Old 24th August 2009, 14:36   #121
gpa
gpa's Avatar
Thanked: 282 Times
Originally Posted by sanjaykk View Post
With the earlier Bridgestones, anything close to 90 feels like the tyres are losing contact with the road.
sanjaykk,
Its great to know that you have gone tubeless. One question though-Which Bridgestone trye did your car earlier run on?
I've used Bridgestone 145/70 R12 (S248s) on my M 800 before I sold it and found the grip levels to be good even at triple digit speeds.
Do let me know.
Cheers,
gpa
Old 24th August 2009, 15:46   #122
Thanked: 182 Times
Originally Posted by gpa View Post
sanjaykk,
Do let me know.
Cheers,
gpa
I had Bridgestone S322 (145/70R12 69S) earlier.
sanjaykk is offline   Reply With Quote
Old 24th August 2009, 17:55   #123
Thanked: 182 Times
Originally Posted by sumeethaldankar View Post
Hey Sanjaykk,
thanks for posting the pics.Your tyres are pretty neat.I think they are taller than my Zigma's which looks underinflated especially at the front.
Your Michelins seem to have given the car extra ground clearance as well and they dont bulge at the bottom the way a Zigma would.
Keep us posted on the perfomance of the tyres .Maybe i could switch to michelin's in the future too
thanks
I'd posted my initial observations here:
I did my Bangalore > Guruvayoor > Bangalore Trip (~950 kms) on these.
Things I noticed:
  • lost respect for small potholes and skinny rumble strips (especially the 'there but not there' varities around Gudalur)
  • cud take the car a li'l beyond 100kmph. With the earlier Bridgestones, anything close to 90 feels like the tyres are losing contact with the road.
  • feel a little lack of confidence on turns at high speeds.
Regarding ground clearance, I guess yes. There is a marginal increase in the ground clearance. But I somehow think that the suspension cancels this effect. Maybe a few more kms of observation will confirm if this is true. I cannot, though, explain the technicality behind this.
Old 19th September 2009, 23:05   #124
para_7k's Avatar
Thanked: 65 Times
Default 145/80 tyres
After some research and going through this extremely informative thread, I installed the MRF ZVTS 145/80 on my M800. I have posted two pictures.
I second Ram's points on the positives and Negatives.
Maruti 800 : Tyre & wheel upgrade thread-post.jpg
para_7k is offline   Reply With Quote
Old 20th September 2009, 00:51   #125
Thanked: 152 Times
Does anyone know what is available in 155/75 or 155/80R12 ?
Trust_In_Thrust is offline   Reply With Quote
Old 20th September 2009, 01:17   #126
Nikhilb2008's Avatar
Thanked: 6,661 Times
Nothing in those two sizes you mention TIT.
Old 20th September 2009, 01:23   #127
Thanked: 152 Times
Thanks .It is so painful to hear this .
Old 18th October 2009, 21:59   #128
Default Michelin XM+performance for Maruti 800
I finally got 145/80R12 Michelin XM1+ for my M800.
Cost 2050/- per type. Filled nitrogen free of cost (otherwise costs Rs. 30 per tyre and Rs. 10 for refills)
Things I noticed:
Hi Sanjay,
How is the performance with Michelin.Read some other post about how fast the tread gets worn out but i think it was with the XM not XM+.I have a 2003 model Maruti 800 with JK radials .4 tyres are which came with the car,one i replaced in 2007 when i had a sidewall burst .Done just 35,000 kms.How do you judge if you need a tyre change.The tread looks good.Will upload a picture of the tyres if required.Last servicing at maruti servicing centre i asked them and they said tyres looked ok but they did not use any tyre tread gauge?? is it the right word...
Checked out the tyre prices at reliance automobile accesories shop at Tolichowki hyderabad.Tubeless they had only Michelin price was 2050 per tyre
with fitting balancing.With tube-Bridgestone:1730,JK 1530,Apollo1485.For the old tyres would give about Rs 400-800 .Do any of the hyderabad team bhpians have any suggestions.Is it mandatory to change your rims when you shift to tubeless.
fergus is offline   Reply With Quote
Old 18th October 2009, 22:34   #129
Originally Posted by fergus View Post
Hi Sanjay,
I have attached photographs of the tyres for your advice
Photographs added
Maruti 800 : Tyre & wheel upgrade thread-img_0106.jpg
Maruti 800 : Tyre & wheel upgrade thread-img_0107.jpg
Maruti 800 : Tyre & wheel upgrade thread-img_0108.jpg
Old 20th October 2009, 21:41   #130
Thanked: 182 Times
Have tried to answer some of your questions inline in bold (I'm no expert! Just user reviews).
