Old 22nd February 2018, 18:57   #16
YakubKC's Avatar
Thanked: 19 Times
Default Re: Hyundai Creta: Tyre & wheel upgrade thread
Could anyone help me with which Tyre to upgrade to for my Creta currently shod with stock 205/65/16? Something reasonably priced and an all rounder will be ideal since the car will be used by the elderly in the family.
YakubKC is offline   Reply With Quote
Old 11th April 2018, 16:08   #17
catchdoon's Avatar
Thanked: 58 Times
Smile Re: Hyundai Creta: Tyre & wheel upgrade thread
Originally Posted by Ricky_63 View Post
I have a Creta 1.6 SX Crdi. It comes with a 16" alloy shod with 205/65/16
I changed these to YOKOHAMA SUV 235/60/16 on day one.
The instant difference in ride quality & braking was evident. The car has done around 8500 kms & I see no reason to complain.
As for the 17" alloys. The best upgrade in my opinion is 225/60/17 or 235/55/17
Check out the Yokos as well (if you like those) they are specifically made for SUV's - hence the name.
Hope that helps
Hey Ricky,
As per your upgrade in the same Rim size, the difference in circumference comes around 2.3% & is NOT recommended by "tyrestore".
Hyundai Creta: Tyre & wheel upgrade thread-capture.jpg
Also I'd like to showcase the tyre size alternative as provided by the calculations from TiresizeCalculator
The alternatives that it provides against the OE 205/65/16 are as under:
Having said that & also read that you had no issues clocking 8.5k Kms until Aug'17, I want to know how have you fared since then.
Also, I'd like to know in detail - since your tyre upsizing isn't in the recommended brackets, What should we consider while upsizing?
Is the 2% recommendation doesn't practically hold up & we can push beyond that?
How did you arrive at your 235/60/16 Calculation?
I'd be very glad to have your insights & inputs
catchdoon is offline   Reply With Quote
Old 11th April 2018, 18:25   #18
Ricky_63's Avatar
Thanked: 394 Times
Originally Posted by catchdoon View Post
Hey Ricky,
The car just crossed 14000 kms with absolutely ZERO issues. I agree the tyre is a tad oversize, by .3% - the tyre I am using is an SUV tyre & not a sedan tyre.
Having said that I would have loved to change my alloys to a slightly wider width but then chose to stick with the OE one.
I did not face any problems till date. Hope that helps
Ricky_63 is offline   (1) Thanks Reply With Quote
Old 30th April 2018, 17:02   #19
9thsphinx's Avatar
Thanked: 468 Times
Upgraded my Creta's tyres to the Accelera PHI 235/55/17 since within a week of taking delivery!
She's run about 20k till date without any issues whatsoever.
The stance has improved and so has the braking by a bit. The Acceleras are a bit noisy though but for the price, they're a good fit at least for city use.
9thsphinx is offline   Reply With Quote
Old 27th May 2018, 13:58   #20
Thanked: 68 Times
What is the specification to be followed for alloys for a creta 1.6 petrol base model having 16 inch tires, I intend to stick on to the OE tire and only swap the rims for a set of alloys.
Will a deep dish alloy fit on OE tires?
gopa99 is offline   Reply With Quote
Old 27th May 2018, 21:54   #21
Screwdriva's Avatar
Thanked: 384 Times
17 inch Michelin tyres now available for the Creta. Expensive but last much longer while providing much better comfort and reliability.
Screwdriva is offline   Reply With Quote
Old 5th July 2018, 12:10   #22
naveen.raju's Avatar
Thanked: 3,812 Times
Anybody here using Michelin on the Creta? I will need to change in the coming months and have shortlisted this. Even though my tyre guy recommended Michelin, he suggested BS since it's more apt for my driving condition (potholes in the city, less highway driving). My current set should last 42k-43k kms.
Any recommendations would be helpful.
naveen.raju is offline   Reply With Quote
Hyundai i10 : Tyre & wheel upgrade thread carZest Tyre & Alloy wheel Section 610 1st August 2018 03:07
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 11 12th February 2018 18:49
ICE upgrade : Hyundai Creta Ad1tya In-Car Entertainment 55 24th September 2017 21:29
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
