Old 9th January 2013, 23:34   #16
rajeev k's Avatar
Thanked: 1,730 Times
Default Re: Excessive Tire Noise
Originally Posted by SafeDrive View Post
J
The car is just a few months old and has travelled only around 4k km. Could someone please help on this?
Check wheel bearing condition and the tyres for any unbalance.
rajeev k is offline   Reply With Quote
Old 11th January 2013, 11:30   #17
Santoshbhat's Avatar
Thanked: 3,009 Times
Just drove down from Trivandrum to Chennai on a Laura TSI. When the car crosses 100 kmph, there is a howling noise coming from the tyres. It sounds like a train honking behind you. This however is not consistent:
1. I did not have this problem when driving to TVM from Chennai
2. This did not always happen on the return trip. Only sometimes
3. I have had this once before ata round 140 a few months back
If the noise is not consistent it is not tire noise.
Bearing noise on such a new car is unlikely. This noise too would be consistent.
Check for any pebble stuck in between the brake rotors and brake pad housing. Better get it checked ASAP as your car must be in warranty. Skoda's warranty policy is funny. If they can prove that you drove around with the problem for a long time without reporting, they can deny your warranty claims.
Santoshbhat is online now   Reply With Quote
Rumour: Renault stops Kwid production due to engine problems (excessive noise) Chillout The Indian Car Scene 13 19th May 2016 21:06
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
Cabin noise at cruising speed (120) excessive or normal MB-Sting Technical Stuff 4 12th February 2009 11:44
Need Help : Excessive tire wear problem in Swift VXI Jan 06 D1ISTHE1 Tyre & Alloy wheel Section 21 9th November 2007 00:01
