Old 9th March 2015, 17:24   #1
Tushar's Avatar
Thanked: 8,379 Times
Default Goodyear Tyres Concept: Electricity Generation & Variable Tyre Pressure
Goodyear has revealed two new tyre concepts at the 85th Geneva motor show. Named “BHO3”, the first concept focuses on the rising popularity of electric vehicles and targets a reduction in the travel range limitation faced by EVs. The concept offers the possibility of charging the batteries of electric cars by transforming the heat generated by the rolling tyre into electrical energy. Goodyear says the materials used would optimize the tyre’s electricity generation capabilities as well as its rolling resistance.
The second concept named “Triple Tube” – contains three tubes that adjust tire inflation pressure in response to changing road conditions. The tyre relies on an internal pump that moves air from the main air chamber to the three individual air tubes. Depending on the road conditions, the tyre adjusts itself to 3 preset positions:-
  • Eco/Safety: Maximum inflation in all three tubes to reduce rolling resistance.
  • Sporty: Reduced inflation within the inboard shoulder tube to enable a greater contact patch and thereby better handling.
  • Wet Traction: Maximized inflation in the centre tube to improve wet road traction and aquaplaning resistance.
BH03
Goodyear Tyres Concept: Electricity Generation & Variable Tyre Pressure-gy-concept_bh03_view34_with-rim_logo-car_lr.jpg
Triple Tube
Goodyear Tyres Concept: Electricity Generation & Variable Tyre Pressure-gy-concept_triple-tube_view-34.jpg
Tushar is offline   (4) Thanks Reply With Quote
Correct Tyre Pressure For Upsized Tyres Xehaust Tyre & Alloy wheel Section 4 2nd April 2018 10:32
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Variable Fuel Quality & Performance gd1418 Technical Stuff 9 7th November 2008 12:18
Variable back pressure muffler? Deepz Modifications & Accessories 9 1st July 2007 02:17
