Old 23rd February 2007, 13:41   #31
devarshi84's Avatar
Thanked: 118 Times
Update:- our Mitsu Dealer in Ahmedabad Autonova has been kind enough to get us the tires we want at dealer discount price.
I am currently leaning more towards bridgestone Turanza ER60 195/60 R14
because Michelin has more tyre wear. But if the dealer service guys recommends Michelin 185/65 R14, I may go for those.
WIll be getting the rubber tomorrow. will post pics and update as soon as possible.
(PS: I am getting a 4 pc 15-inch aura alloys for 18750. Any design I want. Discounts possible further. Is that a good price?)
devarshi84 is offline   Reply With Quote
Old 23rd February 2007, 17:33   #32
devarshi84's Avatar
Thanked: 118 Times
Have decided to go for Michelin XM1 185/65 R14. The Mitsubishi Dealer service manager specially called the tyre guy.
Maniar tyre at Judges bungalow is a Bridgestone performance club shop. He still recommended MIchelins over Turanza Er-60's.
Also got to see soe b250 brand of tyres under bridgestone there.
Old 25th February 2007, 11:25   #33
devarshi84's Avatar
Thanked: 118 Times
Got Michelin XM1's installed. the finaly price was Rs3410. The tyre wells certainly look better now. I got the 185/65 R14's
The steering is slightly hard but the tyre guy said it will be ok in about a 100kms.
Ride is soft for sure and tyre noise is out too. Will check the tyres better in the upcoming road trip.
thanks guys for your imputs.
Old 25th February 2007, 12:01   #34
Vid6639's Avatar
Thanked: 19,386 Times
Devarshi lets have some pics of the new tyres on the car and how the stance of the car is now. also close up of the michelins.
Old 25th February 2007, 13:43   #35
kpzen's Avatar
Thanked: 1,599 Times
Congrats Dev.!!
Hope u also got allignment n balancing done too....
kpzen is online now   Reply With Quote
Old 26th February 2007, 09:33   #36
devarshi84's Avatar
Thanked: 118 Times
yep. got the alignment and balancing done their. Our Autonova Mitsubishi dealership service people I would say took good care of us. I would rate them 8/10
edit: WILL POST PICS SOON.
Old 28th February 2007, 19:03   #37
karthik247's Avatar
Thanked: 16 Times
Off Topic
Guys i'm using Yokokama tyres in the car. The rear ones seems to have developed a small bulge on the side wall. So i know if have to chage it, but does it mean i have to change it asap, i mean really asap!??
The tyres have done about <10k kms only. No uneven tyre wear or anytin..just the bulge. So what should i do?
karthik247 is offline   Reply With Quote
Old 28th February 2007, 19:09   #38
iraghava's Avatar
Thanked: 154 Times
That is the result of big potholes & small sidewalls!! With the size you're running this was always a possibility especially with your driving style.
However it is advisable to replace the tyre with a new one or use it in the spare and use it sparingly. I would recommend you put it in the spare & change it when you have the money. Also avoid putting this tyre on the fronts since then you'll get a lot of wobble on your steering wheel.
Old 28th February 2007, 19:12   #39
karthik247's Avatar
Thanked: 16 Times
I have only four alloys and four Yokos. The spare is the stock tyre on stock rim :(
So i guess i'll have to change it then.. Any tips on using it till i get a new one?
Old 28th February 2007, 19:15   #40
iraghava's Avatar
Thanked: 154 Times
Keep it on the rear axle, preferably where it is right now. Keep a regular check especially for sidewall cuts & low-pressure. Don't push the car too much especially when on cratered roads.
Also were these with warranty? You could try getting them replaced from the dealer.
Old 28th February 2007, 19:18   #41
karthik247's Avatar
Thanked: 16 Times
I'm using Nitrogen in the tyres but will keep a check on pressure anyways. Its a very very minor bulge, u can't notice it easily unless u look closely. But i think its better n safer if i take it easy while driving.
I got the tyres from Bangalore, will find out about the warranty. They about 8-9months old.
Old 28th February 2007, 19:45   #42
rks
rks's Avatar
As noted by iraghava, it looks like your low-profile tyre took a beating on bad potholed roads. If at all there is any scope for increasing tyre pressures, I would strongly recommend that. Because sidewall damage at < 10000 kms is unusual and low pressures are one possbility, apart from bad roads/manufacturing defect. This is especially true if you drive at higher speeds.
Old 28th February 2007, 19:47   #43
karthik247's Avatar
Thanked: 16 Times
I'm using 205/50 R15 tyres. That guy filled it with 28psi. Is it low? There won't be more than 3ppl in the car max so could someone recommend the correct pressure..
Should i ditch the N2 and get it filled normally. I didn't notice or feel any big differece except for the price.
Old 28th February 2007, 20:06   #44
rks
rks's Avatar
Looks to me like 28 psi is quite low especially if you are prone to speeding. If I were you I would operate at substantially higher tyre pressures -- maybe 32-33 psi. Ride will undoubtedly be harsher, but I personally don't care about that. I don't know what would be the ideal pressures for your car, but I think for fast driving you should definitely increase the tyre pressures well above the manufacturer's recommendation since you have upgraded to low-profile tyres.
If you use normal air you can get your pressures checked, say, once in 2 weeks. I would always prefer that, since I am now hyper-fidgety about getting tyre problems while on the Expressway. I also have my own accurate pressure gauge and portable inflator. With N2 you can only check less frequently (maybe once a month?) and you should have the filling point availiable before checking -- otherwise frequent checks will only serve the purpose of letting out some N2 and reducing your pressures.
Old 28th February 2007, 21:51   #45
karthik247's Avatar
Thanked: 16 Times
The recommended pressure for stock tyre (165/80 R14) is 32psi i think. I guess i'll get 30psi normal air unless u guys want me to keep the N2 and if it really does make a diff (which i don't think it does)
And does more pressure mean less grip?? I usually drive only in the city, maybe a max speed of 100kmph, very rarely hit the highways. So i need a balance btw handling/grip as well.
HELP! Uneven rear tyre wear in Wagon-R ravi@64bhp Tyre & Alloy wheel Section 13 4th July 2016 17:02
Uneven Tyre Wear? IMP Technical Stuff 31 4th June 2012 18:02
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Tyre wear woes brainscooper Tyre & Alloy wheel Section 8 23rd March 2008 22:04
Uneven Tyre wear!? - Goodyear GSD2 Eagle F1 anarchist Tyre & Alloy wheel Section 4 10th March 2006 13:00
