Old 4th January 2013, 08:01   #31
Sankar's Avatar
Thanked: 4,657 Times
Default Re: Replaced No-name alloy wheel nuts with Gorilla wheel nuts.
Originally Posted by babhishek View Post
Hi Sankar,
Any idea of the Swift nut thread sizes?
thanks!
Have replied to your PM but let this be here for others if they're looking.
12 x 1.25
The quintessential question? Safer, but if you lose or misplace the special nut adapter you may be in serious trouble.
Buy and keep a spare one with you.
Old 5th February 2013, 14:43   #32
Chetan_Rao's Avatar
Thanked: 4,357 Times
@Sankar: Did you end up getting a spare key/set locally from Bangalore?
General Update: My set will be a year old in mid-Feb. I recently got my car serviced, and all lug nuts seem to be in good shape. I had to stay around when they unbolted the wheels just to be sure they don't over-torque while refitting.
The nuts are far better than the rust-prone hex-key ones, and I'd recommend them. I myself got them because the OE nuts wouldn't fit the holes in the alloys, and I didn't want to risk open-ended hex-key nuts.
Chetan_Rao is offline   Reply With Quote
Old 5th February 2013, 15:05   #33
Schoudhury's Avatar
Thanked: 470 Times
I also have aftermarket alloys on my car and instead of going for these special nuts i have fitted the OEM nut which comes in the ZDI and ZXI version of Maruti cars. Those nuts cost me around Rs 1100 .
So i will suggest people using maruti cars can look @ this option also .
So I just bought a new L type spanner with detachable head(the kind which tire shops use), and it works fine.?
Sirji.
Please let us know how much did you pay for getting the L type spanner and also from where you got it .
Schoudhury is offline   Reply With Quote
Old 5th February 2013, 15:20   #34
tsk1979's Avatar
Thanked: 16,422 Times
Sirji.
I bought this from a standard auto parts shop on the highway. Cost me around 200rs all inclusive
The big one for the safari cost 270rs all inclusive.
Any spare parts shop has this L spanner with removable head which can be used with aftermarket alloys
tsk1979 is offline   (1) Thanks Reply With Quote
Old 18th February 2013, 23:16   #35
prince85's Avatar
Thanked: 117 Times
I'd appreciate if someone could please help me with the right thread size for the Hyundai i10
prince85 is online now   Reply With Quote
Old 20th February 2013, 20:21   #36
Thanked: 83 Times
Can someone please help me determine the lug nut size for the Tata Safari? The nut tool lists that it is for 19mm nuts. Which Gorilla Lug Nut will I need? Thanks in advance.
SumitB is offline   Reply With Quote
Old 21st February 2013, 12:34   #37
Sankar's Avatar
Its 12x1.5
Check if the vehicle manual has the info in it. If not consult the workshop manual when you go to the service centre, it will have the necessary info.
Wheel locking nuts Samurai Tyre & Alloy wheel Section 66 15th May 2016 22:58
Caution! Rusted wheel lug nuts ece2k2 Tyre & Alloy wheel Section 48 24th June 2015 18:41
Where can i get Alloy Wheel Nuts NFS2024 Tyre & Alloy wheel Section 9 8th September 2009 15:07
Help Required: Procuring Alloy Wheel nuts for Palio (98 PCD conversion) basilmabraham Tyre & Alloy wheel Section 33 12th July 2009 12:40
All the wheel nuts were loose! Has this happened to any one else ? vdiatech Street Experiences 31 23rd May 2009 00:17
