Old 6th October 2011, 02:26   #31
vigsom's Avatar
Thanked: 606 Times
Default Re: Wheel rubbing against wheel well
^^ +1 to that
It is better to check it out yourself ; and if you get to the root,you'll feel good that you solved the problem yourself.
Old 6th October 2011, 11:45   #32
one-77's Avatar
Thanked: 208 Times
It was indeed the loose plastic cladding that the wheel was rubbing against. I pushed it back into place, and the sound disappeared. Couldn't get the cladding replaced, however, as TASS wasn't open today.
one-77 is offline   Reply With Quote
Old 6th October 2011, 13:11   #33
toiingg's Avatar
Thanked: 85 Times
Its probably some clips which hold the cowl into place that have dropped off. Get them replaced.
toiingg is offline   Reply With Quote
Old 6th October 2011, 17:18   #34
libranof1987's Avatar
Thanked: 4,221 Times
Default Re: Tyre Scraping Wheel Arch
Nice and easy then.
I think it is held in place by screws.
Unless the plastic arch has torn apart, just changing the screw will do the trick.
libranof1987 is offline   Reply With Quote
Old 6th October 2011, 20:53   #35
one-77's Avatar
Thanked: 208 Times
It has broken off at a point where it is screwed to the wheel arch. Will need replacement.
Art of taking Speed Breakers(humps) without scraping the belly. dhanushs Technical Stuff 66 26th April 2016 11:32
Upsized my Civic's tyres. Now scraping under load! keertan Modifications & Accessories 14 8th June 2011 14:35
HELP -OHC under body(silencer) scraping speed breakers sushrutha Tyre & Alloy wheel Section 18 9th March 2010 10:29
Getz 1.3 - Metal scraping sound from the front nishantgandhi Technical Stuff 5 2nd June 2009 10:53
Scraping the Underside of my OHC aveek Modifications & Accessories 21 21st October 2005 14:15
