these are marginaly more expensive than aluminium alloys - but lighter! (steering effort!)
5. What is a tyre to use - Bridgestone G3/Yokohama AVS100/Dunlop Sp9000/ Pirelli 6000's? I see a lot of nice things on the forum about the Yokos - - I do a lot of highway - roads are a mixture of good highways (becoming rarer and rarer) and some very rough state highways. And YES - it RAINS BIG time in Kerala! Do not want to compromise on Grip, Handling & Ride. Rough road manners/ Low noise will help - and yes the tyres should at least last 35+k under the above mentioned "normal" conditions. (dont want any of the soft compounds - I have a nose heavy diesel!)
Pls help @!!@
kb100 is offline   Reply With Quote
Old 21st March 2006, 00:36   #2
kpzen's Avatar
Thanked: 1,598 Times
Harsh ride...better cornering but dont go beyond 6.5J ...... Heard cases of rims coming off while fast cornering....
ps. U didn't have pete's box during the meet right??? Great if u have got it done
Old 21st March 2006, 15:35   #3
kb100's Avatar
Thanks KP...
ALL ALLOY 'n TYRE GURUS... Pls HELP!!
Old 22nd March 2006, 12:25   #4
nitrous's Avatar
Thanked: 282 Times
For tyres,i'd suggest Dunlop FM901s.
Our member '5u3zero' has them on his Palio GTX and after the track experience,i'd vouch for them. Check his gallery.
Don't go for the V-treads like EagleF1s or Yoko ES100s since they're not meant for broken highways.
Old 22nd March 2006, 12:58   #5
jkdas's Avatar
Thanked: 1,389 Times
he bought one after a test drive and has it on 18+7bhp setting. Let God bless/help the un-petefied cars and others.
Old 22nd March 2006, 13:06   #6
PJSPEED's Avatar
Originally Posted by kb100
Fellow BHPians..
Pls help @!!@
Recently i have sold a Forged Billet alluminium wheels ....Very expensive !!!!
PJ
PJSPEED is offline   Reply With Quote
Old 22nd March 2006, 16:22   #7
kb100's Avatar
I DId... very interesting looking tyres!!!
Nitrous... Can you elaborate a little bit (in fact LOTS ) on your track experience with these tyres??
Old 23rd March 2006, 09:56   #8
nitrous's Avatar
Thanked: 282 Times
They were like 'quickfix'.
The dunlops glued the GTX onto the track. They did squeal at tight corners ,but not a single hint of traction-loss.
I was IMPRESSED!!
Old 23rd March 2006, 21:20   #9
kb100's Avatar
.. SIGHhhhhh..... You bring a problem to the Forum... and you walk away with MORE options!!!
Old 24th March 2006, 20:25   #10
ScarySkulls's Avatar
Thanked: 19 Times
Shouldn't going up in rim size help making the gearing taller.
I mean that that should be done. Right..???
I remember it hitting rev limit in top gear on a highway run.
ScarySkulls is offline   Reply With Quote
Old 24th March 2006, 21:03   #11
S@~+#0$#'s Avatar
Thanked: 37 Times
Forged rims are available in India. Have a look at the 2006 HR catalogue, you'll find around 5 wheel patterns of a brand called Magline which are marketed by HR. The rims are excellent and quite light compared to the regular HR/League wheels. However, they are available in 15 inch and above are available. They are priced slightly higher than the HR range but I feel they are well worth their price.
S@~+#0$# is offline   Reply With Quote
Old 24th March 2006, 21:19   #12
kb100's Avatar
>.. And wonder if 205/55's in 15" will scuff... have to ask Drifter that - I think he uses SP9000's of the same size..
Old 24th March 2006, 21:47   #13
kpzen's Avatar
I think he uses 205/50 not 55....with SP9000 rubber
Old 24th March 2006, 21:53   #14
kb100's Avatar
Yup!!.. You are right!... DRIFTER _ YOUR INPUTS PLZ!!!
There are a few ppl here promising me to get me forged alloys in 14"... got to be careful with these claims- met three shysters yesterday alone!!
Old 24th March 2006, 21:55   #15
kb100's Avatar
And the tyre... I need some alternative to the 901's
Lancer DIESEL/ Accent DLS/Accent CRDI ForeRunner Sedans 28 20th June 2011 18:19
Max tyre upsize for Accent GLS. Prithvi Tyre & Alloy wheel Section 6 25th November 2006 11:24
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
