Old 10th February 2007, 13:43   #1
paras211's Avatar
Thanked: 57 Times
Question tyre pressures for the drag
what would be the ideal pressure for the speed run ??
30psi s recomended would 30 be best or should there be a little less giving a little more grip
paras211 is offline   Reply With Quote
Old 10th February 2007, 15:23   #2
karan561's Avatar
Thanked: 10,517 Times
if ur tyre size is 195/55 r/15 ... which is the standard on a corolla then u should go in for 28 psi ......
karan561 is online now   Reply With Quote
Old 10th February 2007, 16:42   #3
kpzen's Avatar
Thanked: 1,655 Times
Corolla tyre size is 195/60-15
Old 10th February 2007, 19:18   #4
karan561's Avatar
yeh sry 195/60 r/15 ....
but then 2 i think 28 psi , should give be ideal for the drag ....
thnx # kpzen .....
Old 12th February 2007, 16:34   #5
paras211's Avatar
Thanked: 57 Times
its 205 60r 15
karan you entering ???
Old 13th February 2007, 01:01   #6
karan561's Avatar
naah .... i have my exam on that very day from 8am - 12:30 pm and i geuss the drag timings are from 7:30 - 2-3 i geuss .....
will b cumin on the 18th just to have a look , but no point u c ....
Old 13th February 2007, 20:24   #7
n_aditya's Avatar
Thanked: 2,779 Times
I guess filling in 3-5 psi more is ok considering an under-inflated tire can slow you down. Slight over-inflation reduces contact area so any unnecessary traction is reduced at least to some extent.
Old 13th February 2007, 21:21   #8
revtech's Avatar
Thanked: 35 Times
true i was thinking of the same thing but wont over inflating it spoil his launch.that will make him lose tractiion while launching.
revtech is offline   Reply With Quote
Old 13th February 2007, 21:25   #9
paras211's Avatar
Thanked: 57 Times
hey you confusing me now what pressures should you keeping
Old 13th February 2007, 22:28   #10
The Wolf's Avatar
Thanked: 58 Times
Well, my 2cents, tyre pressure is dependent on how much power your car is generating, launch technique, ambient temperature while fillup and during the drag day and ofcos the profile and make of the tyre. If you could furnish these details I should be able to recommend the ~ ideal tyre pressure...
The Wolf is offline   Reply With Quote
Old 13th February 2007, 23:54   #11
paras211's Avatar
Thanked: 57 Times
i think the temp should be around 28 celcus
i am planing to minimize wheelspin so i ll TAKE OFF at bout 2500 rpm
should be about 135 145 hp at the crank
205 60 r 15
michlines and the tread i dont know how to describe its not the v tread
How often should I check my tyre pressures? rajesh1868 Tyre & Alloy wheel Section 73 10th August 2015 19:13
Correct Tyre Pressures Kaizer Sozay Tyre & Alloy wheel Section 83 7th March 2015 19:56
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Uneven tyre pressures Hells Bells Technical Stuff 8 13th November 2006 15:27
Tyre pressures for various performance tyres theMAG Tyre & Alloy wheel Section 1 17th June 2006 10:08
