Old 5th October 2016, 09:04   #91
Mr.Boss's Avatar
Thanked: 1,884 Times
Default Re: Honda Jazz : Tyre & wheel upgrade thread
Originally Posted by peterjim13 View Post
Other than the improved clearance, wont this bring a much better ride comfort.
Yes, compromising the handling characteristics.
How will this affect braking ? Isn't better road grip and braking connected ?
Tire width, pattern & compound contributes more for road grip rather than the section height. Increase in overall diameter requires higher braking force (in turn, higher pedal effort)
Mr.Boss is offline   Reply With Quote
Old 5th October 2016, 10:16   #92
peterjim13's Avatar
Thanked: 253 Times
So you mean to say there are more -ves that I am probably gonna bear just for the ride comfort when it comes to increasing the circumference of the tyre ?
Noted ! But in the image you had shared in terms the variation in the diameter. Isnt the change very marginal ?
How bad can the braking go !
The car would be mostly driven by my sister and hence the concern.
peterjim13 is offline   Reply With Quote
Old 5th October 2016, 11:46   #93
Mr.Boss's Avatar
Any change in vehicle spec will have both Pros & Cons directly and indirectly. It is hard to estimate by simple means.
Just to give an example, increase in overall tire diameter will increase the input load to suspension and other components by Kinematics (and basic engineering principle) whereas increase in air volume (side wall height) makes the overall suspension softer and hence reduces the input load. So we couldn't conclude if tire upgrade will result in positive or negative impacts.
Yes, the difference is marginal, but matters a lot when comes to part design.
Cost sensitive market & competition drive companies towards lean design, with lesser factor of safety. Also in the era of common platform design, parts from a smaller vehicle might be used in a bigger vehicle (of same / similar platform) with very less margin of safety.
To put it simple, you will have deterioration in braking (may be marginal) but the same will be compromised if better rubbers were used. To put it further simple, go for 195/65R15 if the tires don't interfere with surrounding parts
Old 3rd January 2017, 11:07   #94
Hi all,
I am thinking of changing the tyres on my 2011 Jazz, which has done around 35000 kms so far. Currently I have Michelin XM1, I am thinking to continue with the same. I had a query regarding the spare tyre, in that it has not been used even once in all the 6+ years that I have had the car. So I was wondering whether I need to change this as well, or whether I can continue to keep it and just change the other four. Any thoughts or advice?
Thanks in advance.
Ropemonk is offline   Reply With Quote
Old 26th January 2017, 10:03   #95
naikameya's Avatar
Thanked: 86 Times
I have an earlier generation honda jazz and am planning tyre upgrade from 175/65/R15 to 195/60/R15.
Currently I have 4.5 yr old Mchelin XM1 that came with the car but have gone very hard and started chipping and cracking in spite of only 30k kms.
I am planning to change to primacy 3 ST. The dealer says 195 section will make the steering heavy. I have a WagonR and Esteem at home. I find Jazz steering anyways lighter than those. My driving is in city but not too much in bumper to bumper traffic. From next week for next 2 -3 months I am going to make 2 day 900 kms trips and hence need to do this over weekend.
So I have few queries:
1. How heavy does the steering gets? Is it too much for my kind of city driving?
2. Any other pros and cons you have experienced from similar tyre upgrade. is there any impact of steering system (joints, arms, etc.)
3. For those who have actually upgraded to this size what has been your experience, does the tyre foul with any body parts?
Thanks in advance.
naikameya is online now   Reply With Quote
Old 26th January 2017, 10:08   #96
naikameya's Avatar
Thanked: 86 Times
Originally Posted by Ropemonk View Post
Hi all,
Thanks in advance.
If the spare tyre is good then you need not change. But check if the rubber has gone very hard you will need to change it as well. This is if you need to drive longer than 5 kms (this is my guess not very scientific) on the spare tyre.
Last edited by naikameya : 26th January 2017 at 10:09. Reason: Kept my 2 posts separate on purpose.
Old 4th February 2017, 21:34   #97
naikameya's Avatar
Thanked: 86 Times
Upgraded to Primacy 3 ST 195/60/R15 from XM1 175/65/R15. I got 4 tyres for 5900 each and some 300 for old tyre. I did it at Tyre X Mulund.
Also did a 900 km 2 day trip from Mumbai to Belgaum. I had done same trip 10 days before on the older tyres so the comparisons are very easy.
