Old 8th September 2015, 20:19   #1
PatchyBoy's Avatar
Thanked: 1,397 Times
Default OZ Alloys and Victon TPMS on my Fiat Linea T-Jet
Alloys
Ever since I bought the T-Jet three years back, I always wanted to upsize to 16" alloys and 205/55 R16 rubber. That was the stock size for the T-Jet plus variant. So I started saving, but something or the other kept coming up and I had to divert my savings for some other objective.
Finally, I had saved up enough and wanted the best I could afford. The tyres were decided a while back - Pirelli Cinturato P7. Alloy choices were confusing. There were several brands and designs available, but none in 98 PCD that caught my fancy. The only 98 PCD readily available was OE. I never felt that OE rims were worth the money @ ₹11,500 per piece.
So I started researching the pros and cons of using 100 PCD instead. The more I read about it, the more I was convinced that 100 PCD is usable, as long as it is done correctly. Wobble bolts were the way to go. As with any after market alloys, hub rings were also needed.
So, I zeroed in on OZ racing alloys. They were pretty expensive, but were definitely worth the money, based on thousands of user reviews - both online, as well as real users that I know of. So, the quest ended here.
All parts, except tyres bought at Hot Tracks, Bangalore. Tyres sourced from Millivision, Bangalore. Here are the cost details -
OZ Racing Lounge 8 alloys - ₹ 54,000 for a set of 4
Tyres - ₹ 30,000 for a set of four
Hub rings - ₹ 2000 for a set of 4
Wobble bolts - M12 x 1.25 ₹ 3200 for 16 numbers
Balancing & fitting - ₹ 800
Total - ₹ 90,000
Did some high speed runs and some hard braking today morning. Did not notice any vibration or wobble. I am very happy with the setup.
Hub rings
Another view of the hub ring. OZ branded, 58.1 mm to suit FIAT
Wobble bolt
Alloys being installed
The alloy wheel
TPMS
I had already made up mind that I will install a TPMS, when I install new tyres. This was based on my experience with losing a 5000 kms old Michelin as I drove a few kms without realizing that I had a flat rear tyre. By the time I realized and pulled over, the side wall had taken a severe beating and the tyre was rubbish. The logic was, the TPMS costs less than or about the same as a new tyre and even if it saves one tyre, it has paid for itself.
There were three options -
1. The rudimentary color coded dust cap. It is a basic TPMS and will help identify any tyre with low pressure, when the car is at a standstill and I make an effort of walking around and checking. Even if I had that, I would have still lost that Michelin anyway
2. External sensor type -
These are easy to install, as the dust cap has an inbuilt sensor, which relays info via wireless in real time. Problem is, it is visible from the outside and will take just a curious kid to be stolen. Replacement sensors are available, but strangely a single replacement sensor costs almost half the cost of the entire system.
3. Internal Sensor type -
These seem to be the best bet. They are fitted inside the rim, protected from the elements, not to mention the curious kids. So I started looking at various models available and zeroed in on the Victon 800A. At a cost of $105 including expedited shipping, it was reasonably priced. I placed the order on the 1st, was shipped on the 2nd, reached Bangalore on the 5th and was delivered on the 7th. Well worth the extra $10 I paid for shipping.
TPMS bought from here
This specific model -
Pros -
  • Reasonable price
  • Internal Sensor
  • Valve made of aircraft grade aluminium
  • Uses Infineon chipset
  • Display has rechargeable battery and can be placed anywhere in the car without dangling wires
  • Sensor position can be re-learnt when rotating
  • The build quality is superb
Cons -
  • Doesn't display tyre temperature - though sounds an alarm if it exceeds 70* C
  • Instruction Manual and all stickers on the device, including sensor position for initial installation is in Chinese
  • If the display is powered down, upon restarting all custom settings revert to default - pressure is displayed in bar and minimum pressure warning gets reset to 1.7 bar (~24 psi)
  • Long term reliability unknown. User reviews were mostly positive. There was only one negative review.
