Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 13th October 2006, 21:50   #1 (permalink)
aZa
aZa's Avatar
Angry HELP!!: Hit a Stone/cement block cracked a RIM & busted a tyre
Guys, i think u cud help me, a week back driving in noida, a truck ahead of me drove over a bunch of cement blocks used in making a divider. It was all so sudden and one of the cement blocks came on the road before i could react my left front tyre hit the cement block @ 50kmph. the car jumped violently and on stopping near by i saw i had a puncture on removing the tyre i found the alloy rim was slightly bent on the edge (inside). Later on at home i found out that the tyre (Potenza GIII 175/60/13) had a busted sidewall too. Next morning i tried putting my stepney another potenza (same direction) on the alloy and got the air filled. The bent edge wasn't leaking but there was a hair line crack on the bend and that was LEAKING !!!
Anyways i straight away got a single new alloy RIM of the same design. Also got all the wheels balanced and aligned immediatly. Now the tyre guy put my front wheels at the back and back wheels at the front saying front wheels had more wear n tear than the back ones. After getting everything done i drove back home. And now i find the steering is harder than before and the car pulls to the left on breaking. The next day i went to the tyre guy again got the alignment checked and everything. its a bit better now but at low speeds of 20-30kmph with windows up i can hear a rubbing sorta sound from the front wheels.
The car is a Santro Xing XS 2005 with potenza Giii 175/60/13 and 30K on the odo. Do you think that cement block hit has caused any suspension damage??? I didn't find anything evidences of a cement hit upon inspecting the wheel well. The car rides properly today i took it at 130kmph on DND toll bridge no issues watsoever. But that rubby sound as if something is touching the from wheel is very irritating, its not loud and u have to listen very carefully to hear it. Any ideas guys ?
This cement block has already caused me a cracked alloy + busted potenza and now this rubby noise !!!! sux i kno
aZa
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
Old 13th October 2006, 22:13   #2 (permalink)
manveet's Avatar
well aZa .. you should have shown it to one of us .. i know for a fact iraghava is the always readily available for a first-hand inspection
anyways .. i'll give you a call next time i'm in noida .. you never know a fresh eye might throw up something
hoping one of the experts on the forum can figure out your problem .. these small little things are very irritating.
best of luck dude
__________________
Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
manveet is online now   Reply With Quote
Old 13th October 2006, 22:35   #3 (permalink)
Hope to have a reply for you by tomorrow emailing this link to a contact
Nikhilb2008 is online now   Reply With Quote
Old 13th October 2006, 22:57   #4 (permalink)
kpzen's Avatar
Hey aZa..
Check the gap b/w tyre n wheel well(both sides)of the hit tyre n compare it with your front right tyre gap....If there's a difference in gap of left n right tyre this means the hit has caused the wheel to shift a little backwards.....
Solution for this is to get the suspension arm checked or even replaced....
KP
__________________
Prajesh
ECLIPSEd
kpzen is online now   Reply With Quote
Old 14th October 2006, 05:32   #5 (permalink)
iraghava's Avatar
Fatso funny you never pointed it out to me on the phone! But I agree with KP here there's a big chance it might have bent the A-arm on the suspension which might need to be fixed/replaced, I too years back had a somewhat similar problem & the A-arm got bent so had to be replaced. I'll be there on Sunday/Monday give me a buzz & we'll have a look at it.
Sorry to hear about your wheel & tyre though. I did tell you on the phone that there was a good probability that you alloy was gone!
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 14th October 2006, 12:23   #6 (permalink)
rks
rks's Avatar
Tough luck, aZa -- not much you could have done about it. Which raises the question of why these stones are left lying about on the road -- in this case probably after some maintenance/construction work on the divider. I consider this to be criminal and the contractors should be held responsible and punished severely.
A technical doubt. If the suspension arm is bent, won't that reflect in the alignment?
Had several close shaves with stones in recent times on my Santro. Once on the Expressway in the left lane at night -- had to swerve to avoid stones. On the road towards Chunabhatti from Ghatkopar side, there are big stones next to the divider -- very dangerous, and had a couple of close shaves at night. Closest shave happened long ago when heading out from Bangalore in a rented Maruti 800. While following a mini-truck at 50-60 kmph, suddenly found a huge stone on the road which the truck guy straddled -- no way the Maruti could pass over that stone, had to stand on the brakes to avoid a smash up. I have hit stones too, but luckily not very big ones that caused noticeable damage.
Old 14th October 2006, 13:57   #7 (permalink)
suren181's Avatar
Would suggest you get the lower arm checked on your car... preferably with a Hyundai service station. How was the alignment on the car did you check out on that when you got the wheel balancing done?
suren181 is offline   Reply With Quote
Old 14th October 2006, 14:33   #8 (permalink)
kpzen's Avatar
The allignment will be affected n will cause non uniform tyre wear....
KP
__________________
Prajesh
ECLIPSEd
Old 14th October 2006, 16:06   #9 (permalink)
aZa
aZa's Avatar
KP : the left front tyre ( the one that took the hit) is a bit backward now. But strangely after the hit i travelled all the way to karolbagh and back changed the rim etc. the car felt fine steering was light and no noise. Post alignment its become different.
ok another thing while doing the alignment all the colors on the computer screen have to be in the "green" area right >?
__________________
Old 14th October 2006, 23:14   #10 (permalink)
kpzen's Avatar
Get the suspension arm checked by an expert(or replaced) n then get the allignment done n it should be fine.....
While cruising is any noise coming from the front end???? A hissing sound???
It should be green though not sure....But didn't u get a report of the allignment
__________________
Prajesh
ECLIPSEd
Old 15th October 2006, 09:41   #11 (permalink)
viper's Avatar
Hi Aza,
You will need to change your lower arm to have the problem rectified. It is not dangerous but advisable to get replaced as it will affect the handling of the car and cause premature tyre wear. That assuming it to be very soon as you say you get a rubbing sound which if it is the tyre rubbing can be potentially dangerous since rubbing sound = contact = tyres getting heated up = tyre burst.
I think you get the picture.
Viper
__________________
NO ONE DARES COME CLOSE
viper is offline   Reply With Quote
Old 15th October 2006, 12:24   #12 (permalink)
speedzak's Avatar
It's so logical too Aza! You hit a stone and the alloys crack & rubber goes burst. So, you think the suspension will be fine without any problem? You've to get it inspected in whole soon.
And the steering tightness? Should be an alignment cum suspension problem & maybe due to new rubber too.
__________________
Chitty Chitty... Bang... Bang... Boom!!!
27th October 2008.
speedzak is online now   Reply With Quote
Thread Tools
Help on Rim & Tyre change on Mahindra Classic Salikt Tyre & Alloy wheel Section 31 9th July 2008 12:12
Tyre Damage after hitting a large stone. wanderernomad Tyre & Alloy wheel Section 13 25th April 2008 20:13
accents tyre cracked after running 8kms zma Technical Stuff 20 13th November 2007 10:21
Rim and tyre change for Matiz.. Su-47 Tyre & Alloy wheel Section 19 2nd November 2006 11:00
Indigo Rim & Tyre Upgrade viper Tyre & Alloy wheel Section 0 16th January 2006 19:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
