Old 16th June 2006, 23:53   #1
theMAG's Avatar
Thanked: 1,574 Times
Question Tyre pressures for various performance tyres
Guys,
As some of you might be aware, I've 195/55 R15 Hankook Ventus K102s on my Swift. The tyre pressures recommended by the dealer (Car Shringar) is 30 psi all-around.
I thot I could homogenize this very beneficial(yet overlooked) info into this thread
Q1. What are the tyre pressures you folks follow on similar profile tyres?
Q2. Do you moderate tyre pressures based on usage - for e.g. city vs highway driving (lets assume on tarmac only-no offroading).
Q3. Full passenger load vs single user etc.
Q4. Ideal duration for checking tyre pressures
Q5. Any other usage conditions
Pl pardon any ingenious stupidity from my part for this topic
Old 17th June 2006, 10:08   #2
Rehaan's Avatar
Thanked: 25,043 Times
Hi theMAG,
Thread moved to Tyre and Wheel section
Even though you are trying to homogenize the info.... there are several threads that deal with almost identical information....
You can start by doing a search for "pressure" in the titles of threads...
Thread closed
cya
R
How often should I check my tyre pressures? rajesh1868 Tyre & Alloy wheel Section 73 10th August 2015 19:13
Correct Tyre Pressures Kaizer Sozay Tyre & Alloy wheel Section 83 7th March 2015 19:56
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
tyre pressures for the drag paras211 Tyre & Alloy wheel Section 10 13th February 2007 23:54
Uneven tyre pressures Hells Bells Technical Stuff 8 13th November 2006 15:27