So, I took the risk and ordered this. Escaped from any customs duty. Came very well packed and the product box itself was very well built. Used Google to translate the sensor position for initial installation. I could have used the re-learn function, but chose to do this instead. Right after the installation, it started working as expected. It was showing 34 psi in the front and 32 psi in the back, though we filled 36 psi and 33 psi. Not sure if it is a calibration issue in the tyre shop, or margin of error of the sensor (document does say ± 1.5 psi accuracy). Once the car is stopped and parked, the display goes to sleep after a minute. The vibration due to unlocking the car was enough to wake it up again. The tyre pressure went up by about 2 psi after the B2B run of 15 kms. Will have to check long distance high speed behaviour. TPMS installation done at Madhus, Bangalore. All in all, I am happy with the purchase.
Me being me, couldn't stop at just printing out the Chinese characters and writing down the location. Had to do this
The sensor, inside the alloy
How it looks from the outside. Now that curious kid will have to be content with just the dust cap
On the way back post installation
At the end of a 15 km bumper to bumper city drive. The pressure had gone up by a couple of psi
PatchyBoy is offline   (21) Thanks Reply With Quote
Old 8th September 2015, 20:48   #2
Thanked: 14,603 Times
Default re: OZ Alloys and Victon TPMS on my Fiat Linea T-Jet
Originally Posted by PatchyBoy View Post
TPMS
E-X-C-E-L-L-E-N-T! Side stance of the car is drool worthy. Hats off to your choice.
I love those alloys and good you went in for TPMS with the new set of tyres. Will go a long way in protecting your tyres and also get you good FE.
Here's mine:
TyreSafe TPMS
I went with external sensor as the stealing part is not issue for me and the other reason that made me choose is problem during Tyre Rotation. I have a high running (110 kms a day) so I do the tyre rotation, wheel alignment and balancing every 5K kms so if I use the external sensors, all I have to remove it before rotating and re-fix it after rotation else the figures on the TPMS monitor will haphazard.
If it is internal type I'll have to get the tyre opened to extract the sensor.
a4anurag is online now   (1) Thanks Reply With Quote
Old 8th September 2015, 20:50   #3
PatchyBoy's Avatar
If it is internal tyre I'll have to get the tyre opened to extract the sensor.
This model addresses that issue. It has a built in sensor position relearn function. So, it is possible to reassign sensor position, in case of tyre rotation.
PatchyBoy is offline   (2) Thanks Reply With Quote
Old 8th September 2015, 20:53   #4
So do you mean after getting the tyres rotated, all one has to do is reassign the sensors to the main unit?! That's cool.
a4anurag is online now   Reply With Quote
Old 9th September 2015, 10:09   #5
ghodlur's Avatar
Thanked: 2,434 Times
Smile re: OZ Alloys and Victon TPMS on my Fiat Linea T-Jet
Hello Rajan Sir (if I assume you are the same Patchyboy),
Thats a cool DIY. The alloys looks rocking, IMHO they are quite expensive. Regarding the TPMS, since the sensor is internal, any one sensor going faulty would required the tyre to be removed for inspection isnt it? Is this not laborious as compared to the external sensor mounts? Also whats the warranty on these sensors? Also on the closer shot of the alloy I could not see any balancing weights, am I missing something here?
Your car still looks droolworthy.
ghodlur is online now   Reply With Quote
Old 9th September 2015, 10:20   #6
Originally Posted by ghodlur View Post
Any one sensor going faulty would required the tyre to be removed for inspection isnt it?
Laborious, Yes but the tension of losing the sensor is nullified. With the internal type sensor that is a problem. Hour these are reliable.
I have 3 years warranty on the TPMS system that i enquired and confirmed before I bought from AliExpress.
I guess the balancing would have been done and the weights are placed on the inner side of the wheel.
Old 9th September 2015, 10:27   #7
PatchyBoy's Avatar
Yes, I am the same Rajan.
