Old 26th August 2017, 17:16   #331
Default Re: 4th gen. Honda City : Tyre & wheel upgrade Thread
Originally Posted by xistinchaos View Post
For my Honda City 2011 VMT, I changed the stock Goodyears to Pirellis - Cinturato P1. The Goodyears had done about 30,000 km in 4 years so the change. I did not want the same tyres again as I wanted less noisier tyres and my experience of pressure holding in Goodyears was not great. The P1 in contrast makes very low noise at high speeds or on concrete roads. I have found them to be great for handling in city as well as highway conditions. I typically don't exceed a speed of 90 kmph, rarely at 100 kmph, so I would not know performance for speed higher than these. The tyres also hold air pressure for quite sometime. I check it every week without fail and I have to top up once in 15 days or so. I have not noticed any drop in mileage either.
The dealer from whom I bought them recommended nitrogen filling but I don't have a petrol pump on my commute which has a nitrogen air stations, so I fill normal air.
Bumping up an old post.Just wanted to know what was your overall experience with the P1. When did you finally change them?
I had changed my tyres to P1 and had a good experience initially.But after 1.5 years one tyre had a sidewall puncture
fergus is offline   Reply With Quote
Old 10th October 2017, 00:16   #332
Thanked: 7 Times
Default Re: 4th gen. Honda City : Tyre & wheel upgrade thread
Originally Posted by sammyboy View Post
Been using the MC5 on the Linea and super happy with them, planning to upgrade my 2011 City to the same tyres. Excellent handling, low noise and fantastic grip and comfort are the reasons I have decided to stick to them.
I am using MC5 on my 2014 city since January 2017. Done about 6.5k on them. Extremely happy with these set of shoes. I think they are a good mix between noise and hardness.
Planing a 700km drive on Saturday. Hope it's a comfortable one.
AkshatR is offline   Reply With Quote
Old 25th October 2017, 15:19   #333
Hi All, I have a Dec'14 Honda City iVtec V Petrol. I bought it around 8 months back, when the original user had done 32k kms. The car has now done around 43k kms and the front tyres are worn out. Apparently the first owner did not rotate tyres regularly and hence the rear tyres are still pretty good. Although as much as I would like to go for an upgrade (195/60), changing the rear tyres that are still pretty good feels like as a waste of money. The car is currently running on stock MRF's 175/60.
What are the best options that I have? Something that I can think of...
1) buy one new tyre and use that along with the spare, which is still new in the front.
2) buy a set of new tyres for the front for now. Keep the spare and rear tyres as is.
3) chuck all and go for an upgrade with all four new tyres. (what to do with the spare in that case?)
If the tyres are of the same size, is it safe to have different brands for front and rear tyres?
Raviganatra1981 is offline   Reply With Quote
Old 25th November 2017, 20:12   #334
outdoorlover's Avatar
Thanked: 63 Times
My Vx CVT is close to 4 years now and has done 38k. The original 175x65 Michelin XM1 tyres have started showing cracks on the surface with chipping that I am not very comfortable with.
After my office in Bangalore shifted to a part of the city that takes me through the thick city traffic, of late, I have been using my small car ( A-Star AT) more as it weaves well through the traffic better due to its size, which means that the City also gets to stand in the garage more often though it does come out for all family outings.
After doing some research, I finally decided to change my tyres today and went in for Yokohama Earth-1 195x60xR15 in place of the Michelin XM1 175x65xR15 that I had been using. My requirement was tyres that handle the potholes of Bangalore well while being silent and long lasting. The first impressions are that the wider Earth-1 soaks in the imperfections of the road better than my last tyre . I got pretty recently manufactured lot- week 44 tyres (end Oct) probably because these tyres are manufactured in India itself and donot have to sail in from far off shores.
4th gen. Honda City : Tyre & wheel upgrade thread-img_20171125_124453.jpg
4th gen. Honda City : Tyre & wheel upgrade thread-img_20171125_124508.jpg
outdoorlover is offline   Reply With Quote
Old 14th December 2017, 18:09   #335
Thanked: 730 Times
@outdoorlover,
I am looking at the same upgrade. Wanted your feedback on the same. Has the upgrade had the desired results? Also, what has been its impact on fuel efficiency?
autorahul is offline   Reply With Quote
Old 14th December 2017, 19:12   #336
Thanked: 63 Times
Originally Posted by autorahul View Post
@outdoorlover,
Hi Autorahul, I am quite happy with the change. The rise is much more pliant and cushioned better. I don't see any appreciable drop in efficiency yet though most of driving post the upgrade has been within Bangalore city. Hope that helps!
Old 15th December 2017, 01:48   #337
Hi guys, any thoughts on the questions below?
Old 21st December 2017, 09:25   #338
Arvindyoga's Avatar
Thanked: 31 Times
After reading through this thread, I've decided to go ahead with Continental MC5 - 195/60R15 tyres. Placed an order and the dealer said delivery would be done in 2 days.
I've been on Michelin XM2 for the past 5 years and driven 50,000 kms on them. Excellent value for money, not a single puncture on hyderabad roads.
