Old 8th August 2015, 13:14   #31
blackwasp's Avatar
Thanked: 3,124 Times
Default Re: DIY Install: 'TyreSafe' Tyre Pressure Monitoring System
This is an excellent purchase. Tyres are important part of a car and it becomes essential to monitor them. Such a system will make it easy to see their status.
Regarding manufacturers adding this features in their cars, it should not be very difficult to implement in top end versions (that have abs installed) as a tyre with low pressure than others will rotate faster relatively. VW uses such a system.
blackwasp is offline   (1) Thanks Reply With Quote
Old 9th August 2015, 08:18   #32
jfxavier's Avatar
Thanked: 1,262 Times
I had the penetrate Mont TPMS/ GPS combo installed in my car.
Here is the link to the post regarding the same.
http://www.team-bhp.com/forum/test-d...ml#post3773991 (Black Beauty: Pre-owned Volvo S60 T6!)
The possibility of seeing all temp. & press. simultaneously was the attractive part for me. The display was a little too big for my liking. Maybe it is due to the fact that they only sell TPMS bundled along with GPS navigator (maybe a smaller TPMS only unit would have been better for the purpose).
Fitting the TPMS was a straight forward affair as the transmitters were fitted in place of the existing filling valves and the display/ receiver unit was fitted on the central console on the middle AC vent.
DIY Install: 'TyreSafe' Tyre Pressure Monitoring System-tpms-layout.jpg
DIY Install: 'TyreSafe' Tyre Pressure Monitoring System-tpms-display.jpg
DIY Install: 'TyreSafe' Tyre Pressure Monitoring System-tpms-mount.jpg
jfxavier is offline   Reply With Quote
Old 9th August 2015, 09:32   #33
Thanked: 341 Times
A very good article and a good product at the right price. Thanks a lot for bringing this to our notice.
Theft is the only concern. In my case, I check pressure at home as well as fill air at home. So better would be to install it on long drives and remove after reaching destination (as I have a tendency or paranoia which makes me stop vehicle and check tires for pressure which irritates spouse like anything)
Simhi is offline   (1) Thanks Reply With Quote
Old 9th August 2015, 22:46   #34
Samfromindia's Avatar
Thanked: 588 Times
A very handy tool indeed. The tomtom 12v charger came handy in this scenario with 2 other usb slots to spare. I was thinking of buying the same but ultimately went for the phone mount charger combo. However i feel this system can be very risky here as there are reports of people getting their valve caps stolen. I think they didnt give any extra caps also. The internal setup seems to be more suitable for indian conditions.
Samfromindia is online now   (1) Thanks Reply With Quote
Old 10th August 2015, 14:26   #35
funkykar's Avatar
Thanked: 1,727 Times
- Why would this device show correct readings only while at motion? There can be a chance that you have a semi deflated tyre already(but was good when you parked it previously) and you do not notice before driving. By the time the device displays correct pressure, may be the tyre would be gone by then?
- How much do the individual sensors cost in case some one flicked it?
- How long do the batteries last?
funkykar is offline   Reply With Quote
Old 10th August 2015, 15:13   #36
Thanked: 13,337 Times
Once ignition is switched on, approximate figures are displayed but the correct ones are displayed after the speeds go above 20kmph.
Yet to experience. Not sure if individual ones are sold.
a4anurag is online now   (1) Thanks Reply With Quote
Old 10th August 2015, 15:40   #37
funkykar's Avatar
Once ignition is switched on, approximate figures are displayed by the correct one are displayed after the speeds go above 20kmph.
Yet to experience. Not sure of individual and his are sold.
For e.g:
I park the car tonight at 9PM. Lets say a nail has pierced just very recently on rear left tyre. Since its tubeless, it takes quite some time to deflate. During the night, lets say its 80% deflated. I do not inspect the tyres next morning and get into the car. You say it would now show approximate of what remains in the tyre after over night deflation and after its driven over 20kmph, it becomes more accurate.
IF this is the case it serves the purpose. If not, it may not fully serve the purpose. Off all the punctures I have had on my cars in last 12 years, 70% of them have happened when stationary and I notice it after driving a few meters. Even though you wouldn't find visible damage, am sure the tyre would take a severe beating even for few meters when driven at very low pressure/deflated condition.