It is not a DIY buddy. Yes, the alloys are expensive, but they are worth it, going by the reputation OZ racing enjoys in the market.
Yes. That is a risk. There is a 6 month warranty, but I am not counting on it. The main reason for getting these is to prevent theft. There are balancing weights, but they are not visible in the picture
PatchyBoy is offline   (1) Thanks Reply With Quote
Old 9th September 2015, 10:56   #8
sdp1975's Avatar
Thanked: 972 Times
What's the longevity of the built in battery in the display, is it replaceable ? Batteries become weak after a certain number of recharges - just like our phone batteries.
Planning to install something similar on my Punto. Btw, feedback on the new tyres ? I guess you'll be looking at a slightly reduced mileage. Those alloys look really great.
sdp1975 is online now   Reply With Quote
Old 9th September 2015, 11:03   #9
PatchyBoy's Avatar
The battery in the display is rechargeable. The manufacturer claims a life of 45 days per charge and the battery is rated for 300 charge cycles. Not sure if it is replaceable, but I am sure I can find a way out if the battery dies prematurely.
The new tyres are grippier and silent. Too early to provide any feedback. Done only about 200 kms on these tyres. I am not fussy about mileage. I have a T-Jet, you see
Old 9th September 2015, 14:38   #10
Thanked: 103,459 Times
Default Re: OZ Alloys and Victon TPMS on my Fiat Linea T-Jet
Very nice rims - congrats!
How about some full profile pics from different angles showing us the meaty stance of your car? Right now, the only image we have is with the car jacked up!
Personally though, I'd never buy rims of a different PCD, no matter what the adjustment. It's just something I'm not comfortable with.
GTO is offline   (1) Thanks Reply With Quote
Old 9th September 2015, 16:13   #11
karan561's Avatar
Thanked: 10,547 Times
Congrats, those OZ's look HAUTE
I remember doing a similar PCD correction on my Corolla & Punto rim upgrade. That time i had got it done at a local mod shop who fabricated these bangles for me & the experiment worked well for me
But that was that after which i have set my mind that for future rim upgrades i'd stick to the OE PCD or no upgrade at all.
karan561 is offline   Reply With Quote
Old 9th September 2015, 18:44   #12
PatchyBoy's Avatar
Thank you guys.
Here you go
Neither was I, till I did some serious research. The response to this will be pretty lengthy. Let me know if you would like me to share my research here and I shall do so.
PatchyBoy is offline   (3) Thanks Reply With Quote
Old 11th September 2015, 10:53   #13
PatchyBoy's Avatar
I have answered this in detail here -
PCD Variation Bolts (PCD Variation Bolts (aka Wobble Bolts) - Myth versus Reality)
Would you still hesitate to use them? If so, why? Just trying to understand some downside I might have overlooked. Thanks
Old 20th September 2015, 02:09   #14
carwatcher's Avatar
Thanked: 1,003 Times
Thanks for the wonderful pics.
I would like to know that is there any specific reason for not going for black vinyl wrap on the roof as its the only mod missing out. IMO it will surely enhance the look.
Thank you guys.
carwatcher is offline   Reply With Quote
Old 5th May 2018, 20:04   #15
sdp1975's Avatar
Thanked: 972 Times
PatchyBoy , how's the Victon TPMS doing ? Any problems so far ? I'm thinking of buying one for my Punto.
EDIT : Can't find the Victon model with internal sensors on AliExpress. There's one with external sensors though.
My Terrestrial Fighter Jet : Fiat Linea T-Jet+. EDIT: 3 years, 4th Service completed KarthikK Long-Term Ownership Reviews 220 8th April 2015 00:19
Renaissance of my JET - White FIAT Linea T-Jet+ (27,000 Kms Up) Sathya_sc Test-Drives & Initial Ownership Reports 225 4th August 2014 20:29
Fuelled FIRE into my (T)JET - The Fiat Linea T-Jet bnzjon Test-Drives & Initial Ownership Reports 123 12th May 2013 00:16
