Old 21st January 2016, 10:58   #1
ilangop's Avatar
Thanked: 591 Times
Default Fiat Palio 1.1L Stile: Upgraded to 14" rims
Hi All,
This is about my colleague's Palio Stile 1.1 Petrol version which he acquired last year. The car had done 27000 kms and still running on the stock Good year 165/80-R13. As the stock tyre had developed bubbles and needed immediate replacement, the hunt started.
After a few visits to a couple of tyre shops, we got to know that we are not going to find a 165/80-R13 locally and then looked for online sources. It was surprising that the price of this particular size alone is comparable to a 175 or 185 profile tyre. And thinking of a long term solution we decided on a rim upsize.
Ordered a set of 4 nos - 14" rims + wheel caps of Fiat Punto from 99rpm.com, 165/70-R14 from snapdeal.com, tubeless tyre valve set from ebay.in. This was all in the last week of December. 99rpm was closed till new year and we had been waiting or the rims for about 10 days. The rest of the stuff had reached us already. Finally the rims & wheel caps arrived on 8th Jan. We were all excited to proceed with fitment.
On 10th, we set out to a nearby tyre & wheel alignment shop and got the fitment done. Took a test drive and felt a difference in the noise levels and above all no more wobbling on the steering wheel. Just for info, the Punto rims are 5.5x14" rims with ET-41. After fitment, the wheel track didn't appear to have changed. So I presume the Palio wheel also came with a similar offset value.
Everything went well, except that the alignment guy revealed that one of the tie-rod ends is jammed and hence toe-in could be adjusted on only 1 side. Replacing the tie-rod will be addressed soon.
Fiat Palio 1.1L Stile: Upgraded to 14" rims-img_20160107_184406.jpg
Fiat Palio 1.1L Stile: Upgraded to 14" rims-img_20160110_133600.jpg
Fiat Palio 1.1L Stile: Upgraded to 14" rims-img_20160110_141121.jpg
Fiat Palio 1.1L Stile: Upgraded to 14" rims-img_20160110_141125.jpg
Fiat Palio 1.1L Stile: Upgraded to 14" rims-img_20160110_152531.jpg
ilangop is offline   (4) Thanks Reply With Quote
Old 21st January 2016, 18:18   #2
Thanked: 443 Times
Default Re: Fiat Palio 1.1L Stile: Upgraded to 14" rims
165/80/13 can be replaced with 185/70/13 which is easily available. My Stile 1.1 runs on them.
Best of luck with the new tyres!
directinjection is offline   (2) Thanks Reply With Quote
Old 22nd January 2016, 09:03   #3
ilangop's Avatar
Thanked: 591 Times
Hi Directinjection,
Yes, the tyre shops suggested 175 & 185 profiles. But for the puny 1.1 litre engine we decided not to strain it with a wider tyre.
Also a wider tyre would compromise on fuel economy marginally. I personally felt, for a powerful 1.6 P or 1.9 D Palio a wider tyre would do all the justice but not for a 1.1 Stile.
-Ilango
ilangop is offline   (1) Thanks Reply With Quote
TATA - FIAT Palio Stile MJD : Crafted by FIAT specially for ME! funkykar Test-Drives & Initial Ownership Reports 179 25th March 2014 13:58
It's Mine!! "Pre-Cared Fiat Palio Stile SDX" - Just another FIAT in my life! funkykar Test-Drives & Initial Ownership Reports 69 6th November 2010 15:54
Palio Stile 1.6 or Palio Stile 1.3MJD? rudrah Hatchbacks 47 5th May 2008 03:45
Palio Retro -> Palio Stile windsurfer Modifications & Accessories 17 20th September 2007 20:31
Palio Stile 1.6 or Old Palio 1.6 2006 vinodbijlani Hatchbacks 12 14th August 2007 15:44
