Old 27th October 2013, 21:08   #91
archat68's Avatar
Thanked: 290 Times
Default Re: Onboard Tyre pressure sensors
Originally Posted by joybhowmik View Post
Now a question. The rated pressure for my tyres is 35 psi.
Rated pressure is always at cold.
archat68 is offline   Reply With Quote
Old 6th November 2013, 12:20   #92
SS-Traveller's Avatar
Thanked: 11,628 Times
My question - should I underinflate the tyres when they are cold, so that the running pressure is at 35 , when they are warm. Conversely pressurise to 35 psi when warm?
Inflate tyres to recommended pressure when cold. A rise of 2-3 psi (and even 5-7 psi) on prolonged running is normal.
Old 26th May 2014, 15:19   #93
Kaumad's Avatar
Thanked: 157 Times
Default Re: TyreProbe TPMS - 6 month review
Came across this one in one of the magazines.
http://www.steel-mate.co.in/index.html
Seems like a 2 minute job as they have described:
1. Remove your 4 plastic valve caps.
2. Screw in 4 of the pressure sensors on your existing tyre valves - no need to remove the tyre.
3. Pug the receiver + display into your 12V socket.
Well, thats pretty much it!!
Seems great but at close to INR 10k, it is a bit expensive.
Has anyone seen this? used this?
Last edited by aah78 : 30th May 2014 at 21:17. Reason: Post moved to relevant thread. Post edited.
Kaumad is offline   (1) Thanks Reply With Quote
Old 26th May 2014, 21:29   #94
sagarpadaki's Avatar
Thanked: 1,337 Times
Originally Posted by Kaumad View Post
Sorry for posting on this thread, because it it not TyreProbe.
What if someone flicks the valve cap sensor? Not useful in Indian conditions unless you have a locking mechanism in place for the valve Cap sensors
Last edited by aah78 : 30th May 2014 at 21:16. Reason: Post moved to relevant thread. Post edited.
Old 16th August 2014, 17:42   #95
Thanked: 172 Times
Originally Posted by Abes View Post
A salesman for LED lights had visited my office & gave me the catalogs of all their products. The TPMS in the catalog looks exactly like the one in your photo!
I was looking for TPMS and came across this post. Called the numbers mentioned in the picture in your post, though they say this product is still under development. No ETA.
Any more BHPians who have used TPMS? Can you please share your experiences and buying details?
mayuresh is offline   Reply With Quote
Old 15th October 2014, 13:53   #96
AZ911's Avatar
Thanked: 84 Times
I have been using Tyreprobe TPMS for past 5 months and it is working fantastically well. It retails for INR 10,500 now, but was for 9,000 when I had put it on. The installation is pretty simple, but requires hooking on the sensors to the existing valves after removing the tyres. The installation is free though and they offer warranty for a year. It is a basic LED display which is connected to the 12V port and displays the tyre pressure and temperature with alarms that you can set when a specific range or pressure and/or temperature is breached.
I am thinking of a DIY with which I can use a rechargeable battery pack attached behind the LED display to power it, rather than managing the long wire running down from the 12V port. Will keep you updated in case it works or not.
AZ911 is offline   (1) Thanks Reply With Quote
Old 15th October 2014, 19:43   #97
archat68's Avatar
Thanked: 290 Times
The wire also works as receiving antenna which picks up the wireless signals from the sensor. So, it is best to leave that as it is.
archat68 is offline   (1) Thanks Reply With Quote
Old 15th October 2014, 19:57   #98
AZ911's Avatar
Thanked: 84 Times
Are you sure about this? If I try with some other wire which goes to the battery instead of the 12V port, that'd not work?
AZ911 is offline   Reply With Quote
Old 15th October 2014, 20:26   #99
archat68's Avatar
Thanked: 290 Times
You need a length of wire from the power inlet of TPMS. This TPMS is a rebadged Orange P409S TPMS. I had the same one purchased from Amazon. It is clearly written in the manual that there are four wires in the power cord - green, red, black (antenna) and the silver (shield).
Download the manual from here and see yourself:
http://www.orange-electronic.com/en/orange_manual.html
Old 15th October 2014, 22:57   #100
joybhowmik's Avatar
Thanked: 1,928 Times
Right.
Would also be interested in your ownership experience on this thread.
http://www.team-bhp.com/forum/techni...th-review.html (TyreProbe TPMS - 6 month review)
Old 16th October 2014, 12:20   #101
archat68's Avatar
Thanked: 290 Times
Right.
It was good but after 1-1/2 years the battery of the sensors started to die one at a time and buying more than two new sensors is equal to buying a new TMPS. So, I bought a new one.
Actually in the older ones (which I had) the battery supply to the sensors were always on which caused the battery to die off sooner. But the newer ones had the system in which the supply to the sensors is activated by motion. So, if the car is kept without moving for more than 10-25 minutes the supply to the sensors get cu-off thus saving and prolonging battery life.
Old 16th October 2014, 12:25   #102
AZ911's Avatar
Thanked: 84 Times
I was told by the dealer that these batteries are replaceable and they usually anyway last for over 3 years. Taken for a ride? 😄
Old 16th October 2014, 13:38   #103
archat68's Avatar
Thanked: 290 Times
Batteries were not replaceable in the model that I had (the whole thing was sealed with epoxy or similar resin). But in newer models batteries should last for 3 years or more.
Old 16th October 2014, 19:06   #104
AZ911's Avatar
Thanked: 84 Times
I also found a Ahmedabad based company named 'Penetrate Navigation Devices' which apparently sells a GPS cum Tpms unit. Any of you have heard of them or used that product? I am yet to hear back from them with the price and some other details like warranty, fitting etc.
Old 5th February 2015, 11:48   #105
dynomite's Avatar
Thanked: 78 Times
Hey everyone - though you'd like to know about this. Blaupunkt India has launched their own TPMS system. Plug and play, like the Steelmate one, with 4 external sensors that you can install yourselves. I'm currently reviewing it - so can also answer any questions you may have. (Disclaimer: I'm in no way connected to Blaupunkt)
Here's the box.
Price label
This is the display unit - plugs directly into the 12V socket and shows real-time pressure for all wheels.
This is the 1 amp USB port behind the display. You can flip the display down and plug a phone in to charge if you like.
Here's a shot of the sensor installed on the valve. No wheel balancing is required after installation. Total installation takes only 5 minutes. Each sensor comes with a silver and a black cap and the lithium coin battery inside is user replaceable.
dynomite is offline   (3) Thanks Reply With Quote
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 731 19th July 2018 12:33
The right tyre pressure? BikerSG Tyre & Alloy wheel Section 165 30th June 2017 18:01
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Tyre pressure, have you checked yours lately? Shan2nu Tyre & Alloy wheel Section 216 14th March 2011 12:39
Tyre pressure indication on the sidewall!! Shan2nu Tyre & Alloy wheel Section 11 7th February 2005 15:37
