Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 11th December 2006, 19:40   #1 (permalink)
Default Tyre Repair..No No
My friend discovered that there was a 1cm long/1cm wide gash on his Wagon R tyre .The tube was damaged badly b'coz the sharp object tore through the tyre into the tube.
The friendly neighbourhood tyrewalla offered him a 155/80 r13 tube which he obviously refused.A new tube of the correct specification in place, ,the tyre walla put in flap(piece of tube) to cover the gash and then the wheel was put back..the result..severe wobbling at speeds >60kmph.
Short cuts are a strict no no having experienced this.
__________________
Som
Challenge The Impossible!!!!!
Old 11th December 2006, 19:57   #2 (permalink)
jango's Avatar
Rethreading the tyre is not adviceable for cars, but on the other hand lot of people do it for Jeeps....Jeeps can take that, i have even heard that re threaded tyres can cause damage to the suspension of cars if used......
__________________
Wounds Heal & Bones Set DRIVE FAST !!
jango is offline   Reply With Quote
Old 11th December 2006, 20:11   #3 (permalink)
iraghava's Avatar
Was this cut on the treaded portion of the tyre or on the sidewall?
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 11th December 2006, 21:09   #4 (permalink)
CrAzY dRiVeR's Avatar
Checked alignment and balancing???
Might have changed if they removed the wheels and put it back...
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 12th December 2006, 16:19   #5 (permalink)
esteem_lover's Avatar
you mean treading & re-treading, dont you ?? this topic is not about re-treading anyway.
@vigsom. it is absolutely unsafe to drive like this. ask your friend to change his tyre & tube immediately.
__________________
Advertisements contain the only truths to be relied on in a newspaper. - Mark Twain
Old 10th January 2007, 19:47   #6 (permalink)
This tyre is not serviceable. Discard it off before you have a disaster.
__________________
sn48001
sn48001 is offline   Reply With Quote
Thread Tools
iPod Repair? Sahil Gadgets, Computers & Software 19 28th July 2008 10:19
Puncture (tubed tyre) and tyre type/age rex_varghese Tyre & Alloy wheel Section 2 13th November 2007 19:19
Need Help - Alternator repair santhoshx Technical Stuff 4 12th October 2006 18:38
Gash in Tyre at the edge of the tread...safe or trash the tyre ? zaphod Technical Stuff 8 31st August 2006 13:24
Help Required - Tubeless Tyre Repair vigsom Tyre & Alloy wheel Section 7 20th June 2006 21:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
