Old 13th April 2007, 22:34   #16
moralfibre's Avatar
Thanked: 6,532 Times
Hi differential what kind of a noise is this?
Old 13th April 2007, 22:42   #17
esteem_lover's Avatar
Thanked: 451 Times
please describe the kind of noise you get. there are some terrific tyre guys here who will decipher these things in a sec.
cheers
Old 14th April 2007, 00:26   #18
rishibravo's Avatar
have you switched from tubed tyres to tubeless? Generally the tubeless are more noisy that the tubed one(thats what I experienced when i switched to tubeless tyres) . But if its some king of squeeeking sound then it might be something else
rishibravo is offline   Reply With Quote
Old 14th April 2007, 02:12   #19
iraghava's Avatar
Thanked: 156 Times
Are you sure about that?
Old 14th April 2007, 02:41   #20
v1p3r's Avatar
Thanked: 27 Times
If it's a constant tap-tap sound that you get, it could be a small pebble lodged in any tyre. This is normally the most common sound people hear, and it used to drive me nuts.
Old 15th April 2007, 11:06   #21
Rehaan's Avatar
Thanked: 25,038 Times
Originally Posted by differential View Post
i've changed rims and tyres on my swift and i seem to get an intermittent noise from the tyres.
When you say intermittent, do you mean its there sometimes and sometimes its not...?
Or do you mean it is "constantly intermittent"
Does the frequency increase with the speed of the vehicle?
Are all four of your directional (Directional Tyres / Asymmetrical Tyres ?) ES100s mounted correctly?
How many kms have your tyres run?
cya
R
Old 15th April 2007, 11:20   #22
Ricky_63's Avatar
Thanked: 394 Times
Hi
I have never had this issue while switching to tubeless ever, maybe something else.......
Old 15th April 2007, 13:30   #23
differential's Avatar
Thanked: 156 Times
cya
R
hi,
its continuously intermittent and the freq. increases with speed, i've checked the placement of the tyres. i've done 7000 km.
differential is offline   Reply With Quote
Old 20th April 2007, 03:47   #24
iraghava's Avatar
Thanked: 156 Times
hi,
Well if it's not a pebble or a nail in the tyres then the logical explanation is to check your Wheel bearings, since I don't think the tyres can make such a noise. Can you describe what kind of a noise this is & when does it occur mostly?
Also have you checked to see that none of the tyres is rubbing with your wheels arches/mud flaps?
Old 20th April 2007, 08:41   #25
rishibravo's Avatar
Originally Posted by Ricky_63 View Post
Hi
Guys by noisy I meant that traction sound that the tyres produce with the tarmac.
Old 20th April 2007, 12:08   #26
iraghava's Avatar
Thanked: 156 Times
Is this "Traction" sound prduced while moving or while at a standstill?
Old 20th April 2007, 12:49   #27
hi,
hi differential, if everything else is correct including no nails & pebbles.
As you mentioned it increases with speed, you are having a shimmy tyre.
Iragahva is correct check your wheel bearings(a cause for shimmy wheel), second reason is you have a bent wheel.
get your steel wheels checked for shimmyness & circularity.then check wheel bearing.
arunforu1 is offline   Reply With Quote
Old 21st April 2007, 10:40   #28
Epic's Avatar
Thanked: 424 Times
hiya, i'm a new member.
i've changed rims and tyres on my swift and i seem to get an intermittent noise from the tyres. repeated wheel balancing and alignments have not settled the problem.
size: 15 inch HR rims with 38mm offset
tyres: 205/55 R15 Yokohama ES 100
Hi Differential,
Firstly, i am concerned about the above specifications mentioned. Correct me if im wrong here, but i believe the Swift comes with stock rims having offset 42. I myself have upgraded my rims to OZ Racing 6.5 X 15", PCD 100 & Offset 43 and 195/60/R15 Goodyear Eagle F1 tyres. These specifications were given by the OZ Racing experts in Italy. I knew the PCD but never knew the Offset. They specifically mentioned that the Offset for the Swift should preferably be greater than 42.
Now your specification says 38 offset. Could this be the problem after all???
Epic
Epic is online now   Reply With Quote
Old 21st April 2007, 10:50   #29
kpzen's Avatar
Thanked: 1,655 Times
Epic
Offset cant cause tyre noise unless the tyres are scraping against the wheel wells
Old 21st April 2007, 11:16   #30
tsk1979's Avatar
Thanked: 16,420 Times
I think the mud flaps are flapping against the tires.
Kumaon: roads less traveled and forests less visited nilanjanray Route / Travel Queries 21 11th January 2013 12:25
GM India - Hope less? or Aim less? or both? rnidumolu The Indian Car Scene 16 17th September 2012 15:12
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 12 10th June 2009 09:59
Noisy Swift Diesel rajatsingh78 Technical Stuff 38 11th July 2008 17:44
Test Drive: Palio Stile 1.6, noisy cabin (engine noise) amitsingh08 Test-Drives & Initial Ownership Reports 16 22nd December 2007 01:10
