| Tyre & Alloy wheel Section Everything to do with footwear for your car! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Aug 2006 Location: Chennai
| I am buying a Baleno LXi today and need advice on the following. I am switching to 14" Alloys (Aura) and GoodYear NCT 185/65 Tubeless (thanks to all the help from Nitrous and Samurai). I need some details on Offset. 1. What is the Offset for Steel Rims (LXi). I have not been able to check out the same. 2. I checked the Offset for Stock Alloys in VXi (Aura - 14"). The Offset if 40mm Positive. 3. Can I assume it will be same for LXi also (steel rims) ?. Would Maruti have tuned suspension differently for LXi and VXi ?. I think not and hence assume the offset be the same for LXi (Steel Rims) and VXi (Alloys). 4. The Alloys I have decided to purchase has an Offset of 44mm Positive (as per Aura Website). I still have'nt check the stamping in the alloy to confirm. WOuld this difference of 4 mm make a big difference. Can anyone help clarify ?. I am taking delivery of the vehicle this evening and changing the tyres / rims immediately. Thanks. |
| | #2 (permalink) | |
| Team-BHP Support ![]() | Quote:
EDIT: make sure it is 5.5J and not 5J
__________________ Samurai The notchy gearshift of GV has become buttery smooth after I started driving the Jeep. | |
| | #5 (permalink) |
| BHPian | hey subbu the wheel details for the baleno is p.c.d. 4 x 100 offset 35..38 c/bore 54 so any rim any size just make sure pcd is 4x100 and offset between 35..38 hope this helps Later JRD [COLOR=#006666][/COLOR] oh forgot to add .. doesnt matter if its 14x6 or 14x5.5.. its the width of the rim. so if the pcd and offset are the ones i gave you . they will fit.. so my suggestion is 185/60 wheels on 14x6 rims Last edited by Samurai : 30th November 2006 at 11:14. |
| | #6 (permalink) |
| Samurai / JRD... D1455 is the Stock Alloys for Baleno VXi and its Offset is 40mm. I am sure the Offset of the Steel Rims (LXi) is different. I am sure Baleno has kept the same suspension setting for both the cars. I am looking at Aura EO1455 (not listed in their site) and the offset is 38mm. Final advice pls. |
| | #7 (permalink) | |
| BHPian | Quote:
hey subbu.. sorry couldnt get back sooner.. but yeah if the rims on the vxi (newone)with 14s has 40 offset and looks fine then it will fit on your lxi. there is no technical change between the lxi and vxi expect for the wheel size.. the offset determines how much the wheel sticks out.. so the lower the positive offset, the wheel will stick out that much more.. hope you get it? so anyway. if the vxi's wheel is 14x6 with 40mm offset, and the rim you are looking at is 14x6 with 38mm offset, your wheel will stick out 2mm more than the vxi's wheel.. as simple as that.. so my advice dont worry about it.. the rim with 38 mm offset will look just fine.. hope this clears things out. Later JRD. | |
| | #8 (permalink) |
| JRD... I checked the Alloys physically (D1455 - stock for VXi) and the offset is 45mm. I know it is different from what I posted earlier but that was based on Dealer info. I have fixed Alloys with 45mm Offset. I have not experienced any issues so far ( I have driven 450 kms with new alloys). While the Tire Dealer has offered to exchange if required, I have not felt the need so far. |
| Thread Tools | |
Similar Threads | ||||
| Estilo Upsizing | deville_56 | Tyre & Alloy wheel Section | 1 | 14th July 2008 11:12 |
| SOS - Urgent.. lost keys for baleno along with the remote | kiranpashtakar | Technical Stuff | 14 | 17th December 2007 18:50 |
| 2004 Baleno Demo car .... URGENT ! | speedemon | Sedans | 27 | 24th May 2006 18:56 |
| FE in upsizing | srasania | Tyre & Alloy wheel Section | 1 | 22nd May 2005 22:49 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
