Old 19th December 2013, 23:44   #1
ariendj's Avatar
Thanked: 83 Times
Default Maruti Alto 800: Wheel & Tyre upgrade
i have booked the Alto 800.
i would like to know the best upgrade in 13 inch tires.
also need to know the PCD and offset since i plan to get alloys along with tire upgrade!
the OEM tire specs are 145/80/R 12
thanks in advance!
ariendj is offline   Reply With Quote
Old 20th December 2013, 00:42   #2
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by ariendj View Post
i have booked the Alto 800. i would like to know the best upgrade in 13 inch tires. also need to know the PCD and offset since i plan to get alloys along with tire upgrade! the OEM tire specs are 145/80/R 12 thanks in advance!
165/60r13 with 5J rims will be the best fit. You can use 5.5J if 5 J isn't available.
speedsatya is offline   Reply With Quote
Old 20th December 2013, 09:21   #3
ariendj's Avatar
Thanked: 83 Times
Default re: Maruti Alto 800: Wheel & Tyre upgrade
thanks.
btw,looks like michelin XM2 tires dont come in that config.
what are my other options in brands?
would 165/65 R13 work?
also any pointers towards PCD ?
Old 20th December 2013, 09:50   #4
speedsatya's Avatar
Thanked: 712 Times
thanks. btw,looks like michelin XM2 tires dont come in that config. what are my other options in brands? would 165/65 R13 work? also any pointers towards PCD ?
for that matter any tire would work. 165/60R 13 or155/65r13 are the right up sizes keeping overall diameter (OD) in mind.
Old 26th December 2013, 13:49   #5
ariendj's Avatar
Thanked: 83 Times
Default Re: Maruti Alto 800: Wheel & Tyre upgrade
PCD for Alto 800 is 100
Have another doubt,will upgrading from 12 inch to 13 inch tires require any additional changes to suspension?
I asked cause my local tire dealer told me that the 13 inchers would scrap the underside!!
Old 20th January 2016, 09:21   #6
suresh_gs's Avatar
Thanked: 1,249 Times
Folks
My friend owns an Alto 800 wishes to change his tyre. The stock size is 145/80 R12. I have suggested the following upgrades as seen in the images below. I have suggested the upgrades highlighted in green color.
The choice narrows down to 155/70 R12 or 155/65 R13. I guess the latter will be recommended.
Even if I suggest 155/70 R12, does it require rim change ie change in rim width ??
Maruti Alto 800: Wheel & Tyre upgrade-alto-image-1.png
Name:  alto image 2.PNG
suresh_gs is offline   Reply With Quote
Old 22nd July 2017, 18:40   #7
nura's Avatar
Can anyone post the ET of the current Alto 800 OEM wheel rim please?
Many thanks in advance.
nura is offline   Reply With Quote
Old 24th July 2017, 10:45   #8
nura's Avatar
Bumping up this thread in the hope of a reply
VW Jetta : Tyre & wheel upgrade thread akhilesh51 Tyre & Alloy wheel Section 139 2nd July 2018 10:05
Skoda Yeti : Tyre & wheel upgrade thread Invinsible Tyre & Alloy wheel Section 484 7th June 2018 13:28
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Got my Nano! Alloy wheel & tyre upgrade suggestions? scooby05 Tyre & Alloy wheel Section 30 19th July 2013 08:45
wheel & tyre upgrade for Innova BikerSG Modifications & Accessories 22 12th July 2007 13:40
