Old 30th March 2007, 11:27   #136
binz's Avatar
Thanked: 411 Times
Originally Posted by Buffetfan View Post
..185/65R14..did not want a wider tyre since Baleno boot already finds it difficult to hold this size only ...dont want to reduce luggage space further
I didnt understand anything above.Please explain.
Old 30th March 2007, 11:48   #137
Originally Posted by spider77 View Post
I am Karan Iam a new memeber here, Thanks for providing such a great resourse of information for any kind of car and related issues..Its a great site and really helped me alot in finding out the right set of tyres and alloys for my Baleno. Check out these links my Wine red Baleno looks Great
Hey Karan
First welcome to the Team-Bhp Pal, Second Welcome to the Baleno Club , the car looks great... Congrats.
../Mega
mega5918 is offline   Reply With Quote
Old 30th March 2007, 11:53   #138
binz's Avatar
Thanked: 411 Times
Oh oh oh .YOu meant spare tire.Got it!
Old 30th March 2007, 12:04   #139
mclaren1885's Avatar
Thanked: 28 Times
Infractions: 0/1 (10)
Buff , im quite sure a 195/65/15 fits in the wheel well without a hassle .. Thats whats running as my stepny right now ..
Old 30th March 2007, 12:16   #140
shuvc's Avatar
Thanked: 283 Times
True .. the 195/60/14 I'm running also fits fine. On very close observation I felt that there may be a sliiiiight bulge on the centre of the boot mat. But nothing so significant that it would reduce boot space.
Old 30th March 2007, 12:51   #141
binz's Avatar
Thanked: 411 Times
Post
Now,
sometime in the coming month the baleno is going to get new tires.This depends on when we take the car out for a roadtrip.So potential options are
195/60/14
+ves- good ride,perfect upsize for my car,reduced chances of steel rim bending
-ves- Alloys wont really look great in 14"(subjective),tires cant be swapped with a higher segment car,ride
185/65/14
+ves- Stock size on the vxi,would be the best bet,cheap!
-ves - cant be swapped with a higher segment car,ride.
195/55/15
+ves- Perfect upsize,.better handling,..looks better and bigger,..stock size on a higher segment car
-ves -Ride goes down,cant be mounted on a steel rim(bending)
205/50/15
+ves - handling,Would be a perfect size for a higher seg car,will look great from the back
-ves - Ride will be killer,car will slow down a bit,Alloys are a must(read expense)
Now this car might be gone in the next 2-4 months(about 2.5-3k kms).And my dad is sure as hell not going to buy new tires for a new car.We might buy one of the new age diesels like the verna sort,In which case 195/55/15 would be my best bet.
So basically,which would be the best viz a viz performance,ride,fe.
Then comes the problem of which tire to buy,..
Eagles are out of the question,..and im interested in the es100,G3,Maxxis Ma-Z1.Pilots;lets see
HEre i could compromise a bit on performance for ride and road noise
Help !
Old 30th March 2007, 12:58   #142
shuvc's Avatar
Thanked: 283 Times
I think you should back-calculate here. Decide on the size(s) that will make sense in your next car and then see if they fit the Baleno. If you have to compromise on ride a bit for 2-4 months, so be it. Apparently you are more inclined towards 15"ers in your next car. In that case choose the alloys too for the next car and fit those 15" alloys on the Baleno.
Once you buy the new car, you can replace both wheels and tyres.
IMO, the key thing to decide here is what your next car will be. Once you sort that out, the rest of the decisions will fall into place.
Old 30th March 2007, 13:02   #143
binz's Avatar
Thanked: 411 Times
Ok and what about the tires,..budget is around 3.5
Old 30th March 2007, 13:07   #144
shuvc's Avatar
Thanked: 283 Times
Given this criteria the popular recommendation would probably be the Michelins.
Old 30th March 2007, 14:37   #145
Thanked: 28 Times
Confirmed news from a rally driver say that 195/55/15''s on a baleno technically and figuratively could be the correct upsize but practically it slows the car down and isnt as convincing around corners too .. He advised it was best to go in for 195/50/15''s and i paid heed to his advise .. Lets see how it works ..
Old 2nd April 2007, 11:34   #146
Smile
@Maclaren,
Exactly, 195/55/R15 is the correct upsize, here is the math
Tyre Specs--Height-----Circumference---RPK
195/55/R15--595.5 mm--1871.58 mm-----535
185/60/R14--596.1 mm--1873.46 mm-----534
165/80/R13--594.2 mm--1867.49 mm-----536
PS: RPK->Revolutions Per Kilometer
I'm running 195/55/15 GSD3's
../Mega
Old 3rd April 2007, 01:53   #147
Thanked: 157 Times
Exactly... I also have this "slight" bulge even with 185/65R14.. and hence dont want to add another 10 mm to it.. given that I already have a sub with a box..in the boot that probably takes away 50-60 litres of space!!
anyway.. I not into checking the cornering limits of my car...so the 185/65 do just fine... the michelins I got are pretty comfy too with low noise...
binz... I would suggest that you go in for 185/65 as the verna comes in that tyre size (the petrol higher end that is)..
BTW.. just make sure that either you buy multi pcd alloys or the car that you plan to upgrade to has the same pcd as the Baleno
Buffetfan is offline   Reply With Quote
Old 3rd April 2007, 03:48   #148
v1p3r's Avatar
Thanked: 26 Times
Hey are you sure you don't mean 185/65 R14. 185/60 is a little low. It's what the Esteems run.
Old 10th April 2007, 14:50   #149
@v1p3r,
You are rite, Me wrong. It's 185/65/R14.
Well the calculations were done for 185/65/R14 but while posting I made a mistake and keyd in 185/60/R14 (typo ). Mods if possible please correct the value in my previous post.
../Mega
Old 1st June 2007, 14:05   #150
Thanked: 7 Times
[quote=gigy;302678]these are the tyre sizes i found for standard baleno tyre,
Tyre code Diameter Circumference Difference
Thanks gigy for the valuable info on upsizing Baleno tyres - was thinking of a 15" alloy wheel conversion
eapen is offline   Reply With Quote
Front Wheel Drive v/s Rear Wheel Drive Revvhead Technical Stuff 269 3rd August 2017 15:48
Maruti Suzuki Baleno (hatchback) : Tyre & wheel upgrade thread rikhav Tyre & Alloy wheel Section 20 27th April 2017 20:47
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Do Wheel Caps Disturb Wheel Balance leadf00t Tyre & Alloy wheel Section 5 19th January 2009 15:22
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
