Old 1st July 2004, 02:32   #1
speedsatya's Avatar
Thanked: 712 Times
guys maybe this wud help u to go for an appropriate upsize.
a +-5mm is said to be acceptable .as anything differnt cud affect the handling,the ground clearance,the speedo reading
consider 145/70r13,of the carb zen
to calculate the tire overall diameter(OD),we multiply the tire width by the aspect ratio to get the height of the tire.
tire height =145*70%=101.5mm=3.9961inches
then we add this tire height to the rim diameter.
2(3.9961)inches+13inches=20.9962inches=533.2018mm.
this is the unloaded tire diameter.as soona s any weight is added this will reduce.
for 145/80r12 ,this is 536.8mm(difference of 3mm)in the mpfi zen,so ground clearance increases by 1.5mmand speedo rdg is same.
for upsize of 155/70r13,this is 547.2mm(a massive increase of 14mm over the original tire),so that is 7mm increase in grnd clrnce.
for 155/65r13,this is 531.7mm ,so that is -2mm and so 1mm decrease in grnd clearance .
so to get an almost similar peedo reading the ideal upsize for a zen shud be 155/65r13 that is provided the 155mm does not foul with any body part.
simi;arly u can calculate the required upsize for ur cars
speedsatya is offline   Reply With Quote
Old 1st July 2004, 09:24   #2
Shan2nu's Avatar
Thanked: 89 Times
http://www.car-videos.com/info/tirespecs.asp
Well if you happen to be bad at math or don't like to work those equations out.
Check out the link above, it's got a online calculator that will do the summing up for you.
Regards....
Shan2nu
Old 1st July 2004, 10:14   #3
this is a very good info. i was just thinking that the upgrade of tyre is all abt width and length. never tought of these calculations.
ravi_28_8 is offline   Reply With Quote
Old 26th April 2010, 15:57   #4
supremoo's Avatar
i think this is a fantastic pierce of information; hope the mods would make it a sticky so enthusiast would not over do the up sizing exercise.
while on the same topic; how much harder would it be to park your vehicle (with bigger tyres) if it was not power assisted? The mahindra invader 4WD does not come with P/S.
supremoo is offline   Reply With Quote
Old 10th August 2011, 07:00   #5
Endeavour333's Avatar
Thanked: 358 Times
Default Re: how to calculate tire diameter
Hello Speedstaya, I have a question regarding tire size and diameter.
Suppose I stay on my current rims on my Endeavour and stock tires of 245/70/16, and then choose to upgrade tire size to say 275/60/16, the formula shows that tire diameter should be 28.9 inches compared to stock tire diameter of 29.5. However what effect does putting 30mm wider rims on the same rim size have on the tire diameter? Will the tire diameter be greater than 28.9 inches once the tire has been mounted on the rim?
I'm looking out for a tire and am finding it really hard to find the size that I want! Thank you for the help.
Endeavour333 is offline   Reply With Quote
Upsizing the Size (Diameter) of your tyre.. AbhiJ Technical Stuff 25 11th May 2015 11:34
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
Hub/Bore Diameter doubt about Baleno Rims greenhorn Tyre & Alloy wheel Section 6 28th October 2009 15:22
Same Profile, Same Make. But still difference in diameter. Possible? vrooooooom Tyre & Alloy wheel Section 34 13th August 2008 21:07
