| LinkBack | Thread Tools | Search this Thread |
| | #17 | |
| Senior - BHPian | Quote:
or the radurra clear wheels ![]() Last edited by faithless_1984 : 11th March 2007 at 01:13. | |
| | #18 | |
| BHPian Join Date: Jan 2007 Location: Mumbai
Thanked: 27 Times
| Quote:
Your problem is the tyres protruding out of the wheel arches and nothing else. I had faced the exact same problem wih my 800. I had fitted 12" alloys and stock radial tyres on it. The design of the alloys were such that the wheels used to protrude out of the wheel arches by an inch. I never made a single change with the tyre size or rims. The front wheels used to scrape the wheel arch during a full turn and the rear wheels used to scrape on full load. I never understood the reason but realised the reason was only the protruding wheels and nothing else. My advise is to stick to alloys which do not bulge out. I do agree they look hot, but not at the cost of damaging the vehicle. Epic | |
| | #19 |
| Team-BHP Support ![]() | Hi mb_Jg please keep us updated on this problem. I am eager to know what went wrong here. |
| | #20 |
| BHPian Join Date: Feb 2006 Location: Pune
Thanked: 88 Times
| Am getting the left suspension checked this weekend. Pretty sure that it's a suspension problem, which is a bit difficult to digest since the car is just about 2 months old. Overall those type of alloys do pose a prob with most vehicles since they protrude a bit. But, nevertheless, I will keep you guys posted. Thanks for all your inputs & help guys. |
| | #21 |
Thanked: 88 Times
| Hi Rehaan, the dealer did say that 13" rims should not be a prob for the Palio. I am running on stock tyres at the moment which I believe are 165's. The side of my car is not sagging, overall it's a brand new car. |
| | #22 |
Thanked: 88 Times
| Hey, this is exactly what it looks like. Looks like the alloys in the picture have 6 spokes, mine has 5. |
| | #23 |
| BHPian | I'm just back from a Thrissur-Palakkad-Thrissur run in my Linea. The highway (NH 47) has some terrible stretches. On getting back to town and doing a round-about, I noticed that the left front wheel was rubbing against the wheel well when turned fully to the right. Now I had maintained only very reasonable speeds, and don't remember hitting any pot hole at great speed. Is this only a simple mis-alignment or am I in for major repairs like a bent axle or something? ![]() Please give some advice! |
| | #24 |
| Senior - BHPian Join Date: Sep 2010 Location: Pune > Manipal > Gurgaon >Bangalore
Thanked: 768 Times
| Do you find any issues with wheel alignment/balancing? As in, car pulling to any side. Is the wheel rubbing the plastic wheel arch? If that's the case, the arch might have come loose. Else, could be something with the suspension. Probably it is not opening up completely. Last edited by libranof1987 : 5th October 2011 at 19:35. |
| | (1)
| | #25 |
| BHPian | The car was perfect till today's drive. Have done only 8000 kms. I got the alignment and balancing done at 5000 kms. I haven't noticed any pull to the sides, but haven't actually tried taking my hands off the steering after I noticed the scraping. Anyway, I'll be taking her to the tyre shop first thing tomorrow. |
| | #26 |
| Senior - BHPian | Could as simple a problem as the wheel well getting loose and sagging on to the wheel. Just check if the wheel well is loose. Cheers KPS |
| | (1)
| | #27 |
| BHPian | The plastic wheel well liner may be loose or bent due to any hit at bottom of liner while on move. If it is fine, then check wheel nuts. |
| | (1)
| | #28 |
| Senior - BHPian | Issues I can think of are : - Bent suspension lower arm - Stabilizer bar rubber bush worn out or damaged Its important to get your car checked ASAP! |
| | (1)
| | #29 |
| BHPian | Thanks for the input, everyone. I guess I should be taking the car to TASS and not the tyre shop! At first look, I wasn't able to discern where exactly the wheel was scraping the arch. Hope it wouldn't be something major! |
| | #30 |
| BHPian | If you have access to an ramp, in your neighborhood garage or service station, you check yourself before taking to A.S.S, so that you can see and feel what is wrong, by turning wheel in ramp. This will save you time and cost, by getting source of problem |
Similar Threads | ||||
| Downsizing wheel / tyre | devsoftech | Tyre & Alloy wheel Section | 32 | 31st August 2012 19:18 |
| Tyre + Wheel Upgrade on BMW 320i | Saarth | Tyre & Alloy wheel Section | 10 | 1st July 2012 21:53 |
| NHC tyre and wheel upgrade!! | nikkibike | Tyre & Alloy wheel Section | 12 | 4th October 2007 19:02 |
| baleno wheel & tyre | gigy | Shifting gears | 3 | 19th May 2007 22:18 |
| Best tyre-wheel combo | theMAG | Tyre & Alloy wheel Section | 1 | 16th May 2006 10:00 |
