Old 6th August 2009, 00:54   #46
iraghava's Avatar
Thanked: 156 Times
That is something you can't avoid man. Normal environmental degradation will make them crack in about 4-5 years time any way. No way to avoid that apart from regular usage of the car.
Old 6th August 2009, 02:34   #47
yogisays0909's Avatar
Thanked: 189 Times
So in that case, should i opt for tubeless tires or the one with tubes?
yogisays0909 is offline   Reply With Quote
Old 6th August 2009, 13:37   #48
iraghava's Avatar
Thanked: 156 Times
Tubeless tyres are better. With tubes you increase your chances of getting flats.
Old 6th August 2009, 14:46   #49
esteem_lover's Avatar
Thanked: 451 Times
Have to agree with iraghava here. Get a set of tubeless 13" tyres. Michelin XM1s are pretty decent & last too.
Old 6th August 2009, 15:43   #50
shreyasma's Avatar
I had 185/60 R13 apollo Acceleres on my esteem on the stock rims. I heard this the max size on a stock rim.
Stick to the size you have now and TUBELESS :-)
shreyasma is offline   Reply With Quote
Old 7th August 2009, 01:31   #51
Venom_rider's Avatar
Thanked: 50 Times
Please correct if I am wrong, but on a 4.5J sized rim 185 would be an overkill. It will certainly cause your tires to bulge. I would strongly suggest to stick to 175/70 R13.
Venom_rider is offline   Reply With Quote
Old 7th August 2009, 11:57   #52
Thanked: 189 Times
Alright guys will stick to 175/70 R13..., will a budget of 25-30K be enough for tyres and alloys.?
Old 7th August 2009, 21:58   #53
Thanked: 50 Times
Yup... 30K should be good. The cost of XM1+ should be around 15K for the 175s. From what I've heard the alloys cost a lot cheaper in Mumbai... so, I guess the whole cost will fall within your budget.
Honda City Rim size - does it fit an Esteem Jeep Tyre & Alloy wheel Section 4 9th May 2009 12:06
Rim Size Upgrade for Indica V2 DLS zzzehar Tyre & Alloy wheel Section 12 5th December 2008 15:54
Stock rim / tyre Size on a BMW 7 Series ? blueraven316 Modifications & Accessories 8 9th February 2008 21:45
rim size kpzen Tyre & Alloy wheel Section 0 20th November 2005 22:25