Hi Sanjay,
Have not run much on the new Michellins. So cant comment on the tread ware. I just hope it lasts long.
Going by the pictures you posted, your tyres can last few more kms. But to be sure, get ALL TYRES checked at a good dealer. Read somewhere about how you can check tread wear using a coin.
Aah..here it is (Coin Test for Tyre Wear checking).
Depends on the condition of your rims. If there are too many dents/bends on the rim it will need replacement. Rust on the rims is also not good.
M800 steel rims should cost Rs. 750 to 800 per rim.
Old 19th November 2009, 15:44   #131
Thanked: 9 Times
My 1997 Old Model M800 needed a new set of rims very recently due to the Hole in the Rim has rusted and the neck of the tube was getting damaged. I changed 2 Rims used one i picked up from one of the Garage. They charged me 750 including the painting of the 4 RIMS in Silver color. Looks a decent deal.
The car runs on Appollo Amazer from past 3 years and with that tyre covered almost 25000 KM looks . I have event touched 100 kph on Nice Road in bangalore when there was no traffic around . IT doesnt have any issues till now.
I have seen the same tyre brand on some some ACE Carriages
vinu_pm is offline   Reply With Quote
Old 15th December 2009, 19:52   #132
Originally Posted by Ram View Post
Over a Maruti 800 with stock radials, the 80% aspect ratio radials have improved both cushioned ride quality and fuel economy.
It has definitely been a worthwhile upgrade for me.
The taller side walls flex more while cornering, marginally increasing understeer and making you slow down while cornering. I wish the front-end geometry were stiffer, so I intend to install a strut brace across the McPherson towers.
Ram
Hi Ram,
Planning to change my maruti 800 tires.Too many choices and brands have muddled my mind.Currently i have JK 145 70r12 with tubes since 2003 done 36,00 kms .However 1 tyre i had changed in 2007 when i had a sidewall burst.Not had many problems with the stock tires so far
My doubts are
1.If i do change to tubeless do i have to change all 5 .What will be the effect if at any time the car has 3 tubeless and 1 with tubes.
2.If i change to another brand besides JK can the car have 3 tires of one make and 1 of a different make
2.If i change to 145 80 r12 then i guess have to change all 5 tires.Michelin does not have 145 70 r12 -checked with a couple of vendors.Secondly the fitting of the spare tire in the luggage compartment may be difficult
3.after fitting new tires is wheel balancing and alignment both necessary.One vendor will only do fitting and balancing.
pls provide your inputs to help me decide.
Old 15th December 2009, 20:15   #133
Ram
Ram's Avatar
Thanked: 149 Times
At low city speeds, there won't be much difference.
But you must have the same kind and size of tire on both left and right sides of the same axle. If the front tires have dissimilar rolling circumferences, your differential gears will operate all the time leading to increased wear and tear.
Should not be a problem if the tire sizes are the same.
Why not go to a big shop who does everything?
Alignment is certainly necessary, if your geometry is misaligned.
Ram is offline   Reply With Quote
Old 9th January 2010, 20:35   #134
vivekgk's Avatar
Thanked: 433 Times
I changed the tyres on my M800 from 145/70R12 Goodyear GPS2 to Yokohama 165/60R12 A539. There's no noticable change in diameter. The calc says that it's about a couple of millimeters smaller, but no big deal. But they are wider, and I've got them on the stock rims. Will they scrub the inside on full suspension travel? Has anyone fitted these on an 800 yet? Will post pics as soon as I get my cam back.
vivekgk is offline   Reply With Quote
Old 20th January 2010, 23:53   #135
T-Rex's Avatar
Thanked: 19 Times
Hi guys.
I have an 2004 M800 which has clocked 65000 & is due for new footwear. I desparately wanted to upsize the tyres to increase ground clearance & better cushioning over mad roads of Mumbai & outskirts, particularly because when fully loaded the silencer kisses big speed- breakers with ease.
Actually, I want to go in for a 13" Konig alloy with 155/80 R13.
Is this possible & would this be a wise thing.
Your advise is my command wise people.
Peace.
T-Rex is offline   Reply With Quote
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 394 18th July 2018 15:45
Maruti Suzuki Alto : Tyre & wheel upgrade thread abhibh Tyre & Alloy wheel Section 364 12th July 2018 11:34
Maruti Ciaz : Tyre & wheel upgrade thread sandeep959 Tyre & Alloy wheel Section 28 30th December 2017 17:33
Maruti Alto 800: Wheel & Tyre upgrade ariendj Tyre & Alloy wheel Section 7 24th July 2017 10:45
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
