Old 18th July 2014, 02:24   #151
Thanked: 25 Times
I had a side wall tear after hitting a sharp pothole within two days of purchase of my new honda city Vmt shod with bridgestone tyres. My question was would the result be the same if I had upgraded to 3st on the first day.
fastraj is offline   Reply With Quote
Old 7th August 2014, 18:38   #152
Alive2Drive's Avatar
Thanked: 50 Times
Default re: 4th gen. Honda City : Tyre & wheel upgrade Thread
Hi Friends,
I am supposed to take delivery of my Honda City I-dtec VX MT Silver this weekend or early next week. I have already planned a tyre upgrade. My car has come with stock Bridgestone B250 175/65 R15 tyres. I have planned to upgrade to 195/65 R15 Continental Premium Contact 2 Tyres.
The dealer has asked me for a difference of 8K for 5 tyres. Can anyone help and tell me if this is a good deal ?
Alive2Drive is offline   Reply With Quote
Old 8th August 2014, 10:29   #153
loving_alaap's Avatar
Thanked: 9 Times
Originally Posted by Alive2Drive View Post
Hi Friends,
Any particular reason for 195/65/R15 over widely recommend 195/60/R15.
loving_alaap is offline   Reply With Quote
Old 8th August 2014, 11:40   #154
Thanked: 50 Times
Nothing too specific ! I prefer continental tyres and think 195/65 would substantially improve the GC
Old 19th September 2014, 23:20   #155
jesrani's Avatar
Thanked: 99 Times
I have booked VXMT Diesel at Vapi, Gujarat and expecting delivery October end. The SA says all VX models coming to them have been with Bridgestones. Should I change to Michelin 195/60R15? I drive every week on highway, 300kms and balance on some bad roads. Currently using Michelin 3ST on my SX4 and very happy with the tyres. Instead of upsize, can I just change to same size but in Michelin? Is 175 size very bad?
jesrani is offline   Reply With Quote
Old 20th September 2014, 07:07   #156
Thanked: 135 Times
jesrani,
In my opinion, the 195 is better.
Also, if you find yourself navigating bad roads, the Honda is a known low-rider. In this case, you can get yourself 195/65R15 tyres without any need to replace the stock rims.
One of my friends has been using this setup for over 4 years without any ride height complaint or any fitment issues (no dealer/warranty issues either).
Another idea, albeit off-topic, is that I've found most people with Honda's are exceedingly happy with the Honda Assure Package (or whatever else it's called), so you might want to have a look at the options for your purchase. There might be some discounts to be had if you work it out before the car is delivered.
bharatsomany is offline   (1) Thanks Reply With Quote
Old 25th September 2014, 19:36   #157
AmitKumarVinay's Avatar
Thanked: 23 Times
Jesrani,
I changed my stock tyres to the Michellin Primary 3ST 196/60/R15 . I have definitely noticed a considerable difference in the drive quality and I feel a lot safer driving in the highways . Also, I haven't seen any difference or drop in the mileage. I hope this helps, my friend.
AmitKumarVinay is offline   (1) Thanks Reply With Quote
Old 25th September 2014, 22:29   #158
jesrani's Avatar
Thanked: 99 Times
Originally Posted by AmitKumarVinay View Post
Jesrani,
Definitely helps, thanks. Am checking up with dealer on Warranty issues.
Old 30th September 2014, 10:20   #159
adarsh76's Avatar
Thanked: 223 Times
Default Re: Honda City : Official Review
Yes it is but changing the rim size might void the warranty of your car. It might also cause problems with the ABS sensors. Better to stick with stock rim size and upgrade the tyres only.
Raven,
I recently checked with one senior service executive at Peninsular Honda, Trivandrum regarding 185/55 R16 tyres and specifically inquired about the ABS sensors.
What he said, ABS sensor is a magnet based system and it will not cause any difference even if we upgrade to the 16 inch tyres and warranty also won't be void.
I'm not sure on the technical side. These tyres are rare in India, but I may be able to get it imported from a dealer. Why I am keen towards 185/55 R16 is because this is what Honda recommends (indirectly) as these tyres are fitted for the 2014 Honda City in Malaysia and also the Owner's manual is mentioning this tyre size. Speedo error is negligible with this tyre size upgrade and a slight increase in Ground Clearance.
As of now I'm running the stock Good year tyres and planning to upgrade either after 6 months (once free services are over) or once I complete 10000 kms. As of now, I've done exactly 4000 kms.
But, is it true about the ABS sensors which the service guy told?
adarsh76 is offline   (2) Thanks Reply With Quote
Old 30th September 2014, 11:25   #160
RavenAvi's Avatar
Thanked: 33,203 Times
Tyre change, yes. Rim change, no.
It is a sensor-based system which is situated alongside the brake drums, based on calibration with the rims. Changing the rims would need re-calibration of all 4 sensors and calipers inside the wheel mount for correct effectiveness.
Recommended read - http://www.toyotazone.co.za/howitwor...ng-wheel-size/
RavenAvi is offline   (1) Thanks Reply With Quote
Old 30th September 2014, 13:26   #161
adarsh76's Avatar
Thanked: 223 Times
Will the service centers or tyre centers be equipped to do this calibration? From the link, they're not even recommending a tyre size change if vehicle is equipped with ABS.
adarsh76 is offline   Reply With Quote
Old 4th October 2014, 16:01   #162
Thanked: 135 Times
RavenAvi,
Seriously, this is a load of rubbish. ABS systems are designed to run in such diverse conditions that such changes do not affect their operation even in the minutest sense, atleast not when up-sizing tyres/wheels. I do agree that undersized tyres can cause this, but I am quite confident that people that are stupid enough to do so are a near non-existent minority!
