Old 30th November 2006, 12:33   #16
sreenivass's Avatar
Default Question to Prabuddha
Originally Posted by prabuddhadg View Post
That is a good idea. I shall try that tomorrow morning when I plan an air check up.
prabuddha a question not related to PSI. Your petra ia an ELX right, does it come with ABS and Airbags ?
sreenivass is offline   Reply With Quote
Old 30th November 2006, 15:18   #17
Firebird's Avatar
Thanked: 61 Times
I checked in the Palio 1.6 Owner's Manual (Page 143), which says
Medium Load
Front - 19 Rear - 1.9
Full Load
Front - 2.2 Rear - 2.2
Spare - 2.2
I maintain 29 in from and Rear but dealer said 28 at front and 30 at rear.
Firebird is offline   Reply With Quote
Old 30th November 2006, 15:52   #18
sivadas's Avatar
Thanked: 171 Times
I think ABS and Airbags are optional.
sivadas is offline   Reply With Quote
Old 30th November 2006, 16:01   #19
Thanked: 64 Times
Originally Posted by hellspawn View Post
so i guess 30 should be okay cos the mean of the two(27+32/2) works out to 30
Naah. It can actually be bad. It doesn't serve purpose when you drive in city with light load. It is over-inflated. While if you take it out on highway with high load, it is under-inflated. So, either ways it doesn't serve purpose. Better is maintain right pressure. I use my car mostly alone during weekdays, so I should be maintaining 28 PSI.
RX135 is offline   Reply With Quote
Filling the right 'Pound per square inch (PSI)' Surprise Technical Stuff 92 21st May 2018 21:28
My Turbo charged Baleno - now 116 whp @ 6psi Edit:145whp at 11 psi! binz Modifications & Accessories 128 13th February 2012 10:18
New PSI Tuning Box for Hyundai Verna jerish666 Modifications & Accessories 47 12th December 2008 14:36
What's the correct PSI ?? groovyanubhav Tyre & Alloy wheel Section 2 5th October 2008 11:38
Swift + Yokohoma S drives 205/50 = What psi? inder_s1 Tyre & Alloy wheel Section 9 15th September 2008 19:14
