Old 4th December 2009, 18:54   #46
Originally Posted by gsferrari View Post
Car: Ford Ikon 1.6 SXi (2003 - 38000kms)
Current Tyres: Bridgestone OEM 175/70 R13
I drive in Mumbai on the Eastern Express Highway which is a mix of concrete and tarmac. The tyre noise is unbearable at times. I did have noisy bearings and got them replaced last week. I have a feeling that despite the relatively low mileage, the rubber has hardened to the point where grip is adversely affected -AND- tyre noise is higher than usual.
I suspect it is time for a tyre change and I am looking to suggestions. My requirements are:
- Low tread noise
- Good grip in the wet and under braking
- Good grip over white lines
- Low tendency for tramlining
I don't want low-profile rubber because I greatly value the comfort and ride quality that a high profile tire can provide on our roads.
Your suggestions are welcome!
Your requirement can be fulfilled by Michelin XM1+ and yoko A drive .
both are silica based will give you good wet traction and both the tyres have interlinked shoulder blocks that minimizes noise.
itzzme is offline   Reply With Quote
Old 5th December 2009, 00:31   #47
gsferrari's Avatar
Thanked: 135 Times
Thanks for the tip - I'll head to the dealers and see whats what.
gsferrari is offline   Reply With Quote
Old 5th December 2009, 01:33   #48
Berj79's Avatar
yokohama dna es501 also is suppose to be a quiet tire, check that out too..
Berj79 is offline   Reply With Quote
Old 5th December 2009, 09:35   #49
dinu2506's Avatar
Thanked: 351 Times
Another angle to the discussion. Do you also feel the tyre noise is also dependent on the acoustics of the car. Have anyone tried damping the the floor or wheel wells and noticed an improvement. If yes, its worthwhile DIY which I am contemplating.
dinu2506 is offline   Reply With Quote
Old 5th December 2009, 20:53   #50
Arrow
i bought a set of nexen N2000 for my ford ikon. size is 195/70 R14
great tyres for wet conditions and noise damping. a uni-directional tread pattern helps grip around corners(as if it wasn't good at gripping already!). I suggest you take a look at the tyres at the nexen website. worth a try
rajeevatdelhi is offline   Reply With Quote
Old 5th December 2009, 23:02   #51
gsferrari's Avatar
Thanked: 135 Times
I will - thanks!
Dynamat comes to mind and yes it does work. Expensive stuff though!
I will check these out as well. Thanks for the tip
Old 6th December 2009, 02:17   #52
iraghava's Avatar
Thanked: 156 Times
Are you facing any scraping problems with that size? Its almost impossible to fit 195/60 on to the Ikon, I wonder how you managed to fit 195/70. Any suspension mods?
Old 7th December 2009, 12:14   #53
Originally Posted by MotoKris View Post
The Michelin Energy XM1+ 175/70 R13 costs Rs 3200 (MRP from the website).
How much did the Apollo Acelere cost you?
Which one would be a better option for someone who drives the car without revving it up much higher? The grip levels in wet, braking and life are important factors.
Apollo Acelere costed me 2600/- per tyre but that was three months ago. I have already driven more than 5k kms (mix of high speed highway drives, city drive and in a crazy rainy situation as well) and never faced any issues.
Mr M R K is offline   Reply With Quote
Old 11th December 2009, 15:32   #54
70 was a typo. it's actually 195/60. and no it's not impossible. no mods on the car as of yet
will post a pic of the car if desired by you.........
Old 27th January 2010, 20:29   #55
khoj's Avatar
Thanked: 1,258 Times
Where in Delhi can one buy Nexen, please let me know.
Old 30th January 2010, 23:42   #56
mithun's Avatar
Thanked: 59 Times
I've always heard that Goodyear tyres(generally) are less noisy when compared to others. is that true ?
Old 31st January 2010, 11:37   #57
sdp1975's Avatar
Thanked: 972 Times
Dont think so, I got GT3s on my Punto and they are not exactly quiet.
sdp1975 is offline   Reply With Quote
Old 9th February 2010, 01:02   #58
iraghava's Avatar
Thanked: 156 Times
For most of the range its actually the opposite. Example include GSD2/3, NCT5, GPS2 etc.
Old 27th February 2010, 19:15   #59
bnzjon's Avatar
Thanked: 125 Times
I have Goodyear GT3 for my Linea.
Its awfully louder on Cement roads, Loud on tar roads and dead silent only when its in the parking lot.
bnzjon is offline   Reply With Quote
Old 27th February 2010, 20:13   #60
Thanked: 312 Times
I have put 205/60/15 on my honda civic stock rims, not at all noisy, gives a little macho look, great handling and i am very happy with them, have already done 20k, when time comes for a change once i have burnt them completely, i will buy them again.
The Saint is offline   Reply With Quote
Kumaon: roads less traveled and forests less visited nilanjanray Route / Travel Queries 21 11th January 2013 12:25
GM India - Hope less? or Aim less? or both? rnidumolu The Indian Car Scene 16 17th September 2012 15:12
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 12 10th June 2009 09:59
Noisy Swift Diesel rajatsingh78 Technical Stuff 38 11th July 2008 17:44
Test Drive: Palio Stile 1.6, noisy cabin (engine noise) amitsingh08 Test-Drives & Initial Ownership Reports 16 22nd December 2007 01:10
