| Tyre & Alloy wheel Section Everything to do with footwear for your car! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hey Guys, Here is he pic of my current wheelies.. ![]() Now I am intrested in switching to low profile rubber (f1 design) I have no idea about the size, few doubts 1) Do I need to change my alloys as well? 2) Will this affect my driving comfort? 3) how much that would cost? Cheers Wadhwa Ajay
__________________ To live is not just to survive, but to thrive with Passion, Compassion, some Humor & your own Style ! |
| | #2 (permalink) |
| Senior - BHPian | What rim size is this, 16 or 17?? 205/40 or 215/35 (lower) on 17inch rims would be low enough profile for delhi roads.... if you want to go lower you can get 215/35/R18 tires but you will need to upgrade to 18 inch wheels as well. Arush
__________________ "I drive a Mitsubishi 3000GT, and I live a 1/4 tank at a time... For those 50kms or less, I'm free." |
| | #4 (permalink) |
| Team-BHP Moderator ![]() | Those look like 15" wheels (or really small (!!) 16"ers). A move to 17"s would definatly improve the looks, but your ride is bound to suffer. But then, Delhi roads are pretty good, so why not!
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| | #6 (permalink) |
| Senior - BHPian | In that case 205/40/R17 would suit your ride best, its low but comofortable enough for delhi roads. Ofcourse not as comfy as your present ones. Go for chrome and yes go for some design which is not so common as the ones you have currently!
| | #7 (permalink) |
| BHPian | hey arush finally I saw my wheelies and shocked to know 3 wheels have 185/70R 14 and one of the wheel in rear has 195/60R14 now wts next? does this means my rims are 14" wt do u suggest shall I change the alloys also?? as you recommended 205/40/R17 can they be fitted on my current alloys?
| | #8 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
In order for you to mount 205/40 R17 you would need 17" rims. The number after the R denotes the rim size in inches for example R17 means that the tyre needs a 17" rim. So yes you would need a new set of 17" Alloy Wheels. And its not correct for you to run 185/70 on 3 rims & 195/60 on 1 rim so please check your spare tyre if its 185/70 then replace it with the 1 195/60 or of it's a 195/60 then replace the one 185/70 in the rear with it.
__________________ There is a very fine line between "Hobby" and "Mental Illness". | |
| | #9 (permalink) |
| Senior - BHPian | iraghava has pointed you in the right direction. You will need to purchase a set of 17inch wheels and tires to fit in your car... 14s damn they look so much bigger in the pic, you fooled me! With 17s your like will definitely look super hot.
| | #11 (permalink) |
| Distinguished - BHPian ![]() | I doubt that would be a problem Ajay but you will have to check that with the steering on full lock either side the tyre does not touch the arch and there should be enough suspension clearance that on mild bumps the tyres should not foul with the arches.
| | #12 (permalink) |
| Senior - BHPian | 195/60/R14 to 205/40/R17 is a difference of +1.1% which is well within tolerance limits (you wont find a more accurate fit). Why i do not recommend anything wider than 205 on your car is for the possibility of scraping on the inside and yes this will retain the original turning radius as well.
| | #13 (permalink) |
| Senior - BHPian | do low profiles do anything except look good? as in do they help performance? i know low profiles really ruin your ride nd all but they can really change the look of a car
__________________ Adhish आधीश् ஆதிஷ் ادهش adhish.wordpress.com __________________ |
| | #14 (permalink) | |
| BHPian | Quote:
__________________ Zeropointeight for me to keep and miles to go before I sleep............ | |
| | #15 (permalink) |
| BHPian | Iam looking at upsizing my Lancer's wheels to 16" wih low profile tires. Since this thread is discussing the same topic, i dint want to start a new thread, hope its ok. Guys tell me if I can upsize the tire size to 16" with low profile rubber without having to modify the suspension the Lancer. |
« CAn I put 15" rims with 50 profile yokohamas on my esteem??
Can Shoe Polish be used as Tyre Cleaner!!! »
| Thread Tools | |
Similar Threads | ||||
| Advantages of Low profile tyres ??? | roopakr | Tyre & Alloy wheel Section | 3 | 30th April 2007 16:13 |
| Which Tyres Are Better? Tubeless Or Low Profile? | 1self | Tyre & Alloy wheel Section | 8 | 29th September 2006 12:48 |
| Plzzz help me i want cool low profile rims for my corolla!!!!!! | turbo dragster | Modifications & Accessories | 8 | 1st May 2006 13:58 |
| Does Low profile tyres reduce the life of suspension? | a4_attitude | Tyre & Alloy wheel Section | 3 | 22nd September 2005 02:45 |
| Pros & Cons of low profile tyres? | satish_appasani | Tyre & Alloy wheel Section | 19 | 17th September 2004 21:39 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
