Old 17th May 2007, 03:40   #61
ankitahuja's Avatar
Thanked: 46 Times
Ishan, Im seriously in to get the tyres changed on my OHC first before I give it for the suspension work.
Im going to stick to stock 13" but need to know of good tyres, first in terms of comfort (low noise, cushioning) and then longevity ofcourse (they should last about 40-45k?). Not particularly emphasizing on grip grip grip but yea, who doesn't want good grip.
Secondly, what size in 13"? Is 195/XX/13 a good option? Tell me the max I can get in a budget of 3k per tyre with whatever you suggest in terms of brand. Speedo error?
AND tell me one person where to go, I need to do this URGENT.
Thanks!
Old 17th May 2007, 03:43   #62
v1p3r's Avatar
Thanked: 26 Times
You can't go 195/xx on your stock 13" steel rims. 185/70 is about as good as it gets. I would recommend Goodyear Ducaro GA. If they're anything like their GDi older brothers, they will be grippy, quiet, and will last you some.
Then again, these days Goodyear is churning out a lot of crap.
Old 17th May 2007, 03:43   #63
Godfather's Avatar
Thanked: 65 Times
195/65 Michelins all the way..
Godfather
Godfather is offline   Reply With Quote
Old 17th May 2007, 03:45   #64
v1p3r's Avatar
Thanked: 26 Times
195/65 13, the stock rims will not take. The tyres will bulge out WAY too much.
Old 17th May 2007, 03:49   #65
ankitahuja's Avatar
Thanked: 46 Times
Even I was wondering if 195 will be way too fat and ugly, but will there be a problem if used on stock 13" rims?
OHC stock is 175/75 if im correct?
Which Michelins are you talkin about Godfather?
EDIT: Does the Potenza fit my requirements?
Old 17th May 2007, 04:22   #66
Godfather's Avatar
Thanked: 65 Times
Michelin Pilot.
Yes the Potenza should be good but i would prefer the Michelins over Bridgestones anyday
Godfather
Old 17th May 2007, 11:54   #67
kpzen's Avatar
Thanked: 1,598 Times
OHC stock size is 175/70-13
U can fit Potenza GIII 185/70-13 on stock rims
Originally Posted by Godfather View Post
Michelin Pilot.
Godfather
Pilot precedas dont come in 13"
Old 17th May 2007, 12:09   #68
iraghava's Avatar
Thanked: 153 Times
I would recommend Michelin Energy XM1's in 185/70 R13 size. Have PM'ed you the number of the dealer also.
Old 17th May 2007, 12:18   #69
ankitahuja's Avatar
Thanked: 46 Times
Thanks v1p3r, Godfather and KP.
I read about these other tyres on the thread, can we consider any of these keeping in mind the options:
Manufactured in 13", Warranty, then further classified for comfort(low noise, cushioning) and then longevity ofcourse (they should last about 40-45k?).
1. Isn't Michelin Energy XM1 an option? OR
2. Bridgestone Turanza
3. Michelin Pilot Preceda/Pilot Primacy - Ruled out as N/A in 13"
5. Bridgestone Potenza GIII
6. Yokohama ES100/AVS Sport
(All suggested by Ishan earlier)
I also read in the forum that the G III tread wears off faster than other tyres, how long a life are we looking at?
Any prices for the above will be excellent?
Old 17th May 2007, 12:24   #70
kpzen's Avatar
s!
Sorry i didnt read your earlier post where u had mentioned about your requirements.
I would suggest u to go by what Ishan has suggested. Michelins are better in terms of road noise n comfort.
Michelin Energy Xm1 is also available in stock size 175/70-13 ..right Ishan ??
Old 17th May 2007, 12:31   #71
kpzen's Avatar
Yokohama ES100/AVS sport are not available in 13".
tsk has Potenza GIII in his Indica which is almost in its last phase n it has done 43K kms...So that is not bad for all the grip it provides...
Prices(185/70-13)
Potenza GIII - 2750
Energy XM1 - 2500 (Ishan can confirm this)
Turanza ER60 - 2700
Old 17th May 2007, 12:39   #72
iraghava's Avatar
Thanked: 153 Times
Ankit - Like I said earlier, keeping your requirements in mind the Energy is the best choice for you and is available in 175/70 & 185/70. Both are good sizes for you. As for wear I just changed my Energy's after 54k of usage!!
For prices you contact the reference I gave you.
Yes sir, it is available. Esteem_Lover has them on his car.
As for warranty, I just checked the booklet I recieved with my new tyres and it mentions a warranty of 3 years on the Michelin's. So I don't think you have anything to worry about.
Old 17th May 2007, 12:54   #73
Thanked: 20 Times
Is energy available in 175/80 14 ?
swathyd is offline   Reply With Quote
Old 17th May 2007, 13:05   #74
kpzen's Avatar
Arre Bhai..!!
Why dont u get 195/70-14 Michelin Energy XM1 for Adventure as Zaphod did ?
Michelin dealer in tvm
New Bharath tyres
Kochar road
Old 17th May 2007, 14:02   #75
Thanked: 20 Times
Arre Bhai..!!
New Bharath tyres
Kochar road
I fear low mileage and poor performance. Though i know xm 1 is better as they are asymmetrical and hence with silica compounds, which is less roll resistant. And perhaps enhancing pick up and mileage. But still i doubt whether it will retain earlier performance and mileage due to increased contact area, though slightly compensated by silica compounds.
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Everything you wanted to know about BMW v12 The International Automotive Scene 13 7th June 2012 09:46
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
Throw out everything you thought you knew about tyres. Auto Bild India knows best Nikhilb2008 Tyre & Alloy wheel Section 28 19th June 2009 19:26
