Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 12th October 2006, 00:51   #1 (permalink)
sAP
sAP's Avatar
Arrow Part 2: Update to Solution for vibrations after installing alloy wheels
This is an update to wheel vibration/ brake shudder issues experienced on high speed cruising after installing alloy wheels.
On part 1 of this topic (http://www.team-bhp.com/forum/151614-post1.html), I mentioned about the need for "centering" aftermarket wheels by installing "centering rings" to reduce the effects of steering/ wheel vibration at speed. Also I mentioned how the vibrations dissappeared after I installed metal centering rings on all 4 wheels.
7000kms later after running on such a setup, I have more experience to share with discerning driving enthusiasts. The reason I have started this as a new thread is so that readers can quickly find this information by going to the first post of the thread.
In my previous long distance daytrip (~700kms), I experienced severe brake shudder when braking from moderate cruise speed (~130km/hr). The brake pedal would pulsate badly when high pressure is applied to the brake, causing passengers in the vehicle also to feel the shudder/vibration. At 160km/hr, it gets a little violent.
Since this was discomforting, I had the brake discs immediately checked for lateral runout and skimmed them to tolerance at a specialized lathe. This indeed helped because the brake shudder reduced considerably. However, over a period of time, it started to increase again.
So last weekend, I installed brand new sets of front brake discs (rotors), brake pads and re-bled the system with new brake fluid. Also, I checked for air bubbles trapped in the lines. After this was done, I took a test drive and found that there was no brake shudder at all in the beginning. However, my happiness didnt last very long. After several attempts over a high speed stretch, I noticed that brake pulsation was starting to creep in. Very slowly, but definitely creeping in.
I didn't want my new brake discs to start warping like my old ones. So I immediately got my alloy wheels off (K-speed 13" with centering rings and all) and installed my stock Corsa wheels (13"). Now, back to the high speed stretch and what an amazing difference there was. The stock wheels on a Corsa were brilliant as far as high speed cruising and braking were concerned! (And sucked as far as looks were concerned)
I tried running several times over, but the new brakes never showed a hint of pulsation or shudder. Verdict: You stand a very good chance of ruining your car by changing over from it's stock wheels.
Now then, a person who's been running on alloy wheels finds it very difficult to run on boring steel wheels. So yesterday I got a brand new set of Aura wheels installed (F61350 13" which is relatively new and not yet displayed on their website) and sold off my used K-speed set (KS315 13") to a used wheels dealer.
Why did I get Aura wheels? Because they were the closest I could get to my original steel wheel specification, which includes:
  • an exactly matching center-bore for my car (56.5mm hub dia)
  • an exactly matching rim width (5")
  • an offset that matches my original (46mm)
  • am anyway running original/ stock tires
In the looks department, the Auras don't stand a chance against my earlier K-speed set (which was a classic 5-spoke with a machined finish, which you can see in my team-bhp garage)
Well, I was back to testing this morning. Heavy braking from 150km/hr. No brake shudder! Tried several times over. Not a *hint* of brake shudder. And it wasn't creeping in either. Hopefully thats the last I have seen of wheel issues.
So here is a summary:
  1. Installed K-speed 13" alloys on stock tires, wheel vibrations occured at high speed
  2. Installed centering rings, high speed vibrations dissappeared
  3. After 7000kms, brake shudder set in
  4. Installed new brake disc, pad and fluid. No brake shudder initially, but it starts to set in slowly
  5. Swapped to stock wheels, no brake shudder whatsoever
  6. After being bored with stock wheels, installed Aura alloys matching original hub-dia, rim-width and offset.
  7. No brake shudder whatsoever
So now, you can make your own verdict. If you have questions, please post them here. I will try and answer as much as I can or know about.
I have to add though, that the Aura's still don't feel as great as the stock Corsa wheels in the 160km/hr territory.
Hope this helps.
sAP
PS: In case you are wondering where all this testing occurs in a place as crowded as chennai, it occured on the Chennai-Tambaram bypass -- which is basically a 19.5km stretch of toll road that is closed off on both sides with railings. A multiple-entry ticket and securing your hand-baggage with a seatbelt is the way to go.
Tires were balanced each time they were mounted on the wheel. Tire pressure was maintained at 30psi-cold on each test (Opel recommends 29psi cold).
sAP is offline   Reply With Quote
Old 13th October 2006, 16:56   #2 (permalink)
sAP
sAP's Avatar
Arrow Thread moved
This thread is being discussed here instead http://www.team-bhp.com/forum/tyre-a...oy-wheels.html (Solution for vibrations after installing alloy wheels) (See post #63 & thereon)
sAP
Thread Tools
Solution for vibrations after installing alloy wheels sAP Tyre & Alloy wheel Section 136 11th August 2008 19:57
Meschindo Alloy Wheels Moksh Tyre & Alloy wheel Section 5 9th December 2006 05:02
Minimalist Alloy Wheels theEnd Tyre & Alloy wheel Section 10 4th September 2006 08:31
alloy wheels cowiee Technical Stuff 0 17th April 2006 22:09
Alloy Wheels kashd Tyre & Alloy wheel Section 3 18th January 2006 19:26
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
