Old 18th April 2013, 17:32   #31
Rehaan's Avatar
Thanked: 25,043 Times
Default Re: CamberTire : Cone-shaped Tyres for High Camber Set-ups
Originally Posted by sujithpnair View Post
Do you think adding details related to CASTER angle may bring more insight to topic?
Here, check this thread out : http://www.team-bhp.com/forum/techni...-smoother.html (Camber, Toe and Castor. Know it now and drive smoother.)
cya
R
Rehaan is offline   (1) Thanks Reply With Quote
Old 20th April 2013, 15:45   #32
delix's Avatar
Thanked: 18 Times
Originally Posted by ImprezaFan View Post
Thanks for the knowledge, Rehaan.
My ritz runs on 195mm tyres and I've always (visually) felt that the rear tyres have a slight negative camber. Have seen this in swifts with >185mm width. Don't know if there is a default negative camber in all stock cars (which becomes prominent with wider tyres). Could somebody please confirm?
Is there a relationship such that (all) FWD cars have rear tyres negatively cambered (or vice versa)? If yes, why?
I can second that. Because after getting alloys in my ritz, i noticed the rear tyres develop a negative camber. Moreover i have noticed a little negative camber in my dzire zdi as well.. I am not sur if this adjustments are deliberately done by the companies.. In the road i have noticed many cars with negate camber ibthe rear wheels specially the i20s, vernas, crv's, swift...
delix is offline   (1) Thanks Reply With Quote
Old 20th April 2013, 18:35   #33
akshay4587's Avatar
Thanked: 1,686 Times
I am in a fix here,my Linea has a certain degree of negative camber,and it is actually more than the specified limits,and i acted careless for 3 weeks by not getting the alignment done,and noticed that front right Tyre has excessive wear on the inner side,after sales guys mentioned something about camber adjustment bolts which are supplied by fiat to fix the camber angle.
Has anyone used these type of bolts?,how do they help,and is it the correct procedure to fix the camber?
Egg shaped tyres ST7677 Tyre & Alloy wheel Section 12 31st January 2011 20:19
Camber Adjustment query & Camber Adjusting Bolts? hell_rider Technical Stuff 18 2nd January 2009 22:43
Pressed paper cone vs non-pressed paper cone sanchits In-Car Entertainment 10 27th November 2007 10:16
