Old 20th October 2017, 20:00   #226
Leoshashi's Avatar
Thanked: 15,901 Times
Default Re: Maruti 800 : Tyre & wheel upgrade thread
Originally Posted by johannskaria View Post
Hopefully Zen rims fits in perfectly without any issues.
The Zen 13 inchers are readily available. Saw them on display a few days back.
Maruti 800 : Tyre & wheel upgrade thread-20171013_185751.jpg
Leoshashi is offline   (8) Thanks Reply With Quote
Old 9th November 2017, 21:16   #227
Maverick79's Avatar
Thanked: 569 Times
Pals,
I lost roundness of my '98 M 800 rear LH tyre.
There is a very evident wobble even at speeds as low as 50kmph.
Need guidance/ help in restoring it, if possible.
Thanks in advance.
Maverick79.
Maverick79 is offline   Reply With Quote
Old 9th November 2017, 21:38   #228
Leoshashi's Avatar
Originally Posted by Maverick79 View Post
Pals,
Thanks in advance.
Maverick79.
Check tyre, rims, bearings and finally suspension in that order.
Leoshashi is offline   (6) Thanks Reply With Quote
Old 9th November 2017, 21:57   #229
saket77's Avatar
Thanked: 5,170 Times
Pals,
Thanks in advance.
Maverick79.
Swap rims and check. Most likely a bent rim. Or if the car remains stranded for long, it could be a flat spot on the tire, but first check the rims.
Saket
saket77 is offline   (5) Thanks Reply With Quote
Old 13th November 2017, 16:39   #230
Maverick79's Avatar
Thanked: 569 Times
Saket
Thanks Guys.
Jacked up and found the tire is the culprit. Bearings were pretty smooth Suspension too was responding normal with a slight push from top of C/D Pillar.
When rotated with hand, the asymmetric profile is clearly visible. Also, the most possible cause was the vehicle was standing for two months before I drove to Chennai without being driven( could see the flat spot). Family were only cranking it leaving it for few minutes once a week to ensure the battery is not dead.
Now, here is the actual questionnaire to all the tire experts,
1. Is it possible to get back the tire to its original shape?
2. If so, will the tire repair guy be able to restore it?
3. Pls share any earlier experiences and associated costs for the same.
Thanks in advance.
Maverick79
Old 13th November 2017, 17:39   #231
saket77's Avatar
This is not conclusive. This symptom can point to a bent rim too. Not saying that this cannot be the tire; you might have diagnosed it perfectly but before going to the remedy, lets be sure of the cause first.
However, some flat spots on tires can vanish after running a few kms. Some prefer inflating it more than usual and then using it for a few hundred kms, but then this has its own disadvantages in terms of compromising road grip and more wear and tear of suspension components.
Saket
saket77 is offline   (3) Thanks Reply With Quote
Old 24th November 2017, 10:53   #232
pedrolourenco's Avatar
Thanked: 634 Times
Take a look at these wheels. It looks like the stock wheels have been modified t take wider tyres. Does anyone have any information on what modification has been done.
Maruti 800 : Tyre & wheel upgrade thread-22254857_841016752725540_1377231926676936718_o.jpg
Maruti 800 : Tyre & wheel upgrade thread-23844685_865482453612303_4793604557620549151_n.jpg
pedrolourenco is offline   Reply With Quote
Old 24th November 2017, 12:26   #233
Leoshashi's Avatar
Yes, it's a separate industry in God's own country.
They ask for your stock rims(or 13 inches Zen's rim) and play around with its width, offset etc for that bulging look.
Leoshashi is offline   (3) Thanks Reply With Quote
Old 24th November 2017, 14:37   #234
Thanked: 634 Times
Thanks. Can you PM me the details. I'm thinking of a 800 project this vacation. I'm closely reading your 800 thread as well as that of Varun to make a list of stuff to be done.
Alloys for an 800 are almost impossible to find these days.
Old 27th November 2017, 20:37   #235
Leoshashi's Avatar
I don't have the contact details, but remember seeing someone posting them in the same group from where you have taken this pic. Will try to find out.
You do get some alloys in NeoWheels, Plati and Tiara(promoted by Bridgestone)
Shashi
Leoshashi is offline   (5) Thanks Reply With Quote
Old 28th November 2017, 12:40   #236
Thanked: 130 Times
It is a process where the wheels are widened by cutting, adding a steel plate and welding it back together. A high precision process which can be done if one has a lathe and a good arc welding machine.
Thanks Guys.
Jacked up and found the tire is the culprit...
Thanks in advance.
Maverick79
Just drive around for a few days with a 10-15% more pressure than usual. Flat spots are supposed to resolve themselves with use.
Last edited by Rehaan : 28th November 2017 at 15:21. Reason: Merging consecutive posts.
fighterace is offline   (2) Thanks Reply With Quote
Old 23rd December 2017, 23:19   #237
Maverick79's Avatar
Thanked: 569 Times
Finally, was able to spend some time on my ride after a two week break.
Updated to 35psi on that particular LH rear tire. Rest all at 30psi.
Will check after 3rd Jan. Thanks for the tip.
Maverick79.
Old 25th December 2017, 02:32   #238
Thanked: 130 Times
Maverick79.
Maintain equal tyre pressure in all tyres, at least same pressure in an axle. Else you may face handling and stability problems.
fighterace is offline   (1) Thanks Reply With Quote
Old 25th December 2017, 08:15   #239
Thanked: 634 Times
Does anyone know if any company manufactures tyres in the size 165/65/R13 and is it the right upsize for an 800? Earlier it was available in Maxxis MA-V1 but I can find it anymore.
Old 26th December 2017, 10:27   #240
Maverick79's Avatar
Thanked: 569 Times
Hi fighterace,
I am already facing the rear LH wheel shake pretty clearly due to a flat spot in the tire created due a three month long idle standing of my ride.
Now, trying all the ways and means possible to restore the roundness of that tire.
Being it in the rear axle, I don't see any other differences in the movement other than the pre existing vertical jerks.
Right now, its getting its A/C worked upon.
Will keep this thread posted on the improvements from tire if found.
Maverick79
Maverick79 is offline   (1) Thanks Reply With Quote
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 398 20th August 2018 00:26
Maruti Suzuki Alto : Tyre & wheel upgrade thread abhibh Tyre & Alloy wheel Section 364 12th July 2018 11:34
Maruti Ciaz : Tyre & wheel upgrade thread sandeep959 Tyre & Alloy wheel Section 28 30th December 2017 17:33
Maruti Alto 800: Wheel & Tyre upgrade ariendj Tyre & Alloy wheel Section 7 24th July 2017 10:45
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