Mine is a Honda City iVtec 2010 model and does not have alloy wheels.
Just checking, would I need new rims to upgrade to 195/60 size? I'm planning to replace the car with the latest 2017 iteration soon, so I don't want to spend too much money on tyre upgrade. If the stock rims are not compatible, I'll have to return the tyre.
ArvindYoga
Arvindyoga is offline   Reply With Quote
Old 24th February 2018, 23:44   #339
Swapnil_Alto's Avatar
Thanked: 258 Times
What should be the ideal Tyre upgrade if one buys the VX variant of the 2017 Honda City? It has 16 inch alloys with 185/55 R16 tyres.
I found this at Tyre Size Calculator. Will 205/50 R16 be an overkill? And what's the difference between stock size and 225/45 R16?
4th gen. Honda City : Tyre & wheel upgrade thread-17457843_1447603551957664_7609862344415849199_n-copy.jpg
Thanks in advance.
Swapnil_Alto is offline   Reply With Quote
Old 26th February 2018, 14:45   #340
Thanked: 707 Times
Thanks in advance.
205/50 R16 is fine in terms of numbers. 0.4% is absolutely fine. I am on 195 and it is absolutely fine. Dont think 205 will cause an issue. 225 will definitely hit the wheel well walls.
Altocumulus is online now   (1) Thanks Reply With Quote
Old 4th March 2018, 18:59   #341
CaptainPrice's Avatar
Thanked: 79 Times
Hi Altocumulus,
I've been following some of your content for a while, and your posts have been quite influential in my decision to purchase a Honda City 2018. After hearing abysmal reviews of the Bridgestone Ecopia, I'm keen on changing the tires. Could you specify the exact details of the tire you're on, or link me to a post that mentions the same? I'd also love to hear how you negotiated the tyre warranty with Honda. I will be taking delivery on 17th March in Bangalore.
PS : Also requesting a contact for your Tire Shop guy.
Thanks in advance.
CaptainPrice is offline   Reply With Quote
Old 5th March 2018, 16:24   #342
Thanked: 707 Times
Originally Posted by CaptainPrice View Post
Hi Altocumulus,
Thanks in advance.
Hey Captain Price. Congratulations on your acquisition
Glad to have some contribution to your decision.
I am running Michelin XM2 195/60 R15. I stay in Whitefield and used a tyre shop here, however I guess Tbhpian Ravi had a slightly better deal. Continental MC5 is also good.
Warranty should not be an issue, because I don't think Honda considers their cars to be that delicate. I had asked the SA when I bought the car and he had said it is not an issue as long as you are within limits. Never asked the service center actually because they are unaware about these things and if you ask Honda they will direct you to your service center. I had asked about changing the alloys where they said I will lose warranty on the steering rack only.
Old 6th March 2018, 09:18   #343
Thanked: 79 Times
Thanks, mate.
I checked with Tyre Empire in Whitefield and for the XM2s, they quoted 48k + 51k worth of vouchers for 195/55 R16, excluding Wheel Alignment and Wheel Balancing.
Also, Tyre Empire quoted 7.8k for the MC5. Will dial the folks at A1 and check for a better deal.
My Sales Reps, Kethan and Syed, told me that changing tyres would void the tyre warranty (if there's an incident and they ascertain that tyres were the cause). Also, upsizing would void warranty on suspension. It's the same dealership that you used, Saphire Honda. Is there someone else to be contacted who can assure me that warranty on suspension will not be voided?
Old 6th March 2018, 15:15   #344
Thanked: 707 Times
Are you buying VX or ZX ? Then dont upsize. 185 is good enough. Change to a better tyre of the same size. If it's V then move to 195/60/R15. For this the tyres are not more than 6.2k and then minus the buyback of your existing tyres.
Same as bove
My SA was Vishnu. He may not agree to it now if others are not. Tyre warranty is a non issue because you will get warranty from the tyre company itself. I dont think you need to worry so much. 195/60/R15 is the natural upsize for the City from the 2009 model, and atleast I have not come across anyone who has had issues with their suspension because of it.
Altocumulus is online now   Reply With Quote
Old 7th March 2018, 11:44   #345
Thanked: 79 Times
ZX.
Firstly, Tyre Empire said that Bridgestone is the only company that supplies the existing size, so no XM2s available. So I'd have to upsize to upgrade, it seems.
Say I did get the existing size from another brand, would it yield a noticeable difference? My family is now questioning whether we'll actually be in such situations that require this additional investment. Currently, expected usage is 90% City runs and 10% highway runs, and I don't have a heavy foot as of now.
The quote I was given was over 9k per tyre, and a buyback of 2.5k per tyre, and that's excluding alignment and balancing. I was appalled!
By natural upsize, do you mean that higher variants of the City sport this tyre? I already will have the highest variant so how does one go about with higher, is the question.
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 322 30th July 2018 11:57
ICE for the 4th-gen Honda City i_m_anaconda In-Car Entertainment 52 24th July 2018 11:55
Honda City (4th gen) niggles: A compilation. Are Honda cars niggle-free anymore? CrAzY dRiVeR The Indian Car Scene 390 9th May 2018 23:35
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
