Old 4th November 2016, 23:57   #1
Screwdriva's Avatar
Thanked: 336 Times
Default Hyundai Creta: Tyre & wheel upgrade thread
I just booked a 2017 Hyundai Creta Automatic SX+ variant that comes shod with 215/60 R17 rubber. I was surprised to see that Michelin doesn't make a tyre in this size (and only Pirelli does) with 225/55 R17 being the closest size possible.
As a die hard Michelin user for the past 15 years, I find it hard to consider other brands. I'm hoping TBHP can convince me to 1) Purchase Michelin 3ST in 225/55 R17 as an upsize OR 2) Consider your experiences to switch to Pirelli OR 3) Suggest another option I hadn't considered.
Top criteria for me are:
1) Softest ride possible
2) Low rolling resistance
3) Long life
Thanks for the help!
Screwdriva is offline   Reply With Quote
Old 7th November 2016, 12:34   #2
RavenAvi's Avatar
Thanked: 23,428 Times
Default Re: Hyundai Creta: Tyre & wheel upgrade thread
You can go with the Pirellis, no problem. Noise levels are excellently controlled, and Pirellis usually have low rolling resistance as well. The lifespan of a Pirelli tyre is also up there with the best (although Bridgestone has all/most of them beat). Haven't used Pirellis yet, but these are feedbacks which I have received from other owners till now.
Of course, nothing can beat the ride quality which a Michelin provides.
But, if you have been using Michelins for a long time now, 225/55 R17 is a worthy option. You won't be upgrading the tyre size per se, because the circumference of the Michelins is about ~1.5% lower than stock size.
Translates to - better grip due to the wider patch in contact with the road, and a more plusher ride. Negative - a slight compromise in FE numbers.
Another option which is available in stock size is Bridgestone Duelers (link), but between all 3 options, I would suggest changing to Michelins.
All the best.
RavenAvi is offline   (1) Thanks Reply With Quote
Old 7th November 2016, 13:13   #3
Nikhilb2008's Avatar
Thanked: 2,995 Times
Please do not use a passenger car tyre on an SUV.
You have an SUV. Stick to SUV patterns. Please do not consider a Michelin P3ST. Because of the large weight on the tyre, you have a higher chance of sidewall damages, etc... I know the Creta isnt a full size SUV, but personally, I'll be a bit wary.
Also, you cannot have long life and softest ride possible in the same sentence... it's like asking you want the most expensive product at the cheapest price. If a tyre is soft, it will not last long. If it lasts long, it wont be soft.
In 215/60-17, the stock tyre is usually Nexen.
The only other option is the Bridgestone Dueler. It is an SUV pattern and should give you a long enough life.
In 225/55-17, you have quite a few options but all are car tyres. Not SUV tyres.
Michelin P3ST, Pirelli P1, Continental CPC2, Yokohama Advan Sport.
Personally, I will recommend you just leave it as it is and use the stock tyres. If you're uncomfortable with a brand like Nexen, then go for the Bridgestone.
Nikhilb2008 is offline   (6) Thanks Reply With Quote
Old 8th November 2016, 10:28   #4
Screwdriva's Avatar
Thanked: 336 Times
Thanks for weighing in! Looks like the Diesel Creta weighs in at around 1400 kgs. That appears to be easily well within the 3ST's ability.
I own Michelin's and have experienced them to last around 50K Kms and they are known to be quite soft, so I'm not sure if the two are mutually exclusive.
Old 8th November 2016, 13:25   #5
kpzen's Avatar
Thanked: 1,343 Times
Hey,
Michelin Primacy 3ST 215/60 R17 is coming soon.
May be in another 3 to 4 months.
Hi Nikhil
Have you tried the Bridgestone S001 ?
If you have, please do share your experience.
kpzen is online now   Reply With Quote
Old 9th November 2016, 10:58   #6
Hey,
Hi Nikhil
I havent... I probably wont anytime soon. It is an RFT only as of now.
225/55-17
205/55-16
225/50-18
245/45-18
245/50-18
and a couple of other sizes.
Nikhilb2008 is offline   (2) Thanks Reply With Quote
Old 30th April 2017, 10:04   #7
Thanked: 18 Times
Hi guys,
A very close friend has booked a Creta 1.6 VTVT SX+ and we would like to upsize to 17" wheels and mags.