Also, I really hope the sensors are cheap and easily available. I am not sure how long they can last before getting it misplaced while filling air or any one stealing it. In my experience, even the plastic air caps don't last for over 2 months for me
funkykar is offline   (1) Thanks Reply With Quote
Old 10th August 2015, 16:44   #38
See the below image:
In the above image, I purposefully deflated that particular tyre to see what is the indication I receive upon the "Sensor learning".
All it did was beep ever 1 minute to the pressures were correct. So as you mentioned, the moment the ignition is switched ON and the indication is below the lower value of set pressure then it notifies.
a4anurag is online now   (2) Thanks Reply With Quote
Old 10th August 2015, 22:34   #39
iTNerd's Avatar
Thanked: 500 Times
I had this a year back and thought I will give an honest feedback. After a month, 2 of the external sensor caps got stolen. Worst, there are no substitute caps available. So, You will be forced to buy a fresh full package again and discard the old one. And that's when I realized, this is NOT meant for Indian condition. If anyone of you are contemplating purchasing a TPMS retrofit, go for internal sensors. Its ideal and much safer in this Indian CHORRY environment. At least you won't be SORRY. About the tire rotation scenario, for internal sensors, I think it is just about making the switch via the system menu i.e., one on right tyre (RHS) could be set to be left tyre (LHS)
iTNerd is offline   (2) Thanks Reply With Quote
Old 10th August 2015, 23:01   #40
speedsatya's Avatar
Thanked: 706 Times
Thanks Anurag for this thread ! Very informative.
speedsatya is offline   (2) Thanks Reply With Quote
Old 11th August 2015, 10:49   #41
Rajeevraj's Avatar
Thanked: 8,029 Times
Nice thread Anurag. Thank you for the detailed review and information. Never realized that such a system was available as an add on. Was always thinking that the TPMS is only possible at the manufacturer level and even that was made up of some complex internal system.
I am pretty paranoid about my Tyre pressures and on top of that with my Vento have been quite unlucky- Several punctures in the last year. In most cases it it has been a nice big nail that kind of seals the hole (tubeless tyre). This results in air escaping slowly and always leaves me with a confusion as to whether I am imagining things or whether the tyre has actually lost pressure.
Looks like this is an ideal thing for me to buy.
Rajeevraj is offline   (1) Thanks Reply With Quote
Old 17th August 2015, 19:46   #42
ecosport rules's Avatar
Thanked: 1,342 Times
Useful install indeed, Anurag
Few questions
How long does the battery in the sensors last for?
Does blaupunkt have a similar model?
Please share the link
ecosport rules is offline   (1) Thanks Reply With Quote
Old 17th August 2015, 19:57   #43
According to the owners manual, average life is around 3 years. I'll have to see how long they survive in reality.
Yes. It is Blaupunkt TPM 2.1 USB. Check the links below for the same:
From Blaupunkt website:
http://www.blaupunkt.com/en/nc/produ.../single/11031/
From Amazon.in - MRP: 14800:
http://www.amazon.in/Blaupunkt-TPM21...=blaupunkt+TPM
From SnapDeal - MRP: 16990:
http://www.snapdeal.com/product/blau...kt%20TPM%202.1
a4anurag is online now   Reply With Quote
Old 19th August 2015, 11:21   #44
Thanked: 29 Times
Many thanks for the great find a4anurag! I've just ordered one for myself yesterday for $86.89...since I've had a few hair-raising experiences with tire blowouts with my Vento over the past few years myself, I was drooling over the TPMS in the XUV500. With your pioneering effort, hope to successfully install and use it for my new Creta!
mr.kaybee is offline   (1) Thanks Reply With Quote
Old 31st December 2015, 10:35   #45
Thanked: 410 Times
Hi a4anurag, Its quite sometime now after your installation. How has been the TPMS working, your valuable update is appreciated!
LoneRidder is offline   Reply With Quote
TPMS - Tyre pressure monitoring system by Tyreprobe pranil Tyre & Alloy wheel Section 23 28th May 2017 09:31
Voyage Passage Planning APEM(appraisal,Monitoring,execution and monitoring) booboo Route / Travel Queries 0 23rd October 2010 13:38
Need Fast Help :- Tire Pressure Monitoring cyneverdie Tyre & Alloy wheel Section 17 24th July 2010 11:57
