Old 13th June 2007, 14:10   #1
invincible7's Avatar
Thanked: 154 Times
Default Esteem Tyre Help
Which size would fit the esteem best.. currently i have 175/70/13 i think... i would be upsizing to the 14 inches alloys.. so which is the best suited tyre size and brand ....
invincible7 is offline   Reply With Quote
Old 13th June 2007, 14:31   #2
kpzen's Avatar
Thanked: 1,655 Times
185/60-14 is the best 14" upsize for an Esteem..
Tyre options:
1.Michelin Energy XM1 - Rs 3600
2.Bridgestone Potenza GIII- Rs 3400
3.Yokohama ES 100
Old 13th June 2007, 14:36   #3
Thanked: 154 Times
how about the Maxxis and the goodyear eagle F1.. would they be a good choice.....
Old 13th June 2007, 14:40   #4
kpzen's Avatar
Goodyear Eagle F1 would never be a good choice for sure..! Please avoid them.
Never used Maxxis Can't comment on them.! Are u getting them in 185/60-14??
Old 13th June 2007, 16:23   #5
Thanked: 154 Times
I am not aware whether Maxxis come in those sizes .. so just asked for them....as it is now a days most of them have been using this.. so was thinking might be a good rubber..
Old 13th June 2007, 17:10   #6
esteem_lover's Avatar
Thanked: 451 Times
I would suggest you to stick to 13" rims & 175/70/13 if you do not want the FE to be affected.
Old 13th June 2007, 17:23   #7
lohithrao's Avatar
Thanked: 163 Times
My OHC has "Bridgestone Turanza". Am loving it.
lohithrao is online now   Reply With Quote
Old 13th June 2007, 18:23   #8
Hellcat's Avatar
AS esteem_lover said stick to 175/70/13
I would suggest Yokohama ES 100, have used them, good performance looks and handling.
Hellcat
Hellcat is offline   Reply With Quote
Old 13th June 2007, 18:55   #9
n_aditya's Avatar
Thanked: 2,780 Times
175/70R13 is the correct size for the esteem but wouldn't hurt to upsize to 185/60 R14 or R13.
I suggest Michelin XM1 as the grip and tire life is good. I picked up my set in 175/70R13 size but i seriously wish i had gone for 185's. Can do with a lil more traction.
Havent tried yoko's but have heard lotsa good things 'bout them. Advan neova's supposedly are faaaaaaar better. Dunno if they come in the above menioned sizes. Maybe the tire guru's can comment.
Old 13th June 2007, 18:56   #10
Thanked: 154 Times
well how much does the FE affect moving to a higher size.. any ideas... as of now i am happy with the 13 inches.. since interested in moving to alloys so thought upsizing should be good...for handling ...
Old 13th June 2007, 19:13   #11
n_aditya's Avatar
FE will not drop more than 1 to 1.5 kmpl. But braking distance reduces considerably and the handling increases a lot too.
Old 13th June 2007, 19:28   #12
kpzen's Avatar
Hellcat
To my knowledge ES100 starts from 14".
Old 14th June 2007, 09:41   #13
hellspawn's Avatar
Infractions: 0/1 (10)
well 1-1.5kmpl is not the standard .if the upsize is done correctly keeping the circumference the same,the width is not increased too much(the contact patch),the tyre compound etc all decide the drop in efficiency.
for eg.if you upsize from 175/70r13 to 185/60r14,your contact area increases by 10mm(this extra area causes extra roling friction).assuming michelin energy xm1's 14" have the silica tread and it does work as claimed by the company,you should see an improvement in fuel economy which should negate the loss due to upsizing.
hellspawn is offline   Reply With Quote
Old 10th November 2007, 01:01   #14
blue2ki's Avatar
how much do PP2's 185/60-14 cost/tyre?
blue2ki is offline   Reply With Quote
Old 10th November 2007, 01:02   #15
kpzen's Avatar
Approx Rs 3800 per tyre.
Tyre Upsize for 2006 Esteem-Lxi Leinad Tyre & Alloy wheel Section 24 5th November 2011 12:48
1996 Esteem VX Tyre Query Bhargava_sr Tyre & Alloy wheel Section 15 6th October 2009 10:31
Esteem fuel pump(mpfi) in esteem-carb tank techn0l0gist Technical Stuff 0 13th June 2009 22:03
Help: one rupee tyre test and tyre sizes amit Tyre & Alloy wheel Section 14 22nd October 2006 08:18
Esteem VXI - Alloys/Tyre Sizes. - Hlp Pls mikemba Tyre & Alloy wheel Section 6 13th August 2006 12:44