Some observations:
1. when someone changes from an old tyre to new one, almost always the experience will be better since the rubber is new and soft, whatever be the brands. So any feedback from anybody should be taken with pinch of salt.
2. Primacy is definitely quite than xm1 since I drive another car with xm tyres.
3. The grip levels are definitely better and handling has improved immensely.
4. As of now the tyres do not foul with any part of the car
5. Ride has been a little plush than before.
6. Steering has not become hard at all, actually it is little lighter I feel.
7. I was not able to check fuel efficiency since I did some spirited driving. The MID read 16.6 instead of 17.1 from previous trip.
Anybody wanting to upgrade should go for primacy instead of xm2 since the price difference is really small around 250 bucks per tyre.
Old 21st February 2017, 15:12   #98
mac_guy555's Avatar
Thanked: 32 Times
Some observations:
Can you please elaborate on the ride quality , ground clearance , tyre pressure recommended ? I am thinking of changing the tyres to wider ones 195/60 R15 ... what is the specification to match for the spare tyre which is just R14 ? Did you get it changed too ? If yes, then please advise the specs.
Prompt suggestions would be appreciated since every km covered now results in the original Good Year tyre resale value depreciating. FYI, the car has covered just 230 kms approx.
Thanks in advance,
Mac_Guy555.
mac_guy555 is offline   Reply With Quote
Old 21st February 2017, 17:03   #99
naikameya's Avatar
Thanked: 86 Times
The ride quality has improved as the bumps are cushioned better but that is also because my earlier tyres were hard.
The ground clearance has increased by 3 mm, for me it is noticeable.
Currently I am maintaining same tyre pressure 32/30 but reducing by 1 or 2 PSI should make the ride more cushioning.
Please note mine is previous gen Jazz it came with same tyre config as the current but spare was same R15 tyre so I haven't changed it. You can calculate right tyre using some tyre upside calculator online. Here is one I use http://tyrestore.in/upsizing.htm
R14 & R15 doesn't really matter if you do not matter if you do not plan to do a 5 tyre rotation and your spare tyre will have low usage. All you will need to ensure is the final wheel diameter with the tyre mounted is same/ close in both the tyre configurations.
Suggestions: Change the 4 tyres to Primacy 195 config and continue with the spare tyre in current config as is, unless you plan to have 5 alloy wheels then upgrade all tyres to Primacy 195 config
Old 25th February 2017, 12:17   #100
mac_guy555's Avatar
Thanked: 32 Times
Upgraded to new Yokohama Earth1 195/60 R15 Tyres at 280 kms. and let the spare wheel be as it is. Just came to know at the time of upgrade that the spare 14" tyre is not a Good Year Assurance but is a MRF and has a sticker on it ... Max speed 120 km/h.
After living with the new shoes for 100 kms. I strongly feel that it is a absolute must upgrade for all Honda Jazz owners especially for the diesel owners with more torque on tap. Get the tyres changed straight after delivery or within 50km to get the best buyback price.
My total damage was Rs. 8500/- for 4 nos. Yokohama Earth1 195/60 R15 including wheel alignment & balancing and nitrogen contract for 1 year.
Excellent tyres and I have felt that it takes on bumps & potholes with a more mature approach since the contact area is wider. The up/down movement of the car with earlier rubber is also significantly less. It feels much more planted and sure footed. The steering has become much better and is still light BUT I feel the feedback is loads better. Tyre pressure is currently 32 psi on all fours.
I have never liked a car with skinny tyres and now I feel the Jazz looks much more proportionate and the wheel wells also fill up better. Photos attached.
Honda Jazz : Tyre & wheel upgrade thread-img20170224wa0005.jpg
Honda Jazz : Tyre & wheel upgrade thread-img20170224wa0009.jpg
Honda Jazz : Tyre & wheel upgrade thread-img20170224wa0007.jpg
Honda Jazz : Tyre & wheel upgrade thread-img20170224wa0004.jpg
mac_guy555 is offline   (1) Thanks Reply With Quote
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 299 26th March 2017 18:10
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 307 23rd March 2017 17:23
Honda Civic : Tyre & wheel upgrade thread shuvd Tyre & Alloy wheel Section 606 6th January 2017 13:54
Honda Brio : Tyre & wheel upgrade thread sunnyman_46 Tyre & Alloy wheel Section 32 13th October 2016 14:49
Honda Accord : Tyre & wheel upgrade thread ab500 Tyre & Alloy wheel Section 27 27th May 2016 17:26