Proof, you ask? Look at the tyre pressure sticker on any car from a reputed manufacturer and you will find that even the manufacturer recommends alternative sizes for the same car.
Look further and you will find highly qualified tuners and aftermarket wheel companies providing certified OEM replacement wheels which are entirely different in weight and size. Do you think they would get ETRTO, TUV, MOT or US-DOT certification if they caused the cars safety systems to fail?
Utter rubbish!
adarsh76,
No, ABS systems are not calibrated by service centres or tyre dealers. This needs specialised equipment and highly trained pros who work on designing this stuff!
Besides, you can rest assured that a wheel/tyre change will NOT affect your cars safety systems unless you've really been ignorant enough to UNDERSIZE your tyres (that is to say REDUCED the diameter).
PEACE!
bharatsomany is offline   (2) Thanks Reply With Quote
Old 4th October 2014, 18:08   #163
RavenAvi's Avatar
Nope. Tyre centers are not equipped with re-calibrating machines. All they can do is swap tyres, do the balancing/alignment, and send you on your way. Service Centers usually don't have such machines nor personnel to do such complicated things either.
Quite frankly, if you have gone for extended warranty as well, I wouldn't recommend it. Not only does it risk voiding company warranty, but in the hands of a tyre shop guy with limited know-how, the ABS system might end up getting damaged.
Originally Posted by bharatsomany View Post
RavenAvi,
Utter rubbish!
Getting a bit animated, are we?
There is a reason why car owners are encouraged to stay within a limit of circumference difference (2% or less). Bigger-sized tyres which cause deviation of more than 2% difference can cause ABS trigger-problems, specially if the sensors kick in later than usual. In extreme cases, it might end up nullifying the ABS system altogether.
I know this because one of my friends reported a complete loss of ABS a few months back when his car, a DZire ZXi, spun out of control. He was running on upsized tyres. He never felt the ABS kick in. I am guessing it did kick in, but it was pretty late. Thankfully no one was hurt.
As for the tyre pressure sticker, here's mine from my 2014 Honda City VMT i-DTEC:
4th gen. Honda City : Tyre & wheel upgrade thread-20140406_100511.jpg
Here's one from our Ritz:
4th gen. Honda City : Tyre & wheel upgrade thread-20121227_113002.jpg
One from our Swift:
4th gen. Honda City : Tyre & wheel upgrade thread-20140806_182903.jpg
Same in all 3. No other recommendations other than OEM sizes specified by the manufacturer.
Can't comment on aftermarket tuners, but if they provide certified OEM replacement wheels, shouldn't they be of the same size and weight?
So that means, increasing the diameter by any sort, size, type, profile or width will not mess with the safety systems such as ABS, etc.? Let me try on 245-sections on my 185-sized Swift then, once my warranty period expires. Will report back.
RavenAvi is offline   Reply With Quote
Old 5th October 2014, 13:33   #164
Thanked: 135 Times
I would have to disagree, it would take a really crazy guy at a tyre shop to actually damage anything.
No offence intended, friend.
That is a generalised rule simply to avoid any rubbing/scraping issues. As for the ABS kicking in later, that is actually a good thing, it just means the tires can take more force before they skid/lock-up. The intent of the ABS is simply to prevent a complete lockup to get the best possible braking while still keeping some steering control over the car (even under very heavy braking).
There are likely a million reasons for anything to fail. Not knowing what exactly happened, I cannot say much except that incorrect inflation pressure causes a lot more problems than the upsizes we are discussing. Also, it is a common misnomer that an ABS will prevent any and all skidding. This is entirely inaccurate. Have a look at the picture below showing tyre marks made when coming to a hard stop with ABS.
Name:  ABS Stop  Tire Marks.jpg
One from our Swift:
Here is an option list of wheel and tyre combinations sourced directly from BMW for the 5 Series GT:
4th gen. Honda City : Tyre & wheel upgrade thread-bmw-5-series-gt-wheel-tyre-options.jpg
Do you really believe the manufacturer would sell these options if they would risk the failure of the safety systems of a car? Needless to add that it is not only improbable but impossible for the weights of every combination to be the same or even close.
Well, the whole point of racing wheels such as OZ, BBS, Enkei, Rays, TSW, etc. is their higher rigidity and lower weight, besides nearly always being wider than the OEM wheels in the same diameter.
Another tidbit: Abt sells 8.5x19 wheels for the likes of an Octavia WITH a TUV certification.
Correct, it will not mess with the safety systems but equal importance has to be given to any scraping or mechanical issues. I would not suggest 245 width tyres for a dZire because they simply will not fit. I do have an old dZire (with the large boot) running 205/55R16 tyres on 7x16 OZ Michelangelo 8 wheels.
bharatsomany is offline   Reply With Quote
Old 6th October 2014, 20:13   #165
adarsh76's Avatar
Thanked: 223 Times
Guys, I was just looking this thing below. And found the 16 inch tires close to the stock tires in circumference difference as well as speed:
4th gen. Honda City : Tyre & wheel upgrade thread-untitled.jpg
4th gen. Honda City : Tyre & wheel upgrade thread-untitled-1.jpg
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 322 30th July 2018 11:57
ICE for the 4th-gen Honda City i_m_anaconda In-Car Entertainment 52 24th July 2018 11:55
Honda City (4th gen) niggles: A compilation. Are Honda cars niggle-free anymore? CrAzY dRiVeR The Indian Car Scene 390 9th May 2018 23:35
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
