Old 21st May 2007, 20:02   #91
rks
rks's Avatar
Originally Posted by moralfibre View Post
I am not sure about 155's but I got the 165/60/R13 Mich XM1's for my cousin brothers Santro 2 weeks ago and he is enjoying the upgrade. They are very nice tyres.
Michelin Australia doesn't mention this size. Did you mean 165/65/R13, or maybe your tyres are Japanese? I think 165/60/R13 will be fine when the roads are good, but one needs to be cautious on bad roads in order to avoid tyre/wheel damage.
Another interesting detail that I just noticed in the Michelin Australia website is the recommended rim widths. For 155/70 R13 tyres that I have, the minimum/optimum/maximum rim widths mentioned are 4J/4.5J/5J respectively. Whereas the carbibles website has 4.5J/6J as min/max for the same tyres. I have always wondered why Hyundai used 4J rims for the stock 155/70 tyres, since the rim width is below minimum as per the carbibles website. But 4J rims would definitely be below minimum width for 165/60 tyres, so I hope your cousin has at least 4.5J.
I have 5J alloys, so I am presently on the upper limit as per Michelin Aus. Perhaps I should go for 165/65 R13 tyres next time if my alloys will permit them without fouling. The consensus in favour of the Energy XM1 seems to be very strong; so I will definitely give it a shot next time.
Old 21st May 2007, 20:13   #92
Vid6639's Avatar
Thanked: 21,075 Times
X3 cheers for rks. 165/65-13 as mentioned by KP is indeed the correct size for the santro. They shouldn't foul in anyway. Dont forget to get the aligment done as well as you are upsizing.
Old 21st May 2007, 21:49   #93
razor4077's Avatar
Thanked: 258 Times
They are, indeed, the correct upsize. Been using them on my Santro for 2 years, and am very satisfied. No fouling or scraping in any way, even while heavily loaded.
razor4077 is offline   Reply With Quote
Old 21st May 2007, 23:20   #94
kpzen's Avatar
Thanked: 1,655 Times
rks
5J alloys would be a perfect match for 165/65-13 tires.
Dont think it will scrape or touch anywhere unless the alloy's offset is way out of limits..
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Everything you wanted to know about BMW v12 The International Automotive Scene 13 7th June 2012 09:46
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
Throw out everything you thought you knew about tyres. Auto Bild India knows best Nikhilb2008 Tyre & Alloy wheel Section 28 19th June 2009 19:26