Please correct me if i'm wrong, but the original 17" 'diamond cut' alloys that Hyundai provides on the higher variants have a rim width of 6.5J.
How wide can we go on 6.5J ?
Coming to the tyres, we had also originally decided on the Michelin Primacy 3ST in 225/55R17 but i was wondering along the same lines as to what Nikhil has posted above. Sedan tyre v/s SUV. Would Michelin Latitude Sport be a better option here ? What sizes are they available in (in R17s) ?
Appreciate your expert inputs.
Thanks.
revvhed is offline   Reply With Quote
Old 30th April 2017, 11:41   #8
Thanked: 18 Times
Sorry for the back to back posts but the edit time limit had expired.
While going through the Michelin site i see that there is a new (?) tyre called the 'Primacy SUV'.
Other options are the Latitude Sport 3 and the Latitude Tour HP.
Available sizes are ;
Primacy SUV - 225/65 R17
Latitude Sport 3 - 235/55 R17 // 235/65 R17
Latitude Tour HP - 225/65 R17 // 235/60 R17 // 235/65 R17
From all the sizes I see above it appears that the idea upsize is 235/55 R17 but i think that may be overkill.
All the other sizes have too much of a variation in total diameter.
What are your opinions on this ? Am i thinking correctly ? Are there any other sizes / brands i should explore ?
Too much confusion. Experts please help. All opinions welcome.
Thanks.
revvhed
Old 30th April 2017, 11:59   #9
Thanked: 15 Times
Thanks.
revvhed
If youre upsizing to 17inch wheels I would say stick to the stock size of 17inch diamond cut models i.e 215/60r17. It is adequately tired especially for the petrol variants. The tires that come from factory, Bridgestone Dueler Sport on those models are pretty good so you can look at those.
Edit: does your friend not like the design of the diamond cut alloys? Asking because he could go in for the new dual tone variant which comes with 17in diamond cut alloys.
rayjaycleoful is offline   (1) Thanks Reply With Quote
Old 30th April 2017, 20:18   #10
Thanked: 18 Times
Hey rayjay,
Thanks for the prompt response. Yes he does like the diamond cut alloys. However, he doesn't like the dual tone colour scheme and it's also not available on the colour he's chosen (Mystic Blue). Hyundai refuses to sell us the mags separately. However, a friendly neighbourhood tyre dealer has offered us the diamond cut mags as he recently had a customer who swapped these for another design. Now, confused about what tyres to choose.
The Michelin Primacy SUV seems nice but the size variation is too much. :(
Old 30th April 2017, 20:21   #11
Thanked: 18 Times
Hey Screwdriva,
So what did you do eventually ?
Old 30th April 2017, 21:07   #12
Screwdriva's Avatar
Thanked: 336 Times
We were going to go for the Michelins. Sadly, we had such a bad experience with the dealer Pramukh Hyundai that we decided to cancel our purchase and wait for the refreshed model coming in 6 months. That's when we'll go for the Michelins
Screwdriva is offline   (1) Thanks Reply With Quote
Old 30th April 2017, 21:21   #13
Thanked: 18 Times
Which Michelins and what size ?
Old 30th May 2017, 18:29   #14
Thanked: 18 Times
Hey,
Hey kpzen .. any idea if Michelin is indeed launching this size ?
Nikhil .. any insider info ?
This is really proving to be a troublesome exercise. Any help / advice would be appreciated.
Thanks.
Hyundai Getz : Tyre & wheel upgrade thread viper Tyre & Alloy wheel Section 109 7th June 2017 10:58
Hyundai Santa Fe : Tyre & wheel upgrade thread ashimitt Tyre & Alloy wheel Section 10 4th June 2017 10:16
Hyundai i10 : Tyre & wheel upgrade thread carZest Tyre & Alloy wheel Section 607 25th April 2017 19:32
ICE upgrade : Hyundai Creta Ad1tya In-Car Entertainment 53 12th March 2017 14:33
Hyundai Accent : Tyre & wheel upgrade thread Ripper Tyre & Alloy wheel Section 33 14th May 2015 22:55
