Old 4th December 2006, 17:57   #1
Question Wheel alignment query.
I put Aura alloys and BridgeStone Turanzas this Saturday on my Santro. The tyre dealer did all the fitting. He did wheel balancing but no alignment. His alignment mechanic had also not come that day.
When I asked for alignment he said that just wheel-balancing is sufficient and alignment needs to be done only after 4000KMs. Is this true??
Now my doubt is how will the original alignment be retained when I have changed all my wheels & tyres??
Please respond.
Thanks in advance,
RS
ronline is offline   Reply With Quote
Old 4th December 2006, 22:24   #2
Nikhilb2008's Avatar
Thanked: 6,619 Times
Where did you get it done in Bangalore ??
Nikhilb2008 is online now   Reply With Quote
Old 4th December 2006, 22:51   #3
2fast4u's Avatar
kick his a$$
when he has changed all 4 just as the balancing is done so should the wheel alignment. get it done asap. it is a MUST
it is very important to get even tyre wear and proper track for the tyre itself.
2fast4u is offline   Reply With Quote
Old 5th December 2006, 00:20   #4
aZa
aZa's Avatar
Thanked: 17 Times
ronline : Balanacing and alignment is usually free when u purchase new tyres so get the alignment done ASAP! and what profile tyres have u put ?
Old 5th December 2006, 00:33   #5
danlalan's Avatar
Thanked: 135 Times
get your alignment done. if he says no...then insist that you've spoken to experts and it is a must..FREE OF CHARGE of course...
danlalan is offline   Reply With Quote
Old 5th December 2006, 11:33   #6
Thanks for your reply guys. I'll ensure that it happens asap. Btw I put 165/65/R13. It looks pretty good. A bigger size would have been a bit disproportionate I think.
Rgds,
RS
Old 5th December 2006, 15:30   #7
iraghava's Avatar
Thanked: 156 Times
That's a good size on the Santro, have run 3 sets with this size on 2 cars of mine & never had any problems.
Old 7th December 2006, 00:27   #8
WasavaTyres's Avatar
Thanked: 255 Times
Smile
Originally Posted by 2fast4u View Post
kick his a$$
Well if you're talking about the "free" part then I guess you'd want to get it done from him or get a credit note made out so you can do it later.Besides that technically speaking you don't need to get your wheel alignment simply 'coz you had your rims taken off the hub and fitted them back.Wheel alignment is done / measured by the tie-rod ends and camber bolts on your vehicle.Since none of these are disturbed while fitment of tyres is done you don't have to worry about your car being misaligned.Just like you don't get your wheel alignment re-done every time you chnage your spare tire after a flat !!
Originally Posted by vikram_d
I'm no expert but here is what they mean in lay mans terms
Wheel balancing means to ensure that is there is no rotational distortion in any wheel. Simple example is to put a wheel on any free rotating rig and rotate it by hand. When it stops rotating mark the point which is towards the ground with a chalk or crayon. Rotate it again, if the wheel is balanced properly the same marked point should not be pointing to the ground. If it is not balanced properly you will find that the chalk mark points towards the ground everytime.
Wheel balancing is done to ensure that the weight is distributed around the circumference of the tire in a uniform manner.As tires are made up of a number of materials like natural rubber,silicon,metal wires,nylon cords etc the weight is not evenly distributed.What happens in this case is that when it rotates the point of the tire that is the lightest is pressed towards the ground more 'coz of the force of centre of gravity,hence you see imbalanced tires having spotty wear.When the balancing weights are added on to the rim thuis problem is solved.It is precisely due to this extra pressure and the tire getting pulled towards the earth with more force at teh point of imbalance that you experience "wobbling" on the steering wheel when you do high speeds on unbalanced wheels.
WasavaTyres is offline   Reply With Quote
Old 8th December 2006, 11:32   #9
Rehaan's Avatar
Thanked: 25,038 Times
Note from Mod - Some post have been moved to a more relevant thread > http://www.team-bhp.com/forum/techni...alignment.html (Newbie questions - wheel balancing, wheel alignment.)
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
