Old 8th June 2007, 17:12   #1
Thanked: 66 Times
Default Tyre size for zen.help needed
I have a 2003 model zen(old shape). i would like to fit wider tyres with a 13inch alloy. please recommend me for the widest tyre possible to be put on that car..
streetracer_919 is offline   Reply With Quote
Old 8th June 2007, 20:09   #2
CrAzY dRiVeR's Avatar
Thanked: 19,781 Times
I guess you currently have stock 145/80 R12...
If you need thicker tyres... You could opt for 165/ 65 R13... I guess kpzen has done this... You could get in touch with him for info...
Old 8th June 2007, 22:21   #3
Thanked: 66 Times
yes,am 145/80/12. i like to go for 175/60/13,but my tyre dealer told me that its not possible to fix beyond 165, is that true?? i have seen zen even with 195/45/14 in team bhp album!!
Old 8th June 2007, 22:48   #4
kpzen's Avatar
Thanked: 1,655 Times
165/60-13 tyres on 13" x 5j alloys would be the correct upsize..
I have 165/65-13 in my Zen on Esteem rims which i wouldn't recommend with an alloy combination....
Old 8th June 2007, 23:40   #5
then in that case go for 14 inch rim...and try 195 or 175 wot ever you want. but its not possible in 13 inch rim
zenopio is offline   Reply With Quote
Old 8th June 2007, 23:49   #6
kpzen's Avatar
Please have some mercy on the 1.0 L engine........
165/60-13 - Perfect upsize - Fantastic grip levels & handling but poor ride quality on bad roads
175/60-13 - Tried & tested not possible on a stock zen.. all four tyres foul with the wheel wells
195/45-14 - If u really wanna try this dont go beyond 5.5j rims.....
Old 8th June 2007, 23:57   #7
hey kpzen iam running om 155/65/r13 for my zen ....but still i feel my rear wheels foul with the arches...what might be the reason . i actually thought of goin for 165 but backed off i think it would have been worse ..do u think 165 will not foul with the body........
Old 9th June 2007, 00:09   #8
kpzen's Avatar
Originally Posted by zenopio View Post
hey kpzen iam running om 155/65/r13 for my zen ....but still i feel my rear wheels foul with the arches...what might be the reason ..
Size of your rim/alloy?? 5j or 5.5j ??
Old 9th June 2007, 00:11   #9
i think 5.3j or something they are of plati.....
Old 9th June 2007, 00:20   #10
kpzen's Avatar
Nahi yaar..!!
There's nothing like 5.3j ....Its either 5j or 5.5j.....
U have 5.5j alloys bcos plati i think doesn't have 5j alloys....
About your fouling issue its all because of 5.5j rims...Once u get 5j rims everything will be fine.....
165/60-13 with 5j rims also doesn't touch anywhere n trully handles like a dream with amazing grip levels buttttttt poor ride quality on bad roads
Old 9th June 2007, 02:14   #11
iraghava's Avatar
Thanked: 156 Times
Yup, it belongs to a member with the id Rev-Hard.
Old 9th June 2007, 02:51   #12
hellspawn's Avatar
Infractions: 0/1 (10)
the best upsize would be 155/65r13.175/60r13 would only fit on 5j rims.you will get 5j rims only from aura or neo.
hellspawn is offline   Reply With Quote
Old 9th June 2007, 09:25   #13
Default Please explain...
Nahi yaar..!!
Can you please tell me what is 5j and 5.5j rims??? How to tell the difference???
And, for my wagonR... Which would make a better choice (Has 155/65 R13 michelin energy Xm1 on stock rims now...
Old 9th June 2007, 10:57   #14
kpzen's Avatar
5j means the width of the rim is 5"........As u upsize the tyre u also need to upsize the rims to extract the max potential out of the tyre...Though its not necessary in very case like yours as its just a 10mm upsize...
Check out the rim width in the picture....
Old 9th June 2007, 21:31   #15
kpzen's Avatar
No 175/60-13 wont fit in a stock zen...Read post#6
Originally Posted by nischint View Post
205/60/r13 rubber..
source - orkut
Its just an overkill for a zen. It won't fit a stock zen unless u have a custom made wheel arches..
Lancer Tyre Size help for 15inch redeye Tyre & Alloy wheel Section 15 3rd May 2008 20:47
max tyre/alloy size for my Ikon? plz help young_icon Tyre & Alloy wheel Section 25 9th October 2007 09:16
What size speakers can I fit in Zen Estilo vebmetal In-Car Entertainment 11 28th September 2007 16:28
Getz and City max tyre size ? jesal The Indian Car Scene 16 2nd November 2004 20:00
